查看: 1282|回复: 3
[LISP函数]:VL-REMOVE
发表于 2003-8-27 19:40:30 | 显示全部楼层 |阅读模式
请教我在用VL-REMOVE函数时不知为什么有时有几个相同的,不能完全remove掉,有时又可以,不稳定不知道是什么原因?
已领礼包: 488个
发表于 2003-8-28 00:31:05 | 显示全部楼层
把你那个不能完全remove掉的表贴出来.
 楼主| 发表于 2003-8-28 13:36:24 | 显示全部楼层
(SETQ AUTOSS(SSGET "_W" FMP TOP (LIST (CONS 0 "CIRCLE"))))
  (SETQ SSAL(SSLENGTH AUTOSS) AUTOCEN(LIST))
  (WHILE (>= (1- SSAL) 0)
    (SETQ SSAUN(SSNAME AUTOSS (1- SSAL))
          SSAUL(ENTGET SSAUN)
          SSAUC(CDR(ASSOC 10 SSAUL))
    (SETQ AUTOCEN(APPEND AUTOCEN (LIST SSAUC)))
    (SETQ SSAL(1- SSAL))
  (SETQ AUTOCEN(VL-SORT AUTOCEN '(LAMBDA (X Y)(< (CAR X)(CAR Y)))))
(WHILE (> (LENGTH AUTOCEN) 0)
  (SETQ AUP(NTH 0 AUTOCEN))
  (SETQ A(SSGET "_W" FMP TOP (LIST (CONS 10 AUP))))
  (setq al(sslength a)
        ak 0)
  (while (>= al 1)
    (if (AND
        (/= (cdr(assoc 0 (entget(ssname a (1- al))))) "ARC")
        (/= (cdr(assoc 0 (entget(ssname a (1- al))))) "CIRCLE")
     (ssdel (ssname a (1- al)) a)
      );if
    (setq al(1- al))
    );while
        aa(list)
        ak 0)
  (repeat al
    (setq aname(ssname a ak)
          alist(entget aname)
          ality(assoc 6 alist)
          acr(assoc 40 alist)
          aty(assoc 0 alist)
          acol(assoc 62 alist)
      (setq aks(ssget "_w" fmp top (list aty acr ))
            aksl(sslength aks)
    (SETQ AKSL(SSLENGTH AKS) AKSK 0)
      (repeat aksl
        (setq aa(append aa (list(ssname aks aksk))))
        (setq aksk(1+ aksk))
        );repeat sksl
    (SETQ AK(1+ AK))
    );REPEAT  AL
  (setq aal(length aa))
(setq aak 0
      aaj 1
      ss (list)
  (if (/= al 1)
(repeat (1- aal)
  (setq aaid(cdr(assoc 10 (entget(nth aak aa)))))
  (setq sameid(list))
  (repeat (- aal aak 1)
    (setq aaid2(cdr(assoc 10(entget(nth aaj aa)))))
    (if (and (= (rtos (car aaid) 2 6)(rtos (car aaid2) 2 6))
             (= (rtos (cadr aaid) 2 6)(rtos (cadr aaid2) 2 6))
;;;    (if (equal aaid aaid2)
      (setq sameid(append sameid (list aaid2)))
      );if
    (setq aaj(1+ aaj))
    );repeat
  (setq sameid(append sameid (list aaid)))
  (if (= al (length sameid))
    (setq ss(append ss (list aaid)))
    );if
  (setq aak(1+ aak)
        aaj(1+ aak)
  );repeat
  (PROGN
    (SETQ AAK 0 ss(list))
  (REPEAT AAL
    (SETQ AAID(CDR(ASSOC 10 (ENTGET (NTH AAK AA)))))
    (SETQ SS(APPEND SS (LIST AAID)))
    (SETQ AAK(1+ AAK))
(setq ssl(length ss) sskk 0 SSCEN(LIST))
(repeat ssl
  (setq ssa(ssget "_w" fMp top (list (cons 0 "ARC")(cons 10 (nth sskk ss)))))
  (SETQ Ssc(ssget "_w" fMp top (list (cons 0 "CIRCLE")(cons 10 (nth sskk ss)))))
  (IF (/= SSA NIL)(SETQ SSAL (SSLENGTH SSA))(SETQ SSAL 0))
  (IF (/= SSC NIL)(SETQ SSCL(SSLENGTH SSC))(SETQ SSCL 0))
  (IF (= AL (+ SSAL SSCL))(SETQ SSCEN(APPEND SSCEN (LIST(NTH SSKK SS)))))
  (SETQ SSKK (1+ SSKK))
(SETQ SS SSCEN)
(setq ss(vl-sort ss '(lambda (x y)(< (car x)(car y)))))
(SETQ SSL(LENGTH SS) SSK 0)
  (REPEAT SSL
    (SETQ MOID(NTH SSK SS))
    (SETQ AUTOCEN(VL-REMOVE MOID AUTOCEN))
    (SETQ SSK(1+ SSK))
 楼主| 发表于 2003-8-28 13:42:24 | 显示全部楼层
          SSAUL(ENTGET SSAUN)
        ak 0)
  (while (>= al 1)
    (if (AND
      );if
    (setq al(1- al))
    );while
        aa(list)
        ak 0)
  (repeat al
          alist(entget aname)
          acr(assoc 40 alist)
          aty(assoc 0 alist)
            aksl(sslength aks)
      (repeat aksl
        );repeat sksl
    (SETQ AK(1+ AK))
    );REPEAT  AL
(setq aak 0
      aaj 1
      ss (list)
  (if (/= al 1)
(repeat (1- aal)
  (setq sameid(list))
      );if
    (setq aaj(1+ aaj))
    );repeat
    );if
  (setq aak(1+ aak)
        aaj(1+ aak)
  );repeat
  (PROGN
  (REPEAT AAL
    (SETQ AAK(1+ AAK))
(repeat ssl
(SETQ SS SSCEN)
  (REPEAT SSL
    (SETQ SSK(1+ SSK))
GMT+8, 2026-11-3 20:09 , Processed in 0.464595 second(s), 39 queries , Gzip On.
