查看: 486|回复: 0
[讨论]:使多义线到序的函数:等待修改入库
发表于 2003-10-26 15:47:22 | 显示全部楼层 |阅读模式
  1. bool oxaReversePolyline(ads_name entname)
  2. {
  3.          char *strGet=new char[32];
  4.          AcDbObjectId   idPline;
  5.          if (acdbGetObjectId(idPline, entname)!=Acad::eOk)
  6.          {
  7.                   return ;//false;
  8.          }
  9.          AcDbEntity*  pEnt;
  10.          if(Acad::eOk!=acdbOpenAcDbEntity(pEnt, idPline, AcDb::kForWrite))
  11.          {
  12.                  return ;//false;
  13.          }
  14.
  15.          //判断是不是曲线
  16.          AcDbPolyline  *cvPLine=AcDbPolyline::cast(pEnt);
  17.          if (cvPLine==NULL)//acutPrintf("\n 选择的不是Polyline ");
  18.          {
  19.                  pEnt->close();
  20.                   return ;//false;
  21.          }
  22.          //
  23.          unsigned int uiNumberTotal=cvPLine->numVerts();
  24.          unsigned int uiNumber=uiNumberTotal/2; // 折半,通过整数相除舍去余数
  25.          uiNumberTotal--;   //修正之,因为index起点是0
  26.          AcGePoint2d ptFront, ptBack;
  27.          double      dBulgeFront, dBulgeBack;
  28.          for(unsigned int index=0;index<uiNumber;index++)
  29.          {
  30.                  cvPLine->getPointAt(index,ptFront);
  31.                  cvPLine->getBulgeAt(index+1,dBulgeFront);
  32.                  cvPLine->getPointAt(uiNumberTotal-index,ptBack);
  33.                  cvPLine->getBulgeAt(uiNumberTotal-index-1,dBulgeBack);
  34.                   acutPrintf("\n---fBulge=%f ,%f ,",dBulgeFront ,dBulgeBack);
  35.                    cvPLine->setPointAt(index,ptBack);
  36.                    cvPLine->setBulgeAt(index,-dBulgeBack);
  37.                  cvPLine->setPointAt(uiNumberTotal-index,ptFront);
  38.                    cvPLine->setBulgeAt(uiNumberTotal-index+1,-dBulgeFront);
  39.          }
  40.          cvPLine->close();
  41.          pEnt->close();
  42.           return ;//true;
  43. }
复制代码
GMT+8, 2026-11-5 10:12 , Processed in 0.267806 second(s), 30 queries , Gzip On.
