查看: 930|回复: 2
[求助] [求助]:菜鸟加载问题?
发表于 2003-11-14 15:37:51 | 显示全部楼层 |阅读模式
小菜不懂lisp,这样的lisp程序怎样加载(加载到cadr14.lsp,作为一个文件加载)?程序如下:
(defun c:v1()(command "view" "s" "v1"))
(defun c:v2()(command "view" "s" "v2"))
(defun c:v3()(command "view" "s" "v3"))
(defun c:v4()(command "view" "s" "v4"))
(defun c:v5()(command "view" "s" "v5"))
(defun c:v6()(command "view" "s" "v6"))
(defun c:v7()(command "view" "s" "v7"))
(defun c:v8()(command "view" "s" "v8"))
(defun c:v9()(command "view" "s" "v9"))
(defun c:11()(command "view" "r" "v1"))
(defun c:22()(command "view" "r" "v2"))
(defun c:33()(command "view" "r" "v3"))
(defun c:44()(command "view" "r" "v4"))
若修改,请示例,多谢!
发表于 2003-11-15 11:50:46 | 显示全部楼层
是要自动运行吗/
 楼主| 发表于 2003-11-15 14:09:46 | 显示全部楼层
是呀!我自己已解决了,谢谢!
GMT+8, 2026-11-4 02:35 , Processed in 0.414318 second(s), 36 queries , Gzip On.
