查看: 1079|回复: 0
[ARX程序]:把Y.LIN在对话框中显示, 并根据对话框中修改值来存盘?
发表于 2002-7-24 09:06:38 | 显示全部楼层 |阅读模式
我定义了一个线型Y.SHX, 作为防护林用。 下面代码把Y.LIN在对话框中显示, 但如何根据对话框中修改值来存盘?
y.lin is as followed:
*YYL1,F2 circle
A,0,[CIRC2,Y.shx,s=1],-50
//The following is the code of diaplaying and editing y.lin
#include "stdafx.h"
#include "MyExam07Dlg.h"
#include "exam07.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// MyExam07Dlg dialog
MyExam07Dlg::MyExam07Dlg(CWnd* pParent /*=NULL*/)
        : CAcUiDialog(MyExam07Dlg::IDD, pParent)
        //{{AFX_DATA_INIT(MyExam07Dlg)
                // NOTE: the ClassWizard will add member initialization here
        //}}AFX_DATA_INIT
void MyExam07Dlg::DoDataExchange(CDataExchange* pDX)
        CAcUiDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(MyExam07Dlg)
        DDX_Control(pDX, IDC_EDIT_YPT, m_ctrlYPtEdit);
        DDX_Control(pDX, IDC_EDIT_XPT, m_ctrlXPtEdit);
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(MyExam07Dlg, CAcUiDialog)
        //{{AFX_MSG_MAP(MyExam07Dlg)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// MyExam07Dlg message handlers
BOOL MyExam07Dlg::OnInitDialog()
        SetDialogName("exam07:MyExam07Dlg");
        CAcUiDialog::OnInitDialog();
        DLGCTLINFO dlgSizeInfo[]= {
                { IDC_STATIC_GROUP1, ELASTICX, 20 },
                { IDC_STATIC_GROUP1, ELASTICY, 100 },
                { IDC_EDIT_XPT,ELASTICX, 20 },
                { IDC_EDIT_YPT,ELASTICX, 20 },
                { IDC_STATIC_GROUP3, MOVEY, 100 },
                { IDC_STATIC_GROUP3, ELASTICX, 20 },
                { IDOK,MOVEX, 100 },
                { IDCANCEL, MOVEX, 100 },
        const DWORD numberofentries =
                sizeof dlgSizeInfo / sizeof DLGCTLINFO;
        SetControlProperty(dlgSizeInfo, numberofentries);
          DisplayPoint();
        SetWindowText("Forrest Lines");
        return TRUE;
void MyExam07Dlg::OnOK()
{   FILE *fp;
    if ((fp=fopen("y.lin","w"))==0) {
             acutPrintf("cannot open file \n");
             return;
    fclose(fp);
        CAcUiDialog::OnOK();
void MyExam07Dlg::DisplayPoint()
{   FILE *fp;
        if ((fp=fopen("y.lin","r"))==0) {
             return;
    //AfxMessageBox("m_str");
    acutPrintf("%c fir\n", getc(fp));
    acutPrintf("%c fir\n", getc(fp));*/
    m_str=getc(fp);
        acutPrintf("%s first\n", m_str);
        while (m_str != EOF) {
                if (m_str == '=')  {
                        m_strXPt=getc(fp);
                ch=getc(fp);
                        while (ch != ']' ) {
              m_strXPt=m_strXPt+ch;
              ch=getc(fp);
                if (m_str == '-')  {
                        m_strYPt=getc(fp);
            ch=getc(fp);
                        while (ch !=EOF) {
              m_strYPt=m_strYPt+ch;
              ch=getc(fp);
      m_str=getc(fp);
    acutPrintf("%s radius\n", m_strXPt);
    acutPrintf("%s offset\n", m_strYPt);
    m_strXPt=getc(fp);
        if (m_strXPt = "*")  m_strXPt=getc(fp);
        m_strXPt+=getc(fp);
    m_strYPt=getc(fp);
        m_ctrlXPtEdit.SetWindowText(m_strXPt);
        m_ctrlXPtEdit.Convert();
        m_ctrlYPtEdit.SetWindowText(m_strYPt);
        m_ctrlYPtEdit.Convert();
    fclose(fp);
GMT+8, 2026-11-3 01:14 , Processed in 0.461892 second(s), 32 queries , Gzip On.
