查看: 1115|回复: 1
[LISP函数]:如何得到以下代码的AcDbObjectID?
发表于 2003-8-4 14:57:21 | 显示全部楼层 |阅读模式
//set up new layers
Acad::ErrorStatus createNewLayer(char* layername,int color)
        AcDbLayerTableRecord * pLayerTableRecord=new AcDbLayerTableRecord;
        if(pLayerTableRecord==NULL)
                return Acad::eOutOfMemory;
        Acad::ErrorStatus es=pLayerTableRecord->setName(layername);
        if(es!=Acad::eOk)
                delete pLayerTableRecord;
                return es;
        AcCmColor acCmColor;
        acCmColor.setColorIndex(color);
        pLayerTableRecord->setColor(acCmColor);
        //open layer table
        AcDbLayerTable *pLayerTable;
        es=acdbHostApplicationServices()->workingDatabase()
                ->getSymbolTable(pLayerTable,AcDb::kForWrite);
        if(es!=Acad::eOk)
                return es;
        //open linetype table
        AcDbLinetypeTable *pLinetypeTbl;
                ->getSymbolTable(pLinetypeTbl,AcDb::kForRead);
        if(es!=Acad::eOk)
                es=pLayerTable->close();
                if(es!=Acad::eOk)
                        acrx_abort("\nClose layer table fault,error: %d",
                                acadErrorStatusText(es));
                return es;
        //get "CONTINUOUS" linetype object's ID
        AcDbObjectId ltypeObjId;
        es=pLinetypeTbl->getAt("CONTINUOUS",ltypeObjId);
        if(es!=Acad::eOk)
                if(es!=Acad::eOk)
                return es;
        //setup linetype for new layer
        pLayerTableRecord->setLinetypeObjectId(ltypeObjId);
        es=pLayerTable->add(pLayerTableRecord);
        if(es!=Acad::eOk)
                Acad::ErrorStatus es2=pLayerTable->close();
                if(es2!=Acad::eOk)
                                acadErrorStatusText(es2));
                return es;
        //close layer table
        if(es!=Acad::eOk)
        //close layer table object
        es=pLayerTableRecord->close();
        if(es!=Acad::eOk)
        //return state code
        return es;
//不是写成一个类啊
发表于 2003-8-16 16:00:59 | 显示全部楼层
你的:es=pLayerTable->add(pLayerTableRecord);
换成:AcDbObjectId idLine;
            es=pLayerTable->add(idLine, pLayerTableRecord);
就可以了。
GMT+8, 2026-11-22 10:35 , Processed in 0.256503 second(s), 12 queries , Gzip On, File On.
