查看: 1512|回复: 3
[求助]:2dpolyline做块问题
发表于 2002-6-21 09:28:30 | 显示全部楼层 |阅读模式
我用2dpolyline线做成块的时候pBlockTable->add(BlockId,blktab)出问题
如何解决 ???急
发表于 2002-6-21 09:31:05 | 显示全部楼层
Re: [求助]:2dpolyline做块问题
最初由 missmoney 发布
[B]我用2dpolyline线做成块的时候pBlockTable->add(BlockId,blktab)出问题
如何解决 ???急 [/B]
把你的代码贴出来吧。
 楼主| 发表于 2002-6-21 09:37:51 | 显示全部楼层
        ads_printf("len:%d",ObjIdArr.length());
        //ads_alert("in");
        AcDbBlockTableRecord* blktab;
        //        char judge[2];
        int len;
        AcDbEntity* ent;
        AcDbEntity* entclone;
        AcDbBlockReference* blkref;
        AcDbDatabase *pEntityDb;
        AcDbBlockTable *pBlockTable;
        AcDbBlockTableRecord *pBlockTableRecord;
        len=ObjIdArr.length();
        ads_printf("len:%d",len);
        for(int qj=0; qj<len; qj++)
                ads_printf("id:%ld",ObjIdArr[qj]);
        CString name;
        name=pszName;
        int judge=0;
        if(name=="")
                return 2;
        //acutPrintf("\nlen%d",len);
        pEntityDb = acdbCurDwg();//ObjectARX2000的形式
        // Get the model space Block Table Record
        if(pEntityDb->getBlockTable(pBlockTable, AcDb::kForWrite)!=Acad::eOk)
                return 2;
//        ads_alert("end getBlockTable");
        if(pBlockTable->has(pszName))
        //        ads_alert("has");
                if(pBlockTable->getAt(pszName,blktab,AcDb::kForWrite)!=Acad::eOk)
                        pBlockTable->close();
                        return 2;
                BlockId=blktab->objectId();
                /*        AcDbBlockReferenceIdIterator* bIter;
                blktab->newBlockReferenceIdIterator(bIter);
                for(int n=0; n<len; n++)
                if(bIter->seek(ObjIdArr[n])==Acad::eOk)
                blktab->close();
                return 1;
                AcDbObjectId idd;
                AcDbBlockTableRecordIterator *pBTableRecordItr;
        //        ads_alert("pBlockTable");
                if(pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite)!=Acad::eOk)
                        blktab->close();
                        return 2;
        //        ads_alert(" end pBlockTable");
                pBlockTableRecord->newIterator(pBTableRecordItr);
                AcDbBlockReference* iddEnt;
                //        AcArray<AcDbEntity*> entitiesToMove;
                for(pBTableRecordItr->start(); !pBTableRecordItr->done();
                pBTableRecordItr->step())
                        if(pBTableRecordItr->getEntity((AcDbEntity*&)iddEnt,AcDb::kForRead)!=Acad::eOk)
                                pBlockTableRecord->close();
                                blktab->close();
                                return 2;
                        if(iddEnt->isKindOf(AcDbBlockReference::desc()) == Adesk::kTrue)
                                if(iddEnt->blockTableRecord()==BlockId)
                                        idd=iddEnt->objectId();
                                                if(idd==ObjIdArr[n])
                                                        blktab->close();
                                                        iddEnt->close();
                                                        return 1;
                                }//endif
                        }//endif
                        iddEnt->close();
                pBlockTableRecord->close();//判断是否自身引用;end*/
                AcDbBlockTableRecordIterator *pBlockTableRecordItr;
                blktab->newIterator(pBlockTableRecordItr);
                AcDbEntity* pEnt;
                for(pBlockTableRecordItr->start(); !pBlockTableRecordItr->done();
                pBlockTableRecordItr->step())
                        if(pBlockTableRecordItr->getEntity(pEnt,AcDb::kForWrite)!=Acad::eOk)
                                blktab->close();
                                return 2;
                        AcTransaction* pTrans=actrTransactionManager->startTransaction();
                        //actrTransactionManager->enableGraphicsFlush(Adesk::kTrue);
                        actrTransactionManager->addNewlyCreatedDBRObject(pEnt);
                        if(pEnt->erase(Adesk::kTrue)!=Acad::eOk)
                                blktab->close();
                                pEnt->close();
                                // acutPrintf("\nerase");
                                return 2;
                        actrTransactionManager->endTransaction();
                        pEnt->close();
                }//删除原来实体;
                delete pBlockTableRecordItr;
                /*        if(pBlockTableRecord->assumeOwnershipOf(entitiesToMove)!=Acad::eOk)
                return false;
        //        ads_alert("acdbOpenAcDbEntity");
                for(int i=0;i<len;i++)
                        if(acdbOpenAcDbEntity(ent,ObjIdArr,AcDb::kForRead)!=Acad::eOk)
                                blktab->close();
                                // acutPrintf("/n1");
                                return 2;
                        //modified 2002-03-21
                        //begin
                        //将2dpolyline实体转换成polyline
                        if (ent->isKindOf(AcDb2dPolyline::desc()))
                                AcDbPolyline *pPline;
                                Poly2dToPoly(ent,pPline);
                                entclone = AcDbEntity::cast( pPline->clone() );
                                delete pPline;
                                ent->close();
                        else
                                entclone = AcDbEntity::cast( ent->clone() );
                                ent->close();
//                        entclone = AcDbEntity::cast( ent->clone() );
//                        ent->close();
                        //end
        //                ads_alert("appendAcDbEntity");
                        if(blktab->appendAcDbEntity(entclone)!=Acad::eOk)
                                blktab->close();
                                entclone->close();
                                //acutPrintf("/n2");
                                return 2;
        //                ads_alert("end appendAcDbEntity");
                        entclone->close();
                }//加入新实体;
//                ads_alert(" end ");
                if(blktab->setOrigin(ptBase)!=Acad::eOk)
                        //acutPrintf("\norigin\n");
                        blktab->close();
                        return 2;
                /* pBlockTable->close();
                return true;*/
                judge=1;
        }//end已存在此块;
        else
//                ads_alert("not has");
                //ads_alert("不已存在此块");
                blktab=new         AcDbBlockTableRecord();//创建块表记录;
                blktab->setName(pszName);
//                ads_alert("open 1");
                {//ads_alert("open in");
                                blktab->close();
                                return 2;
                //        ads_alert("end open in");
                        //begin
                /*        if (ent->isKindOf(AcDb2dPolyline::desc()))
                                ads_alert("2dp");
                                ads_alert("2dp clone");
                                ads_alert("end 2dp clone");
                            pPline->close();        //delete
                                ent->close();
                                ads_alert("end clone");
                        else
                                ent->close();
        //                ads_alert("2dp clone");
                        ent->close();
                //        ads_alert(" end 2dp clone");
                        //end
//ads_alert("appendAcDbEntity1");
                                ads_alert("!=Acad::eOk");
                                blktab->close();
                                entclone->close();
                                return 2;
                //        ads_alert(" end  appendAcDbEntity1");
                        entclone->close();
                ads_alert("setOrigin");
                        return 2;
                ads_alert(" end setOrigin");
                if(pBlockTable->add(BlockId,blktab)!=Acad::eOk)
                        ads_alert("pBlockTable->add(BlockId,blktab)!=Acad::eOk");
                        blktab->close();
                        //        acutPrintf("\n nono");
                        return 2;
                ads_alert("pBlockTable  ");
        }//end else;
        //acutPrintf("\nid%d",BlockId);
        // pBlockTable->close();
        ads_alert("end else;");
        if(judge==1)
                ads_alert("judge");
                AcDbBlockTableRecordIterator* pBlkTblRcdItr;
                        blktab->close();
                        return 2;
                pBlockTableRecord->newIterator(pBlkTblRcdItr);
                AcDbEntity* pEntItr;
                AcDbObjectId id;
                for(pBlkTblRcdItr->start(); ! pBlkTblRcdItr->done(); pBlkTblRcdItr->step())
                        pBlkTblRcdItr->getEntityId(id);
                        if(pTrans->getObject((AcDbObject*&)pEntItr,id ,  AcDb::kForWrite)!=Acad::eOk )
                                blktab->close();
                                return 2;
                        pEntItr->erase( Adesk::kTrue);
                        pEntItr->erase( Adesk::kFalse);
                        pEntItr->close();
                /*        AcDbBlockReferenceIdIterator* pIterator;
                AcDbObjectId id;
                AcDbEntity* ident;
                //ads_name entname;
                blktab->newBlockReferenceIdIterator( pIterator);
                blktab->close();
                for(pIterator->start(); !pIterator->done();        pIterator->step())
                //acdbGetAdsName( entname,ids[k]);
                //acedRedraw(entname , 1);
                  pIterator->getBlockReferenceId (id);
                  if(pTrans->getObject((AcDbObject*&)ident,id ,  AcDb::kForWrite)!=Acad::eOk )
                        //        if(acdbOpenAcDbEntity(ent,,AcDb::kForWrite)!=Acad::eOk)
                        //acutPrintf("\nopen");
                        return false;
                          ads_printf("\nt");
                          ident->erase( Adesk::kTrue);
                          ident->erase( Adesk::kFalse);
                                        // ident->draw();
                                        ident->close();
                                        //  actrTransactionManager->queueForGraphicsFlush();
                                        //  actrTransactionManager->flushGraphics();
                ads_alert("en d judge");
        blktab->close();
        //  AcDbBlockReference* blkref;
    blkref=new AcDbBlockReference();//创建块引用;
        if(blkref->setBlockTableRecord(BlockId)!=Acad::eOk);
        blkref->setPosition(ptBase);
        //加入引用块;
        pEntityDb =acdbCurDwg();//ObjectARX2000的形式
        if(pEntityDb->getBlockTable(pBlockTable, AcDb::kForRead)!=Acad::eOk)
                blkref->close();
                return 2;
                blkref->close();
                return 2;
        if(pBlockTableRecord->appendAcDbEntity(BlockRefID,blkref)!=Acad::eOk)
        {        pBlockTableRecord->close();
        blkref->close();
        return 2;
    blkref->close();
        //删除实体;
        ads_alert("删除实体");
        for(int h=0;h<len;h++)
                if(pTrans->getObject((AcDbObject*&)ent,ObjIdArr[h] ,  AcDb::kForWrite)!=Acad::eOk )
                        return 2;
                if(ent->erase(Adesk::kTrue)!=Acad::eOk)
                {        ent->close();
                return 2;
        }//end erase;
        //        BlockRefID=NULL;
        return 0;
发表于 2002-6-21 09:49:35 | 显示全部楼层
最初由 missmoney 发布
[B]{
        //ads_alert("in");
        //        char judge[2];
        int len;
        AcDbEntity* ent;
        AcDbBlockReference* blkre... [/B]
一般来说,出现这样结果的原因是:
AcDb2dPolyline是复杂实体,出了主实体ID外,还包括AcDb2dVertex实体。因此,在你把2DPOLY添加到一个AcDbBlockTableRecord(块表记录)里的时候,只把主实体的所属ID设置成了块表记录,但是子实体AcDb2dVertex对象的所属ID没有设置,造成了一个块中的实体有不同的BLOCKID,因此出错了。
解决方法是对子实体对象调用下setBlockId设置下所属ID为AcDbBlockTableRecord的ID值。
你试试。
对于2dpoly的操作,推荐最好还是实现转换为AcDbPolyline对象,这样是简单的实体,做其后的工作都很方便。
GMT+8, 2026-11-22 10:29 , Processed in 0.387927 second(s), 17 queries , Gzip On, File On.
