查看: 836|回复: 2
[转贴]:Import data from Access to Excel (ADO)
发表于 2003-8-10 16:21:38 | 显示全部楼层 |阅读模式
With the procedure below you can import data from an Access table to a worksheet.
Sub ADOImportFromAccessTable(DBFullName As String, _
    TableName As String, TargetRange As Range)
' Example: ADOImportFromAccessTable "C:\FolderName\DataBaseName.mdb", _
    "TableName", Range("C1")
Dim cn As ADODB.Connection, rs As ADODB.Recordset, intColIndex As Integer
    Set TargetRange = TargetRange.Cells(1, 1)
    ' open the database
    Set cn = New ADODB.Connection
    cn.Open "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & _
        DBFullName & ";"
    Set rs = New ADODB.Recordset
    With rs
        ' open the recordset
        .Open TableName, cn, adOpenStatic, adLockOptimistic, adCmdTable
        ' all records
        '.Open "SELECT * FROM " & TableName & _
            " WHERE [FieldName] = 'MyCriteria'", cn, , , adCmdText
        ' filter records
        RS2WS rs, TargetRange ' write data from the recordset to the worksheet
'        ' optional approach for Excel 2000 or later (RS2WS is not necessary)
'        For intColIndex = 0 To rs.Fields.Count - 1 ' the field names
'            TargetRange.Offset(0, intColIndex).Value = rs.Fields(intColIndex).Name
'        Next
'        TargetRange.Offset(1, 0).CopyFromRecordset rs ' the recordset data
    End With
    rs.Close
    Set rs = Nothing
    cn.Close
    Set cn = Nothing
End Sub
' RS2WS rs, Range("A3") ' rs is an ADO recordset variable
Sub RS2WS(rs As ADODB.Recordset, TargetCell As Range)
Dim f As Integer, r As Long, c As Long
    If rs Is Nothing Then Exit Sub
    If rs.State <> adStateOpen Then Exit Sub
    If TargetCell Is Nothing Then Exit Sub
    With Application
        .Calculation = xlCalculationManual
        .ScreenUpdating = False
        .StatusBar = "Writing data from recordset..."
    End With
    With TargetCell.Cells(1, 1)
        r = .Row
        c = .Column
    End With
    With TargetCell.Parent
        .Range(.Cells(r, c), .Cells(.Rows.Count, c + rs.Fields.Count - 1)).Clear
        ' clear existing contents
        ' write column headers
        For f = 0 To rs.Fields.Count - 1
            On Error Resume Next
            .Cells(r, c + f).Formula = rs.Fields(f).Name
            On Error GoTo 0
        Next f
        ' write records
        rs.MoveFirst
        On Error GoTo 0
        Do While Not rs.EOF
            r = r + 1
                .Cells(r, c + f).Formula = rs.Fields(f).Value
                On Error GoTo 0
            Next f
            rs.MoveNext
        Loop
        .Rows(TargetCell.Cells(1, 1).Row).Font.Bold = True
        .Columns("A:IV").AutoFit
    End With
    With Application
        .StatusBar = False
        .Calculation = xlCalculationAutomatic
        .ScreenUpdating = True
    End With
End Sub
发表于 2003-11-26 22:58:52 | 显示全部楼层
这段程序是VBA还是VB?谢了。
发表于 2003-11-27 02:27:46 | 显示全部楼层
vba是vb 的子集。
GMT+8, 2026-11-3 10:15 , Processed in 0.467238 second(s), 36 queries , Gzip On.
