查看: 1629|回复: 7
[公告]:ArchiCAD 8.1新特性
发表于 2003-8-29 18:26:57 | 显示全部楼层 |阅读模式
ArchiCAD 8.1: Code name Hyppolit
ArchiCAD 8.1,代号Hyppolit
Some of the new features of the upcoming ArchiCAD 8.1 (which can not be considered just a simple maintenance upgrade), have started to leak out. Let see some of them.
一些即将到来的ArchiCAD 8.1的新特性(不可以被当作是简单的升级维护),开始泄漏了。来看看:
ArchiCAD 8.1:
ArchiCAD 8.1:
1. The increase of the 2D navigation speed
1、2D Navigation(2D导航)速度提升
2. Possibility of assigning different line types to all skin separator lines of composite structures
2、可以指定不同的线型(Line Type)作为复合结构(composite structures)的各层分界线
3. Possibility to hide either end lines of a composite wall on the floor plan.
3、可以在平面上隐藏复合结构墙体的任何一条线
4. Wall-end tool: allows to create a correct end profile of a free standing composite wall with just one click. Furthermore it automatically resizes itself when it gets placed to a different wall type and it stays on the end of the wall when this one is stretched.
4、这句不会逐词翻译。大意是,会有一个新的工具,Wall-End Tool,似乎是自动放样工具。它可以随着被指定的墙体的变化自动变化。
5. Connections of cross intersecting walls are now cleaned up automatically (this feature can be switched on and off according to the user needs).
5、可以自动清理交叉的墙体(这个特性可以澳找用户的需要打开或者关闭)
6. Addition of smart hotspots along both sides of a wall (not just along its reference line side).
6、聪明的Hotspot(一直不知道这个东西翻译成什么比较好)被添加在墙体的两侧(而不是墙体参考线上)
7. Possibility to assign keyboard shortcuts to all tools and actions and not just to menu commands. For example the shortcut "M" can be assigned to the wall tool and other shortcuts can link directly to different geometry or construction methods etc.
7、可以为所有的工具和动作指定键盘快捷键,不仅仅是菜单命令。据个例子,“M”可以被指定给墙体工具,其他的快捷可以连接到不同的几何或者构造方式上,等等。
8. Possibility to print only a "marquue area" of a project and not the entire windows or view content, by placing a marquue area and selecting the print marquee option. The placement of a header or footer note and the re-positioning of the final drawing on the page is also possible.
8、可以通过放置Marquue和选择Marquue打印来仅仅打印项目的一个区域而不是整个窗口或者视图。页眉和页脚以及图纸相对于打印纸的定位都可以被调整。
PlotMaker:
1.Beside masterpages, drawing titles were also added. They can indicate drawing specific details, like drawing name, drawing number etc, and they can be placed by each drawing automatically.
1、在Master中,加上了图纸名称(?不知道这么翻译是否合适,所以以下省略)
2. Implementation of a drawing numbering system for the placed drawings on a layout.
2、在一个layout上放置图纸时,执行图纸编号系统。
3 Possibility to set rules for how the placed drawings will update their attributes in the whole layout book, with the option of making exceptions when needed.
3、可以设定义被放置的图纸的属性更新规则。
DWG interchange:
DWG 交换:
When exporting to AutoCAD 2004 format, dimensions remain dimensions, including the custom placed dimension text, which keeps its original position.
当输出为AutoCAD2004各式的时候,AC的标注转化为ACAD的标注,包括自定的标注文字放置位置。
Zones get translated into blocks keeping their hidden parameters.
AC的Zone被转化成为ACAD的Block,以保持隐藏的参数。
Multiline text temain multiline text without breaking apart;
多行文字保持不变,不会被拆分。
ArchiCAD labels get converted to leaders (their equivalents in Autocad).
AC的Label转换成ACAD的Leader。
ArchiCAD patches now correctly cover the area where they were originally placed with no need of correcting them in Autocad.
AC的Patch现在可以正确的转换了,不需要再ACAD中修改。
[BTW]还是给配上翻译算了。
发表于 2003-8-30 14:09:32 | 显示全部楼层
这个好,终于可以象ACAD一样一手键盘,一手鼠标了。
 楼主| 发表于 2003-8-30 14:34:48 | 显示全部楼层
我也喜欢!
发表于 2003-8-30 21:58:05 | 显示全部楼层
不知什么时候有8.1的crack 了
发表于 2003-10-12 23:37:08 | 显示全部楼层
用的少,D版不知要什么时候啊!!
发表于 2003-10-13 20:07:35 | 显示全部楼层
受累打听一下,我刚下载完的R3是8.1吗?
发表于 2003-10-14 09:50:59 | 显示全部楼层
最初由 mic2 发布
[B]受累打听一下,我刚下载完的R3是8.1吗? [/B]
R3是8.03~不是8.1*-*6
发表于 2003-10-14 10:14:16 | 显示全部楼层
听说旧插件不能使用在8.1。又多一次革命。。。。。。。。
GMT+8, 2026-11-22 10:59 , Processed in 0.558558 second(s), 25 queries , Gzip On, File On.
