查看: 918|回复: 2
[求助] [求助]:帮我rtos函数点解
发表于 2003-8-30 20:22:37 | 显示全部楼层 |阅读模式
郁闷啊,
(rtos 1.14159 2 3)返回是1.142
可(rtos 0.5 2 3)返回不是0.500而是0.5
已领礼包: 593个
发表于 2003-8-30 20:40:56 | 显示全部楼层
检查 系统变量 dimzin
发表于 2003-8-31 07:02:18 | 显示全部楼层
Type: Integer
Saved in: Drawing
Initial value: 0
Controls the suppression of zeros in the primary unit value. DIMZIN stores this value when you enter it on the command line or set it under Primary Units in the Annotation dialog box. DIMZIN values 0–3 affect feet-and-inch dimensions only.
0 Suppresses zero feet and precisely zero inches
1 Includes zero feet and precisely zero inches
2 Includes zero feet and suppresses zero inches
3 Includes zero inches and suppresses zero feet
4 Suppresses leading zeros in decimal dimensions (for example, 0.5000 becomes .5000)
8 Suppresses trailing zeros in decimal dimensions (for example, 12.5000 becomes 12.5)
12 Suppresses both leading and trailing zeros (for example, 0.5000 becomes .5)
DIMZIN also affects real-to-string conversions performed by the AutoLISP rtos and angtos functions.
GMT+8, 2026-11-3 20:13 , Processed in 0.497797 second(s), 36 queries , Gzip On.
