查看: 735|回复: 0
[ARX程序]:DWG CONVERTER: ICDWFIN ver.3.3.0.0
发表于 2003-8-1 00:09:33 | 显示全部楼层 |阅读模式
NEW VERSION!!!
DWF->DWG CONVERTER: ICDWFIN ver.3.3.0.0
(Released July 14/2003)
Version history
Current version: ICDWFIN.ARX v.3.3.0.0, released July 14/2003
version 3.3.0.0, current (July 14/2003)
Updated to include compatibility with AutoCAD 2002 and it's modified DWF file definition.
1.Added support for importing 'invisible' AutoCAD entities. This was a customer driven update since some DWF files could not be imported as all of the entities were marked as being 'invisible'.  It is also very useful when trying to recover a lost drawing as you will get all of your original information including all your entities which were hidden when creating the DWF file.
2.Added a user notification if an attempt is made to import a non-recoverable corrupt DWF file into AutoCAD.
3.Modified the entity creation to repaint the screen in stages, rather than after the entire file is processed. This lets the user know that work is actually taking place when working with large DWF files.
4.Modified the importing process dialog to give the user a better representation of what stage the processing of the DWF file is actually going through.
下载:http://www.intelcad.com/pages/dwfin/setup_dwfin2.exe
GMT+8, 2026-11-3 19:23 , Processed in 0.459581 second(s), 32 queries , Gzip On.
