查看: 929|回复: 3
[编程申请]:在arx中如何使用dll
发表于 2003-9-24 09:55:16 | 显示全部楼层 |阅读模式
因为我要把图传到其它计算机去,要用到dll,而我不会,现在也没有资料。于是就问:在arx中如何使用dll? 就是C调用dll。
这有一个例子,能帮我写出来吗?
dll路径:C:\web.dll
有一个函数:int _stdcall connect(HTTP_CONNECTION **connection, const char *host, short port, const char *username, const char *password)
其中HTTP_CONNECTION 是一个结构体,定义如下
struct http_connection {
SOCKET socketd;
int status;
char *host;
struct sockaddr_in address;
int persistent;
HTTP_AUTH_INFO *auth_info;
(其它定义略)
问题:我怎么调用这个函数?比如在head.h 中如何声明,head.cpp中如何使用?
静态如何?
动态如何?
谢谢!
声明:
#define DllImport _declspec(dllimport)
typedef struct http_connection      HTTP_CONNECTION;
typedef struct http_auth_parameter  HTTP_AUTH_PARAMETER;
typedef struct http_auth_info       HTTP_AUTH_INFO;
SOCKET socketd;
int status;
char *host;
int persistent;
struct http_auth_parameter {
char *name;
char *value;
HTTP_AUTH_PARAMETER *next_parameter;
HTTP_AUTH_PARAMETER *prev_parameter;
struct http_auth_info {
char *method;
int count;
HTTP_AUTH_PARAMETER *first_parameter;
HTTP_AUTH_PARAMETER *last_parameter;
extern "C" int _stdcall dav_init(void);
extern "C" int _stdcall dav_connect(HTTP_CONNECTION **connection, const char *host, short port, const char *username, const char *password);
调用:
HTTP_CONNECTION *connection = NULL;
connection = (HTTP_CONNECTION *) malloc(sizeof(HTTP_CONNECTION));
typedef int(proc1)(HTTP_CONNECTION **connection, const char *host, short port, const char *username, const char *password);
proc1* pFunc1;
HINSTANCE hInstance;
hInstance=::LoadLibrary("C:\\ploting\\webdav.dll");
if(hInstance==NULL)
        acutPrintf("\n can not fine dll file.");
        pFunc1=(proc1*)::GetProcAddress(hInstance,"dav_connect");
int test=(*pFunc1)(&connection,(char *)"192.168.0.22",8080,(char *)"maf",(char *)"maf");
acutPrintf("\n test is %d",test);
编译错误:
Run-Time Check Failure #0 - The value of ESP was not properly saved across a function call.  This is usually a result of calling a function declared with one calling convention with a function pointer declared with a different calling convention.
是为什么?
发表于 2003-9-24 18:31:35 | 显示全部楼层
我的一个学习调用DLL的例子,不过是以ARX作为DLL的
 楼主| 发表于 2003-9-25 08:55:21 | 显示全部楼层
好的,谢谢!
发表于 2003-10-6 10:50:33 | 显示全部楼层
1。把dll文件copy入AutoCAD 搜索路径或系统目录
2. 在ARX中包含.h
3.直接调用dll函数即可
GMT+8, 2026-11-2 22:21 , Processed in 0.502935 second(s), 39 queries , Gzip On.
