查看: 5271|回复: 60
[密技]:人人都会做快捷键!
发表于 2003-11-19 12:01:30 | 显示全部楼层 |阅读模式
此方法适用R14。R2000及天正系列,其它版本的没试过,谁有其它版本的可以一样试试。
先在你所使用的软件安装目录下找出acad.pgp文件,R14的就在R14下找,天正的就在天正下找。
然后用写字版打开,如下:
;  AutoCAD Program Parameters File For AutoCAD Release 14
;  External Command and Command Alias Definitions
;  Copyright (C) 1997 by Autodesk, Inc.
;  Each time you open a new or existing drawing, AutoCAD searches
;  the support path and reads the first acad.pgp file that it finds.
;  While AutoCAD is running, you can invoke other programs or utilities,
;  such Windows system commands, utilities, and applications.
;  You define external commands by specifying a command name to be used
;  from the AutoCAD command prompt and an executable command string
;  that is passed to the operating system.
;  You can abbreviate frequently used AutoCAD commands by defining
;  aliases for them in the command alias section of acad.pgp.
;  You can create a command alias for any AutoCAD command,
;  device driver command, or external command.
;  Recommendation: back up this file before editing it.
;  There is a bonus application for editing command aliases as well as
;  a sample acad.pgp file with many more command aliases.
;  See the bonus\cadtools folder for more details.
;  External command format:
;  <Command name>,[<DOS request>],<Bit flag>,
  • <Prompt>,
    ;  The bits of the bit flag have the following meanings:
    ;  First bit (1): if set, don't wait for the application to finish
    ;  Second bit (2): if set, run the application minimized
    ;  Third bit (4): if set, run the application "hidden"
    ;  Bits 2 and 4 are mutually exclusive; if both are specified only the 2 bit is used.
    ;  The most useful values are likely to be 0 (start the application and wait
    ;  for it to finish), 1 (start the application and don't wait), 3 (minimize and don't
    ;  wait), and 5 (hide and don't wait). Values of 2 and 4 should normally be avoided,
    ;  as they make AutoCAD unavailable until the application has completed.
    ;  Examples of external commands for command windows
    CATALOG,   DIR /W,         0,File specification: ,
    DEL,       DEL,            0,File to delete: ,
    DIR,       DIR,            0,File specification: ,
    EDIT,      START EDIT,     1,File to edit: ,
    SH,        ,               1,*OS Command: ,
    SHELL,     ,               1,*OS Command: ,
    START,     START,          1,*Application to start: ,
    TYPE,      TYPE,           0,File to list: ,
    ; Examples of external commands for Windows
    ; See also the STARTAPP AutoLISP function for an alternative method.
    EXPLORER,  START EXPLORER, 1,,
    NOTEPAD,   START NOTEPAD,  1,*File to edit: ,
    PBRUSH,    START PBRUSH,   1,,
    ; Command alias format:
    ;   <Alias>,*<Full command name>
    ;  The following are guidelines for creating new command aliases.
    ;  1.  Try the first character of the command, then try the first two,
    ;         then the first three.
    ;  2.  Ignore "DD" at the beginning of a command.
    ;  3.  Abbreviate the following prefixes:
    ;        Examples: 3 for 3D, A for ASE, D for Dim, I for Image, R for render.
    ;  4.  Once an alias is defined, add suffixes for related aliases:
    ;        Examples: R for Redraw, RA for Redrawall, L for Line, LT for Linetype.
    ;  5.  An alias should reduce a command by at least two characters.
    ;  6.  Commands with a control key equivalent, status bar button, or function key
    ;        do not require a command alias.
    ;        Examples: Use Control-N, -O, -P, and -S for New, Open, Print, and Save
    ;  7.  Use a hyphen to differentiate between command line and dialog box commands.
    ;  8.  Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
    ;  Sample aliases for AutoCAD commands
    ;  These examples include most frequently used commands.
    3A,        *3DARRAY
    3F,        *3DFACE
    3P,        *3DPOLY
    A,         *ARC
    AA,        *AREA
    AL,        *ALIGN
    AP,        *APPLOAD
    AR,        *ARRAY
    AAD,       *ASEADMIN
    AEX,       *ASEEXPORT
    ALI,       *ASELINKS
    ASQ,       *ASESQLED
    ARO,       *ASEROWS
    ASE,       *ASESELECT
    AT,        *DDATTDEF
    -AT,       *ATTDEF
    ATE,       *DDATTE
    -ATE,      *ATTEDIT
    B,         *BMAKE
    -B,        *BLOCK
    BH,        *BHATCH
    BO,        *BOUNDARY
    -BO,       *-BOUNDARY
    BR,        *BREAK
    C,         *CIRCLE
    CH,        *DDCHPROP
    -CH,       *CHANGE
    CHA,       *CHAMFER
    COL,       *DDCOLOR
    CO,        *COPY
    D,         *DDIM
    DAL,       *DIMALIGNED
    DAN,       *DIMANGULAR
    DBA,       *DIMBASELINE
    DCE,       *DIMCENTER
    DCO,       *DIMCONTINUE
    DDI,       *DIMDIAMETER
    DED,       *DIMEDIT
    DI,        *DIST
    DIV,       *DIVIDE
    DLI,       *DIMLINEAR
    DO,        *DONUT
    DOR,       *DIMORDINATE
    DOV,       *DIMOVERRIDE
    DR,        *DRAWORDER
    DRA,       *DIMRADIUS
    DST,       *DIMSTYLE
    DT,        *DTEXT
    DV,        *DVIEW
    E,         *ERASE
    ED,        *DDEDIT
    EL,        *ELLIPSE
    EX,        *EXTEND
    EXIT,      *QUIT
    EXP,       *EXPORT
    EXT,       *EXTRUDE
    F,         *FILLET
    FI,        *FILTER
    G,         *GROUP
    -G,        *GROUP
    GR,        *DDGRIPS
    H,         *BHATCH
    -H,        *HATCH
    HE,        *HATCHEDIT
    HI,        *HIDE
    I,         *DDINSERT
    -I,        *INSERT
    IAD,       *IMAGEADJUST
    IAT,       *IMAGEATTACH
    ICL,       *IMAGECLIP
    IM,        *IMAGE
    -IM,       *-IMAGE
    IMP,       *IMPORT
    IN,        *INTERSECT
    INF,       *INTERFERE
    IO,        *INSERTOBJ
    L,         *LINE
    LA,        *LAYER
    -LA,       *-LAYER
    LE,        *LEADER
    LEN,       *LENGTHEN
    LI,        *LIST
    LS,        *LIST
    LT,        *LINETYPE
    -LT,       *-LINETYPE
    LTS,       *LTSCALE
    M,         *MOVE
    MA,        *MATCHPROP
    ME,        *MEASURE
    MI,        *MIRROR
    ML,        *MLINE
    MO,        *DDMODIFY
    MS,        *MSPACE
    MT,        *MTEXT
    MV,        *MVIEW
    O,         *OFFSET
    OS,        *DDOSNAP
    -OS,       *-OSNAP
    P,         *PAN
    -P,        *-PAN
    PA,        *PASTESPEC
    PE,        *PEDIT
    PL,        *PLINE
    PO,        *POINT
    POL,       *POLYGON
    PR,        *PREFERENCES
    PRE,       *PREVIEW
    PRINT,     *PLOT
    PS,        *PSPACE
    PU,        *PURGE
    R,         *REDRAW
    RA,        *REDRAWALL
    RE,        *REGEN
    REA,       *REGENALL
    REC,       *RECTANGLE
    REG,       *REGION
    REN,       *DDRENAME
    -REN,      *RENAME
    REV,       *REVOLVE
    RM,        *DDRMODES
    RO,        *ROTATE
    RPR,       *RPREF
    RR,        *RENDER
    S,         *STRETCH
    SC,        *SCALE
    SCR,       *SCRIPT
    SE,        *DDSELECT
    SEC,       *SECTION
    SET,       *SETVAR
    SHA,       *SHADE
    SL,        *SLICE
    SN,        *SNAP
    SO,        *SOLID
    SP,        *SPELL
    SPL,       *SPLINE
    SPE,       *SPLINEDIT
    ST,        *STYLE
    SU,        *SUBTRACT
    T,         *MTEXT
    -T,        *-MTEXT
    TA,        *TABLET
    TH,        *THICKNESS
    TI,        *TILEMODE
    TO,        *TOOLBAR
    TOL,       *TOLERANCE
    TOR,       *TORUS
    TR,        *TRIM
    UC,        *DDUCS
    UCP,       *DDUCSP
    UN,        *DDUNITS
    -UN,       *UNITS
    UNI,       *UNION
    V,         *DDVIEW
    -V,        *VIEW
    VP,        *DDVPOINT
    -VP,       *VPOINT
    W,         *WBLOCK
    WE,        *WEDGE
    X,         *EXPLODE
    XA,        *XATTACH
    XB,        *XBIND
    -XB,       *-XBIND
    XC,        *XCLIP
    XL,        *XLINE
    XR,        *XREF
    -XR,       *-XREF
    Z,         *ZOOM
    ; The following are alternative aliases and aliases as supplied in AutoCAD Release 13.
    AV,        *DSVIEWER
    CP,        *COPY
    DIMALI,    *DIMALIGNED
    DIMANG,    *DIMANGULAR
    DIMBASE,   *DIMBASELINE
    DIMCONT,   *DIMCONTINUE
    DIMDIA,    *DIMDIAMETER
    DIMED,     *DIMEDIT
    DIMTED,    *DIMTEDIT
    DIMLIN,    *DIMLINEAR
    DIMORD,    *DIMORDINATE
    DIMRAD,    *DIMRADIUS
    DIMSTY,    *DIMSTYLE
    DIMOVER,   *DIMOVERRIDE
    LEAD,      *LEADER
    TM,        *TILEMODE
    前面的英文就不管了,看到下面的
    TH,        *THICKNESS
    TI,        *TILEMODE
    TO,        *TOOLBAR
    TOL,       *TOLERANCE
    TOR,       *TORUS
    TR,        *TRIM
    UC,        *DDUCS
    UCP,       *DDUCSP
    UN,        *DDUNITS
    -UN,       *UNITS
    UNI,       *UNION
    V,         *DDVIEW
    -V,        *VIEW
    VP,        *DDVPOINT
    -VP,       *VPOINT
    左边的为快捷键字母,右边快捷键对应的命令
    快捷键可以随意修改增加,
    只要满足设置模式就可以:
    快捷键,   *快捷键对应的命令
    然后保存,再运行软件就可以用你刚设的快捷键了 。
    注意:不要把快捷键设置重复了,注意检查,不然软件系统可能不
    认你所设的快捷键。
    为了更好说明问题,我帖上照片。
  • 论坛插件加载方法
    发表于 2003-11-19 14:27:20 | 显示全部楼层
    能不能一台机子上设置两三套快捷键,谁用谁调自己的出来?
    发表于 2003-11-19 14:43:37 | 显示全部楼层
    可以的吧
    发表于 2003-11-19 14:58:26 | 显示全部楼层
    有什么方法指教一下
    发表于 2003-11-19 15:11:56 | 显示全部楼层
    最初由 zhiyongfan 发布
    [B]能不能一台机子上设置两三套快捷键,谁用谁调自己的出来? [/B]
    多定义几个acad.pgp文件,想用哪个就把它拷到cad或天正的sys目录下
    发表于 2003-11-20 12:49:37 | 显示全部楼层
    做快捷键好麻烦
    发表于 2003-11-20 18:02:18 | 显示全部楼层
    也可以根据上面格式添加新的命令和快捷键
    发表于 2003-11-20 19:28:26 | 显示全部楼层
    应该是一劳永逸
    发表于 2003-11-21 12:07:13 | 显示全部楼层
    天正3中的快捷命令怎么定义(例如:绘制强体)
    发表于 2003-11-21 18:24:56 | 显示全部楼层
    请教在acad。pgp里怎样设置join(l连接线段)的快捷键?
    发表于 2003-11-21 19:57:11 | 显示全部楼层
    我看不懂啊高手,能教教我吗????
    发表于 2003-11-22 21:08:48 | 显示全部楼层
    好东东,不过标明中文就更好了
    发表于 2003-11-22 21:57:36 | 显示全部楼层
    好象在天正里修改不能用
     楼主| 发表于 2003-11-26 09:30:14 | 显示全部楼层
    12楼楼主说:   9pt 10pt 11pt 12pt 13pt 15pt
    jion是编辑多意线下面的子命令,先把辑多意线的命令调出来,下面就有jion的命令了.
    13楼楼主说:   9pt 10pt 11pt 12pt 13pt 15pt
    我看不懂啊高手,能教教我吗????
    就是查找出acad.pgp文件,你用的是天正就在天正安装目录下,是R14就在R14安装目录下找.
    然后打开它,一直拉到底,然后就是:
    快捷键可以随意修改增加,
    只要满足设置模式就可以:
    快捷键, *快捷键对应的命令
    只要快捷键没有重复就行.
    11楼楼主说:   9pt 10pt 11pt 12pt 13pt 15pt
    一样拉,只要对应的命令是正确的,ACAD.PGP文件也是对应的就行
    15楼楼主说:   9pt 10pt 11pt 12pt 13pt 15pt
    好象在天正里修改不能用
    你修改的不是天正目录下的ACAD.PGP吧,R14目录下也有ACAD.PGPG,如果你是修改的是R14目录下的,当然天正的就调不出来拉.
    发表于 2003-11-26 09:44:31 | 显示全部楼层
    ET工具中有个连接线段的命令:pljoin
    教学中心有演示,可以先选择了要连接的线段,再执行pljoin命令,相比pedit要简便很多
    刚好acad原来的命令别名里“J”是没有用的,用来做这个命令的别名正好
    动画演示的地址是:
    http://www.xdcad.net/techcenter/ ... &articleid=1318
    GMT+8, 2026-11-6 19:49 , Processed in 0.564892 second(s), 61 queries , Gzip On.
