查看: 1239|回复: 8
[求助]:斑竹请进,问题难了我好几天~~
发表于 2003-8-20 18:54:24 | 显示全部楼层 |阅读模式
斑竹那有没有 AcGeInterval 求交、并、差的例子,我怎么求出来的结果始终没有有效值???
如果有话请发往 amyandjans@sohu.com 谢谢了~~~
发表于 2003-8-20 19:00:17 | 显示全部楼层
最初由 jans_boy 发布
[B]斑竹那有没有 AcGeInterval 求交、并、差的例子,我怎么求出来的结果始终没有有效值???
如果有话请发往 amyandjans@sohu.com 谢谢了~~~ [/B]
把你求交、并、差的代码帖出来,这样大家也好帮你分析问题的原因!!
 楼主| 发表于 2003-8-21 08:44:14 | 显示全部楼层
CView *pView = acedGetAcadDwgView();
        if(pView == NULL) return;
        CRect rect;
        pView->GetClientRect (&rect);
        ads_name ssname;
        acedDwgPoint ptToLe;
        acedDwgPoint ptBoRi;
        acedCoordFromPixelToWorld(rect.TopLeft (), ptToLe);
        acedCoordFromPixelToWorld(rect.BottomRight (), ptBoRi);
        if(acedSSGet("W", ptToLe, ptBoRi, NULL, ssname) != RTNORM) return;
        long length;
        if(acedSSLength(ssname, &length) == RTNORM)
                AcGeVoidPointerArray curveSet;
                actrTransactionManager->startTransaction();
                for(int i=0; i<length; i++)
                        ads_name   tempName;
                        AcDbObjectId tempId;
                        if(acedSSName(ssname, i, tempName) == RTNORM)
                                acdbGetObjectId(tempId, tempName);
                                AcDbEntity *pEnt = NULL;
                                if(actrTransactionManager->getObject((AcDbObject *&)pEnt, tempId, AcDb::kForRead) == Acad::eOk)
                                        addToPtrArray(pEnt, curveSet);        //此处返回的是转换后的 AcGeCurve 数组
                                if(pEnt != NULL) pEnt->close();
                int geLength = curveSet.length();
                if(geLength < 2) return;
                AcGeInterval otherInter;
                ((AcGeCurve3d *)curveSet[0])->getInterval(otherInter);
                for(int n=1; n<geLength; n++)
                        AcGeInterval resultInter;
                        AcGeInterval tempInter;
                        ((AcGeCurve3d *)curveSet[n])->getInterval(tempInter);
                        double std; double end;
                        otherInter.getBounds(std, end);
                        acutPrintf("\n 0 >> start: %lf, end: %lf", std, end);
                        tempInter.getBounds(std, end);
                        acutPrintf("\n 1 >> start: %lf, end: %lf", std, end);
                        Adesk::Boolean er = otherInter.intersectWith(tempInter, resultInter);
                        if(er)
                                resultInter.getBounds(std, end);
                                acutPrintf("\n result >> start: %lf, end: %lf", std, end);
                                acutPrintf("\n insertsectWidth is %s", "TRUE");
                        else
                                acutPrintf("\n insertsectWidth is %s", "FALSE");
                        otherInter = resultInter;
发表于 2003-8-21 08:55:14 | 显示全部楼层
最初由 jans_boy 发布
[B]CView *pView = acedGetAcadDwgView();
        CRect rect;
        ads_name ssname;
        acedCoordFro... [/B]
把你的代码修改一下,现在还有语法错误呢!你看看下边那句:
最起码你要让大家能够编译通过吧!这样才好帮你找问题所在啊!!
for(int i=0; i {
ads_name tempName;
 楼主| 发表于 2003-8-21 09:00:53 | 显示全部楼层
工程附件
发表于 2003-8-21 09:18:41 | 显示全部楼层
最初由 jans_boy 发布
[B]工程附件 [/B]
说说你的这个工程主要完成一个什么功能,最好把你的编程思路和大家说说!!
 楼主| 发表于 2003-8-21 09:32:38 | 显示全部楼层
现在只是测试 AcGeInterval 类的使用,就是想得到视图可见的两个实体的交集,但是在调试的过程中,交集的 AcGeInterval::getBounds() 函数返回值总是无效的,例如:
otherInter.getBounds() 返回的范围是 0, 134.56
tempInter.getBounds() 返回的范围是 0, 234.34
调用 otherInter.intersectWith(tempInter, resultInter);
resultInter.getBounds() 返回值却是 0, 134.56
而两曲线肯定是相交的,这让我百思不得其解,难道是我理解错了,我理解 resultInter.getBounds()返回的数据就是两条曲线的相交点的参数 param 值。
发表于 2004-12-2 17:36:05 | 显示全部楼层
是呀,怎么不对,望斑竹指教
发表于 2004-12-6 13:20:59 | 显示全部楼层
期待
GMT+8, 2026-11-6 02:38 , Processed in 0.464795 second(s), 49 queries , Gzip On.
