查看: 2112|回复: 15
[原创]:我的小小快捷方式
发表于 2003-11-7 14:03:53 | 显示全部楼层 |阅读模式
下面的小函数放到acad.lsp里“c:”后面的是简码,“ ”
内的是原始命令,简码可以根据习惯自己修改。
(DEFUN C:Ap  () (COMMAND "APERTURE"))
(DEFUN C:AA  () (COMMAND "AREA"))
(DEFUN C:A  () (COMMAND "ARRAY"))
(DEFUN C:AtF () (COMMAND "ATTDEF"))
(DEFUN C:Atp () (COMMAND "ATTDISP"))
(DEFUN C:ATX () (COMMAND "ATTEXT"))
(DEFUN C:AX  () (COMMAND "AXIS"))
(DEFUN C:BS  () (COMMAND "BASE"))
(DEFUN C:BM  () (COMMAND "BLIPMODE"))
(DEFUN C:Bl   () (COMMAND "BLOCK"))
(DEFUN C:BE  () (COMMAND "BLOCK" PAUSE "0,0" (SSGET "X" ()) ""))
(DEFUN C:B   () (COMMAND "BREAK"))
(DEFUN C:CF  () (COMMAND "CHAMFER"))
(DEFUN C:Cg  () (COMMAND "CHANGE"))
(DEFUN C:DCH () (COMMAND "DDCHPROP"))
(DEFUN C:CH  () (COMMAND "CHPROP"))
(DEFUN C:Ci  () (COMMAND "CIRCLE"))
(DEFUN C:CR  () (COMMAND "COLOUR"))
(DEFUN C:C   () (COMMAND "COPY"))
(DEFUN C:CP  () (COMMAND "COPY" "P" ""))
(DEFUN C:DB  () (COMMAND "DBLIST"))
(DEFUN C:DY  () (COMMAND "DELAY"))
(DEFUN C:DI  () (COMMAND "DIM"))
(DEFUN C:D1  () (COMMAND "DIM1"))
(DEFUN C:D   () (COMMAND "DIST"))
(DEFUN C:DD () (COMMAND "DDEDIT"))
(DEFUN C:DiV  () (COMMAND "DIVIDE"))
(DEFUN C:DV () (COMMAND "DVIEW"))
(defun c:dm () (command "ddmodes"))
(DEFUN C:DN  () (COMMAND "DONUT"))
(DEFUN C:DNN () (COMMAND "DOGHNUT"))
(DEFUN C:DG  () (COMMAND "DRAG"))
(DEFUN C:DdM  () (COMMAND "DDMODIFY"))
(DEFUN C:DT  () (COMMAND "DTEXT"))
(DEFUN C:DXB () (COMMAND "DXBIN"))
(DEFUN C:DXi () (COMMAND "DXFIN"))
(DEFUN C:DXO () (COMMAND "DXFOUT"))
(DEFUN C:EV  () (COMMAND "ELEV"))
(DEFUN C:ELP () (COMMAND "ELIPSE"))
(DEFUN C:E   () (COMMAND "ERASE"))
(DEFUN C:EL  () (COMMAND "ERASE" "L" ""))
(DEFUN C:EX  () (COMMAND "EXPLODE"))
(DEFUN C:Ed  () (COMMAND "EXTEND"))
(DEFUN C:FS   () (COMMAND "FILES"))
(DEFUN C:FL  () (COMMAND "FILL"))
(DEFUN C:F   () (COMMAND "FILLET"))
(DEFUN C:Fc   () (COMMAND "FILLET" "c" ""))
(DEFUN C:GR  () (COMMAND "GRAPHSCRN"))
(DEFUN C:G   () (COMMAND "GRID"))
(DEFUN C:HT  () (COMMAND "BHATCH"))
(DEFUN C:HD  () (COMMAND "HIDE"))
(DEFUN C:IGI () (COMMAND "IGESIN"))
(DEFUN C:IGO () (COMMAND "IGESOUT"))
(DEFUN C:I  () (COMMAND "INSERT"))
(DEFUN C:IP  () (COMMAND "ISOPLANE"))
(defun c:l   () (command "line"))
(DEFUN C:LA  () (COMMAND "LAYER"))
(DEFUN C:LM  () (COMMAND "LAYER" "M"))
(DEFUN C:LS  () (COMMAND "LAYER" "S"))
(DEFUN C:L0  () (COMMAND "LAYER" "S" "0" ""))
(DEFUN C:LN  () (COMMAND "LAYER" "N"))
(DEFUN C:Lo  () (COMMAND "LAYER" "ON"))
(DEFUN C:na  () (COMMAND "LAYER" "ON" "*" "" ))
(DEFUN C:fa  () (COMMAND "LAYER" "OFF" "*" "" ""))
(DEFUN C:T*  () (COMMAND "LAYER" "T" "*" "" ))
(DEFUN C:F*  () (COMMAND "LAYER" "F" "*" "" ))
(DEFUN C:L-  () (COMMAND "LAYER" "OFF"))
(DEFUN C:LF  () (COMMAND "LAYER" "F"))
(DEFUN C:LH  () (COMMAND "LAYER" "T"))
(DEFUN C:LC  () (COMMAND "LAYER" "C"))
(DEFUN C:L?  () (COMMAND "LAYER" "?" "" ""))
(DEFUN C:LR  () (COMMAND "LINE" "@"))
(DEFUN C:LTP () (COMMAND "LINETYPE"))
(DEFUN C:LI  () (COMMAND "LIST"))
(DEFUN C:LTS () (COMMAND "LTSCALE"))
(DEFUN C:ME  () (COMMAND "MEASURE"))
(DEFUN C:MT  () (COMMAND "MINSERT"))
(DEFUN C:Mi  () (COMMAND "MIRROR"))
(DEFUN C:M   () (COMMAND "MOVE"))
(DEFUN C:ML  () (COMMAND "MOVE" "L" ""))
(DEFUN C:MP  () (COMMAND "MOVE" "P" ""))
(DEFUN C:MW  () (COMMAND "MOVE" "W"))
(DEFUN C:MC  () (COMMAND "MOVE" "C"))
(DEFUN C:MSD () (COMMAND "MSLIDE"))
(DEFUN C:O   () (COMMAND "OFFSET"))
(DEFUN C:OO  () (COMMAND "OOPS"))
(DEFUN C:OP  () (COMMAND "OPEN"))
(DEFUN C:OS  () (COMMAND "OSNAP"))
(DEFUN C:OC  () (COMMAND "OSNAP" "CENT"))
(DEFUN C:OE  () (COMMAND "OSNAP" "END"))
(DEFUN C:OT  () (COMMAND "OSNAP" "INSERT"))
(DEFUN C:OI  () (COMMAND "OSNAP" "INT"))
(DEFUN C:OM  () (COMMAND "OSNAP" "MID"))
(DEFUN C:ON  () (COMMAND "OSNAP" "NEAR"))
(DEFUN C:OD  () (COMMAND "OSNAP" "NODE"))
(DEFUN C:OF  () (COMMAND "OSNAP" "NONE"))
(DEFUN C:OPP () (COMMAND "OSNAP" "PERP"))
(DEFUN C:OQ  () (COMMAND "OSNAP" "QUAD"))
(DEFUN C:OK  () (COMMAND "OSNAP" "QUICK"))
(DEFUN C:OT  () (COMMAND "OSNAP" "TANG"))
(DEFUN C:ORT () (COMMAND "ORTHO"))
(DEFUN C:P   () (COMMAND "_PAN"))
(DEFUN C:Pl  () (COMMAND "PLINE"))
(DEFUN C:PO  () (COMMAND "CHPROP"))
(DEFUN C:PE  () (COMMAND "PEDIT"))
(DEFUN C:N   () (COMMAND "POINT"))
(DEFUN C:NR  () (COMMAND "POINT" "@"))
(DEFUN C:PY  () (COMMAND "POLYGON"))
(DEFUN C:PP  () (COMMAND "PRPLOT"))
(DEFUN C:PG  () (COMMAND "PURGE"))
(DEFUN C:QT  () (COMMAND "QTEXT"))
(DEFUN C:RD  () (COMMAND "REDO"))
(DEFUN C:RE   () (COMMAND "REDRAW"))
(DEFUN C:RG  () (COMMAND "REGEN"))
(DEFUN C:RA  () (COMMAND "REGENAUTO"))
(DEFUN C:RN  () (COMMAND "RENAME"))
(DEFUN C:RM  () (COMMAND "RESUME"))
(DEFUN C:R  () (COMMAND "ROTATE"))
(DEFUN C:Rec () (Command "RECTANG"))
(DEFUN C:RS  () (COMMAND "RSCRIPT"))
(DEFUN C:SC  () (COMMAND "SCALE"))
(DEFUN C:SCR () (COMMAND "SCRIPT"))
(DEFUN C:SE  () (COMMAND "SELECT"))
(DEFUN C:SP  () (COMMAND "SHAPE"))
(DEFUN C:JJ  () (COMMAND "SHELL" ""))
(DEFUN C:SK  () (COMMAND "SKETCH"))
(DEFUN C:SN  () (COMMAND "SNAP"))
(DEFUN C:SD  () (COMMAND "SOLID"))
(DEFUN C:SS  () (COMMAND "STATUS"))
(DEFUN C:S  () (COMMAND "STRETCH"))
(DEFUN C:SY  () (COMMAND "STYLE"))
(DEFUN C:Te   () (COMMAND "TEXT"))
(DEFUN C:TM  () (COMMAND "TIME"))
(DEFUN C:T  () (COMMAND "TRIM"))
(DEFUN C:TC  () (COMMAND "TRIM" "C"))
(DEFUN C:U   () (COMMAND "UNDO"))
(DEFUN C:UN  () (COMMAND "UNITS"))
(DEFUN C:VE   () (COMMAND "VIEW"))
(DEFUN C:VD  () (COMMAND "VIEW" "D"))
(DEFUN C:VR  () (COMMAND "VIEW" "R"))
(DEFUN C:VS  () (COMMAND "VIEW" "S"))
(DEFUN C:VW  () (COMMAND "VIEW" "W"))
(DEFUN C:V?  () (COMMAND "VIEW" "?"))
(DEFUN C:VRS () (COMMAND "VIEWRES"))
(DEFUN C:V  () (COMMAND "VPOINT"))
(DEFUN C:VSD () (COMMAND "VSLIDE"))
(DEFUN C:w  () (COMMAND "wblock"))
(DEFUN C:XH  () (COMMAND "DIM1" "HOR" PAUSE PAUSE PAUSE ""))
(DEFUN C:XV  () (COMMAND "DIM1" "VER" PAUSE PAUSE PAUSE ""))
(DEFUN C:XA  () (COMMAND "DIM1" "AL"  pause pause pause ""))
(DEFUN C:XG  () (COMMAND "DIM1" "ANG" PAUSE pause PAUSE ""))
(DEFUN C:XR  () (COMMAND "DIM1" "RAD" PAUSE pause PAUSE""))
(DEFUN C:XD  () (COMMAND "DIM1" "DIA" PAUSE PAUSE PAUSE ""))
(DEFUN C:XC  () (COMMAND "DIM1" "CON" PAUSE ""))
(DEFUN C:XL  () (COMMAND "DIM1" "LEADER" PAUSE PAUSE "" "" ))
(DEFUN C:XU  () (COMMAND "DIM1" "UPD" PAUSE PAUSE ))
(DEFUN C:XN  () (COMMAND "DIM1" "NEW" (GETINT) PAUSE ))
(DEFUN C:XT  () (COMMAND "DIM1" "TED" PAUSE PAUSE ))
(DEFUN C:XM  () (COMMAND "DIM1" "HOME" PAUSE ))
(DEFUN C:Z  () (COMMAND "_ZOOM" ))
(DEFUN C:ZA  () (COMMAND "_ZOOM" "A"))
(DEFUN C:ZV  () (COMMAND "_ZOOM" "V"))
(DEFUN C:ZC  () (COMMAND "_ZOOM" "C"))
(DEFUN C:Z5  () (COMMAND "_ZOOM" "0.5X"))
(DEFUN C:Zz  () (COMMAND "_ZOOM" "0.5X"))
(DEFUN C:Z2  () (COMMAND "_ZOOM" "2X"))
(DEFUN C:ZD  () (COMMAND "_ZOOM" "D"))
(DEFUN C:ZE  () (COMMAND "_ZOOM" "E"))
(DEFUN C:ZL  () (COMMAND "_ZOOM" "L"))
(DEFUN C:ZX  () (COMMAND "_ZOOM" "P"))
(DEFUN C:ZP  () (COMMAND "_ZOOM" "P"))
(DEFUN C:ZW  () (COMMAND "_ZOOM" "W"))
(DEFUN C:4F  () (COMMAND "OSNAP" "END,INT,PER,mid"))
(defun c:mH  () (command "matchprop")
rem (DEFUN C:xx () (COMMAND "STYLE" "xx" "ROMANS,HZ4" "0" "0.7" "" "" "" ""  ))
rem (DEFUN C:xy () (COMMAND "STYLE" "xy" "ROMANS,HZ4" "0" "0.7" "" "" "" ""  ))
rem (DEFUN C:x () (COMMAND "STYLE" "HZ4" "txt,HZ4" "0" "0.7" "" "" "" ""  ))
rem (DEFUN C:HZ4 () (COMMAND "STYLE" "HZ4" "ROMANS,HZXY" "0" "0.7" "" "" "" ""  ))
(DEFUN C:A3  () (SETVAR "PICKBOX" 3) (COMMAND "APERTURE" 3))
(DEFUN C:A5  () (SETVAR "PICKBOX" 5) (COMMAND "APERTURE" 5))
(defun c:a8  () (SETVAR "PICKBOX" 8) (COMMAND "APERTURE" 8))
(DEFUN C:dda  () (COMMAND "DDATtE"))
(DEFUN C:At  () (COMMAND "ATTEDIT" "" "" "" "" pause "" "v" "r"))
(DEFUN C:ATe  () (COMMAND "ATTEXT"))
(DEFUN C:Att  () (COMMAND "ATTEDIT"))
(DEFUN C:F=  () (COMMAND "FILL" "ON") (COMMAND "REGEN"))
(DEFUN C:F-  () (COMMAND "FILL" "OFF") (COMMAND "REGEN"))
发表于 2003-11-7 14:56:28 | 显示全部楼层
这个太复杂了,而且也是CAD的快捷键
发表于 2003-11-7 15:30:30 | 显示全部楼层
你直接把acad.lsp文件上传大家一下载多好的阿
 楼主| 发表于 2003-11-7 16:36:59 | 显示全部楼层
确实有点复杂,不过只要把你常用的几个放到acad.lsp的最后第二行就好了!!当然,你还有个办法就是你吧这东东另存为一个譬如xx.lsp的文件名,进入cad后用appload命令加载。就可以按照里面的简码输入命令了。再次声明一下,简码可以自己修改的,尤其后面缩放等的几个有后续命令的,现在直接输入一个就好啦。如输入zz,那就是吧图缩小0.5倍观察!!
发表于 2003-11-7 19:17:22 | 显示全部楼层
shyyoo []   你就直接把acad.lsp文件上传大家一下载吧
发表于 2003-11-7 20:20:06 | 显示全部楼层
用于什么版本
发表于 2003-11-7 20:45:39 | 显示全部楼层
怎么用呀
发表于 2003-11-7 21:31:52 | 显示全部楼层
精神可嘉,可惜绕了个大圈。快捷方式 全在acad.pgp文件中,在此中编辑即可。
发表于 2003-11-7 21:33:48 | 显示全部楼层
这个已经上传过多次了
发表于 2003-11-7 22:16:41 | 显示全部楼层
请问楼主它的功用是什么呀?
发表于 2003-11-8 13:10:03 | 显示全部楼层
还是在CAD中改一下吧自己想怎么改就怎么改,看自己喜欢喽
发表于 2003-11-8 13:14:36 | 显示全部楼层
在ACAD。PGP中改来的更快
发表于 2003-11-9 12:37:54 | 显示全部楼层
个人习惯不同,自己编
发表于 2003-11-10 14:50:17 | 显示全部楼层
同上
发表于 2003-11-10 15:27:50 | 显示全部楼层
高手真多,我想编但是心有余而力不足
  学海无涯苦做舟。。。。真的不努力不行了
GMT+8, 2026-11-3 09:24 , Processed in 0.513145 second(s), 61 queries , Gzip On.
