查看: 926|回复: 2
[求助] [求助]:有什么办法才能让标注四舍五入??帮帮忙吧!
发表于 2003-11-28 14:43:37 | 显示全部楼层 |阅读模式
新手上路,请教大家:怎么标出来得数字这么难看的,有什么办法才能让标注四舍五入??帮帮忙吧!
defun c:db ()
(setq a (getreal "边长="))
(setq p0 (getpoint "enter start point:"))
(setq x0 (car p0) y0 (cadr p0))
(setq p1 (list (+ x0 a)  y0 ))
(setq p2 (list (+ x0 (/ a 2)) (+ y0 a)))
(command "line" p0 p1 p2 P0 "")
(setq d (distance p0 p1))
(setq x (list (+ (car p0) 800) (cadr p0)
(command "dim" "al" p0 p1 x d "")
(setq d (distance p2 p1))
(command "dim" "al" p2 p1 x d "")
(setq d (distance p2 p0))
(command "dim" "al" p2 p0 x d "" "exit"
发表于 2003-11-30 22:58:25 | 显示全部楼层
問題出在這
(command "dim" "al" p0 p1 x d "")  ->(command "dim" "al" p0 p1 x "")
去掉d  ,有d 成為"輸入標註文字",因精度的關係,會顯示原值
其餘類同
发表于 2003-12-23 14:12:54 | 显示全部楼层
先定义精度系统变量LUPREC再求值,最后恢复系统变量
GMT+8, 2026-11-4 03:02 , Processed in 0.806960 second(s), 37 queries , Gzip On.
