查看: 2664|回复: 9
[求助]:为什么我在.mns文件里添加的菜单在重新加载后却无法显示?
发表于 2002-8-30 11:01:13 | 显示全部楼层 |阅读模式
哪位老兄帮我看一看有什么问题?还有 .mns  .mnu  .mnc  .mnl  .mnr这几个后缀的菜单文件有什么区别吗?我改的是 .mns  和 .mnu文件。谢谢。(ROOM文件和FDM.mns文件内容一致)
//      AutoCAD menu file - C:\Fdm2000\System\FDM.mns
***MENUGROUP=ROOM
***BUTTONS1
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,5),GRIP_),$P0=ACAD.GRIPS $P0=*);
$P0=SNAP $p0=*
^C^C
^B
^O
^G
^D
^E
^T
***BUTTONS2
$P0=SNAP $p0=*
***AUX1
$P0=SNAP $p0=*
^C^C
^B
^O
^G
^D
^E
^T
***AUX2
$P0=SNAP $p0=*
$P0=SNAP $p0=*
***AUX3
$P0=SNAP $p0=*
***AUX4
$P0=SNAP $p0=*
***POP0
**SNAP
               [&Object Snap Cursor Menu]
ID_Tracking    [Temporary trac&k point]_tt
ID_From        [&From]_from
ID_MnPointFi   [->Poin&t Filters]
ID_PointFilx     [.X].X
ID_PointFily     [.Y].Y
ID_PointFilz     [.Z].Z
ID_PointFixy     [.XY].XY
ID_PointFixz     [.XZ].XZ
ID_PointFiyz     [<-.YZ].YZ
ID_OsnapEndp   [&Endpoint]_endp
ID_OsnapMidp   [&Midpoint]_mid
ID_OsnapInte   [&Intersection]_int
ID_OsnapAppa   [&Apparent Intersect]_appint
ID_OsnapExte   [E&xtension]_ext
ID_OsnapCent   [&Center]_cen
ID_OsnapQuad   [&Quadrant]_qua
ID_OsnapTang   [Tan&gent]_tan
ID_OsnapPerp   [&Perpendicular]_per
ID_OsnapPara   [Para&llel]_par
ID_OsnapNode   [No&de]_nod
ID_OsnapInse   [In&sert]_ins
ID_OsnapNear   [Nea&rest]_nea
ID_OsnapNone   [&None]_non
ID_Osnap       [&Osnap Settings...]'_+dsettings 2
               [计算器]'cal
               [测距离]'dist
***POP1
               [文件]
ID______3      [新建...]^C^C_new
ID______4      [打开...]^C^C_open
ID______5      [关闭...]^C^C_close
ID______6      [存盘...]^C^C_qsave
ID__________0  [赋名存盘...]^C^C_saveas
ID______7      [修复...]^C^C_recover
ID______________0 [圆方出图助手]^C^CPlotWizard
ID______________1 [回到工作视图]^C^CSavePlotView
ID__________________0 [家具立体尺寸标注]^C^C_wholedim
ID____________________0 [尺寸文字单视窗显示]^C^COneVpShow
ID______8      [出图...]^C^CCMDDIA;1;_plot
               [->输入/输出]
ID_3DS______0    [3DS 输入...]^C^C_3dsin
ID_DXF______0    [DXF 输入...]^C^C_dxfin
ID_DXB______0    [DXB 输入...]^C^C_dxbin
ID_IGES______0   [IGES 输入...]^C^C_igesin
ID_PostScript______0   [PostScript 输入...]^C^Cpsin
ID_3DMAX_VIZ______________0   [3DMAX(VIZ)转换文件输出...]^C^Cexport3dm
ID_3DS______1    [3DS 输出...]^C^C_3dsout
ID_DXF______1    [DXF 输出...]^C^C_dxfout
ID_IGES______1   [IGES 输出...]^C^C_igesout
ID_PostScript______1   [<-PostScript 输出...]^C^Cpsout
               [->外部引用]
ID______9        [附加...]^C^C_xref;_attach;~
ID______10       [分离]^C^C_xref;_detach
ID______11       [更新]^C^C_xref;_reload
ID______12       [列表]^C^C_xref;?;*;
ID__________1    [<-更改路径]^C^C_xref;_path
ID______13     [配置]^C^C_config
ID__________2  [应用程序...]^C^Cappload
ID_MRU         [绘图历史(&R)]
ID______14     [退出]^C^C_quit
***POP2
**EDIT
ID_MnEdit      [&Edit]
ID_U           [&Undo        Ctrl+Z]_u
ID_Redo        [&Redo        Ctrl+Y]^C^C_redo
ID_Cutclip     [Cu&t        Ctrl+X]^C^C_cutclip
ID_Copyclip    [&Copy        Ctrl+C]^C^C_copyclip
ID_Copybase    [Copy with &Base Point]^C^C_copybase
ID_Copylink    [Copy &Link]^C^C_copylink
ID_Pasteclip   [&Paste        Ctrl+V]^C^C_pasteclip
ID_Pastebloc   [Paste as Bloc&k]^C^C_pasteblock
ID_Pastehlnk   [Paste as &Hyperlink]^C^C_pasteashyperlink
ID_Pasteorig   [Paste to Original Coor&dinates]^C^C_pasteorig
ID_Pastesp     [Paste &Special...]^C^C_pastespec
ID_Erase       [Cle&ar        Del]^C^C_erase
ID_SelAll      [Se&lect All        Ctrl+A]^C^C_ai_selall
ID_Links       [&OLE Links...]^C^C_olelinks
ID_TextFind    [&Find...]^C^C_find
***POP3
               [绘图]
               [->直线]
                 [数段]^C^Cc_line
                 [<-1 段]^C^Cc_line;\\;
               [弧]^C^Carc
               [圆]^C^Cc_circle
               [三维面]^C^C3dface
               [复合线]^C^C_pline
               [三维复合线]^C^C3dpoly
               [圆环]^C^C_donut
               [->椭圆]
                 [轴,偏心率]^C^C_ellipse;
                 [<-心,轴,轴]^C^C_ellipse;_c;
               [->多边形]
                 [边长]^C^C_polygon;\_e;
                 [外切]^C^C_polygon;\\_c;
                 [<-内接]^C^C_polygon;\\_i;
               [四边形]^C^Crectang
               [插入...]^C^Cddinsert
               [->三维自建]
                 [->建立]
                   [拉伸]^C^Cextrude
                   [旋转]^C^Crevolve
                   [<-三维物体...]$I=room.image_3dobjects $I=room.*
                 [倒角]^C^Cchamfer
                 [倒圆]^C^Cfillet
                 [设置网格密度]^C^Cfacetres
                 [->操作]
                   [合并]^C^Cunion
                   [相减]^C^Csubtract
                   [<-<-相交]^C^Cintersect
               [填充...]^C^Cbhatch
               [图片...]^C^Cimage
               [->三维表面]
                 [边界表面]^C^C$S=X $S=3D _edgesurf
                 [直纹表面]^C^C$S=X $S=3D _rulesurf
                 [旋转表面]^C^C$S=X $S=3D _revsurf
                 [延伸表面]^C^C$S=X $S=3D _tabsurf
                 [设置M方向密度]^C^Csurftab1
                 [<-设置N方向密度]^C^Csurftab2
               [->文字]
                 [动态文字]^C^C_dtext
                 [设定字型...]^C^Cstyle
                 [->属性]
                   [定义...]^C^Cddattdef
                   [编辑...]^C^C_ddatte
                   [<-<-提取...]^C^Cddattext
               [->尺寸标注]
                 [房间面积]^C^Cc_roomarea;
                 [隐藏标注]^C^Clayer f dim ;
                 [显示标注]^C^Clayer t dim ;
                 [圆点方式]^C^Cdim1 restore dot-base
                 [斜线方式]^C^Cdim1 restore cut-base
                 [->基本尺寸标注]
                   [设置...]^C^Cddim
                   [->长度]
                     [水平]^C^C_dimlinear
                     [垂直]^C^C_dimlinear
                     [对齐]^C^C_dimaligned
                     [旋转]^C^C_dim1 _rotated
                     [基线标注]^C^C_dimbaseline
                     [<-连续标注]^C^C_dimcontinue
                   [->圆弧]
                     [直径标注]^C^C_dimdiameter
                     [半径标注]^C^C_dimradius
                     [<-中心记号]^C^C_dimcenter
                   [->座标标注]
                     [自动]^C^C_dimordinate
                     [X-标注]^C^C_dim1 $S=X $S=dimord _ordinate;\_x
                     [<-Y-标注]^C^C_dim1 $S=X $S=dimord _ordinate;\_y
                   [角度标注]^C^C_dimangular
                   [<-<-引线]^C^C_leader
***POP4
               [编辑]
               [图元编辑...]^C^Cddmodify
               [删除]^C^Cc_erase
               [->断开]
                 [选物体, 第 2点]^C^C$S=X $S=break0 break
                 [选物体, 定 2点]^C^C$S=X $S=break0 break;\_f;
                 [<-在 拾取位置 上]^C^C$S=X $S=break0 break;\@;
               [延伸]^C^Cc_extend
               [修剪]^C^Cc_trim
               [围栏修剪]^C^CFenceTrim
               [镜象]^C^Cc_mirror
               [等距线]^C^Cc_offset
               [倒圆]^C^Cfillet
               [切角]^C^Cchamfer
               [移动]^C^Cc_move
               [旋转]^C^Cc_rotate
               [改大小]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale)
               [伸展]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_stretch,^C^Cc_stretch)
               [->修改]
                 [点位]^C^C_change
                 [<-性质]^C^Cddchprop
               [打散]^C^C_explode
               [复合线编辑]^C^Cpedit
               [设置曲面平滑类型...]$I=poly $I=*
               [->编辑  标注]
                 [->标注文字]
                   [更改文字]^C^C_dim1 $S=X $S=dimed _newtext
                   [文字归位]^C^C_dim1 $S=X $S=dimed _hometext
                   [移动文字]^C^C_dim1 $S=X $S=tedit0 _tedit
                   [<-旋转文字]^C^C_dim1 $S=X $S=dimed _trotate
                 [斜尺寸界线]^C^C_dim1 $S=X $S=dimed _oblique
                 [<-标注更新]^C^C_dim1 $S=X $S=dimed _update
***POP5
**VIEW
ID_MnView      [&View]
ID_Redrawall   [&Redraw]'_redrawall
ID_Regen       [Re&gen]^C^C_regen
ID_Regenall    [Regen &All]^C^C_regenall
ID_MnZoom      [->&Zoom]
ID_ZoomRealt     [&Realtime]'_zoom ;
ID_ZoomPrevi     [&Previous]'_zoom _p
ID_ZoomWindo     [&Window]'_zoom _w
ID_ZoomDynam     [&Dynamic]'_zoom _d
ID_ZoomScale     [&Scale]'_zoom _s
ID_ZoomCente     [&Center]'_zoom _c
ID_ZoomIn        [&In]'_zoom 2x
ID_ZoomOut       [&Out]'_zoom .5x
ID_ZoomAll       [&All]'_zoom _all
ID_ZoomExten     [<-&Extents]'_zoom _e
ID_MnPan       [->&Pan]
ID_Pan           [Real&time]'_pan
ID_PanPick       [&Point]'_-pan
ID_PanLeft       [&Left]^P'_-pan (trans (list (* -0.2 (getvar "viewsize")) 0) 0 1) ;^P
ID_PanRight      [&Right]^P'_-pan (trans (list (* 0.2 (getvar "viewsize")) 0) 0 1) ;^P
ID_PanUp         [&Up]^P'_-pan (trans (list 0 (* 0.2 (getvar "viewsize"))) 0 1) ;^P
ID_PanDown       [<-&Down]^P'_-pan (trans (list 0 (* -0.2 (getvar "viewsize"))) 0 1) ;^P
ID_Dsviewer    [Aerial Vie&w]'_dsviewer
ID_MnTiledVi   [->&Viewports]
ID_Ai_tiledv     [&Named Viewports...]^C^C_+vports 1
ID_VportsSav     [N&ew Viewports...]^C^C_+vports 0
ID_VportsSin     [&1 Viewport]^C^C$M=$(if,$(eq,$(getvar,tilemode),1),^C^C_-vports _si,^C^C_-vports)
ID_Vports2       [&2 Viewports]^C^C_-vports _2
ID_Vports3       [&3 Viewports]^C^C_-vports _3
ID_Vports4       [&4 Viewports]^C^C_-vports _4
ID_VportsRes     [$(if,$(eq,$(getvar,tilemode),1),~)&Polygonal Viewport]^C^C_-vports _p
ID_VportsDel     [$(if,$(eq,$(getvar,tilemode),1),~)&Object]^C^C_-vports _o
ID_VportsJoi     [<-$(if,$(eq,$(getvar,tilemode),0),~)&Join]^C^C_-vports _j
ID_Ddview      [&Named Views...]^C^C_view
ID_MnViewpoi   [->$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)&3D Views]
ID_Ddvpoint      [V&iewpoint Presets...]^C^C_ddvpoint
ID_VpointTri     [&Viewpoint]^C^C_vpoint ;
ID_MnPlanView    [->&Plan View]
ID_PlanCurre       [&Current UCS]^C^C_plan ;
ID_PlanWorld       [&World UCS]^C^C_plan _w
ID_PlanUCS         [<-&Named UCS]^C^C_plan _u
ID_VpointTop     [&Top]^C^C_-view _top
ID_VpointBot     [&Bottom]^C^C_-view _bottom
ID_VpointLef     [&Left]^C^C_-view _left
ID_VpointRig     [&Right]^C^C_-view _right
ID_VpointFro     [&Front]^C^C_-view _front
ID_VpointBac     [Bac&k ]^C^C_-view _back
ID_VpointSW      [&SW Isometric]^C^C_-view _swiso
ID_VpointSE      [S&E Isometric]^C^C_-view _seiso
ID_VpointNE      [&NE Isometric]^C^C_-view _neiso
ID_VpointNW      [<-N&W Isometric]^C^C_-view _nwiso
ID_3dorbit     [$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)3D Or&bit]'_3dorbit
ID_Hide        [&Hide]^C^C_hide
ID_MnPersShad  [->$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)&Shade]
ID_2doptim       [&2D
Wireframe]$M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),^C^C_shademode,^C^C_shade
mode _2)
ID_Wireframe     [&3D
mode _3)
ID_Hidden
[&Hidden]$M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),^C^C_shademode,^C^C_shadem
ode _h)
ID_Flat          [&Flat
Shaded]$M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),^C^C_shademode,^C^C_shademod
e _f)
ID_Gouraud       [&Gouraud
e _g)
ID_FlatEdges     [Fla&t Shaded, Edges
On]$M=$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),^C^C_shademode,^C^C_shademode
_l)
ID_GourEdges     [<-Gouraud &Shaded, Edges
_o)
ID_MnRender    [->$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)R&ender]
ID_Render        [&Render...]^C^C_render
ID_Scene         [&Scene...]^C^C_scene
ID_Light         [&Light...]^C^C_light
ID_Rmat          [&Materials...]^C^C_rmat
ID_Matlib        [Materials Librar&y...]^C^C_matlib
ID_Setuv         [M&apping...]^C^C_setuv
ID_Backgroun     [&Background...]^C^C_background
ID_Fog           [&Fog...]^C^C_fog
ID_Lsnew         [Landscape &New...]^C^C_lsnew
ID_Lsedit        [Landscape &Edit...]^C^C_lsedit
ID_Lslib         [Lands&cape Library...]^C^C_lslib
ID_Rpref         [&Preferences...]^C^C_rpref
ID_Stats         [<-S&tatistics...]^C^C_stats
ID_MnDisplay   [->Disp&lay]
ID_MnUCSicon     [->&UCS Icon]
ID_UcsiconOn
[$(if,$(and,$(getvar,ucsicon),1),!.)&On]$M=$(if,$(and,$(getvar,ucsicon),1),^C^C_ucsicon
_off,^C^C_ucsicon _on)
ID_UcsiconOr
[$(if,$(and,$(getvar,ucsicon),2),!.)O&rigin]$M=$(if,$(and,$(getvar,ucsicon),2),^C^C_ucsicon
_no,^C^C_ucsicon _or)
ID_UcsiconPr       [<-&Properties...]^C^C_ucsicon _p
ID_MnAttribu     [->&Attribute Display]
ID_AttdispNo       [$(if,$(eq,$(getvar,attmode),1),!.)&Normal]'_attdisp _n
ID_AttdispOn       [$(if,$(eq,$(getvar,attmode),2),!.)&On]'_attdisp _on
ID_AttdispOf       [<-$(if,$(eq,$(getvar,attmode),0),!.)O&ff]'_attdisp _off
ID_Textscr       [<-&Text Window        F2]'_textscr
ID_Toolbar     [T&oolbars...]^C^C_toolbar
***POP6
**INSERT
ID_MnInsert    [&Insert]
ID_Ddinsert    [&Block...]^C^C_insert
ID_Xattach     [E&xternal Reference...]^C^C_xattach
ID_Imageatta   [Raster &Image...]^C^C_imageattach
ID_MnLayout    [->&Layout]
ID_NewLayout     [&New Layout]^C^C_layout _new
ID_TmplLayou     [Layout from &Template...]^C^C_layout _template
ID_LayoutWiz     [<-Layout &Wizard]^C^C_layoutwizard
ID_3dsin       [&3D Studio...]^C^C_3dsin
ID_Acisin      [&ACIS File...]^C^C_acisin
ID_Dxbin       [Drawing &Exchange Binary...]^C^C_dxbin
ID_Wmfin       [&Windows Metafile...]^C^C_wmfin
ID_Insertobj   [&OLE Object...]^C^C_insertobj
ID_MARKUP      [Mark&up...]^C^C_rmlin
ID_Xref        [X&ref Manager...]^C^C_xref
ID_Image       [I&mage Manager...]^C^C_image
ID_Hyperlink   [&Hyperlink...        Ctrl+K]^C^C_hyperlink
***POP7
**FORMAT
ID_MnFormat    [F&ormat]
ID_Layer       [&Layer...]'_layer
ID_Ddcolor     [&Color...]'_color
ID_Linetype    [Li&netype...]'_linetype
ID_Linewt      [Line&weight...]'_lweight
ID_Style       [Text &Style...]'_style
ID_Ddim        [&Dimension Style...]'_dimstyle
ID_PlotStyle   [$(if,$(eq,$(getvar,pstylemode),1),~,)Plot St&yle...]^C^C_plotstyle
ID_Ddptype     [&Point Style...]'_ddptype
ID_Mlstyle     [&Multiline Style...]^C^C_mlstyle
ID_Units       [&Units...]'_units
ID_Thickness   [&Thickness]'_thickness
ID_Limits      [Dr&awing Limits]'_limits
ID_Ddrename    [&Rename...]^C^C_rename
***POP8
**TOOLS
ID_MnTools     [&Tools]
ID_Today       [&Today]^C^C_Today
ID_PointA      [&Autodesk Point A]^C^C_^C^C_browser http://pointa.autodesk.com
ID_MeetNow     [&Meet Now]^C^C_MeetNow
ID_MnCadStd    [->CAD &Standards]
ID_Standards     [&Configure...]^C^C_standards
ID_CheckStan     [Chec&k...]^C^C_checkstandards
ID_LayTrans      [<-&Layer Translator...]^C^C_laytrans
ID_Spell       [Sp&elling]'_spell
ID_Qselect     [Quic&k Select...]^C^C_qselect
ID_MnOrder     [->Display &Order]
ID_DrawordeF     [Bring to &Front]^C^C^P(ai_draworder "_f") ^P
ID_DrawordeB     [Send to &Back]^C^C^P(ai_draworder "_b") ^P
ID_DrawordeA     [Bring &Above Object]^C^C^P(ai_draworder "_a") ^P
ID_DrawordeU     [<-Send &Under Object]^C^C^P(ai_draworder "_u") ^P
ID_Inquiry     [->In&quiry]
ID_Dist          [&Distance]'_dist
ID_Area          [&Area]^C^C_area
ID_Massprop      [Region/&Mass Properties]^C^C_massprop
ID_List          [&List]^C^C_list
ID_Id            [&ID Point]'_id
ID_Time          [&Time]'_time
ID_Status        [&Status]'_status
ID_Setvar        [<-Set &Variable]'_setvar
ID_EAttExt     [Attribute E&xtraction...]^C^C_eattext
ID_Modify      [$(if,$(and,$(getvar,opmstate),1),!.)Propert&ies
Ctrl+1]$M=$(if,$(and,$(getvar,opmstate),1),^C^C_propertiesclose,^C^C_properties)
ID_Content     [$(if,$(and,$(getvar,adcstate),1),!.)AutoCAD Desi&gnCenter
Ctrl+2]$M=$(if,$(and,$(getvar,adcstate),1),'_adcclose,'_adcenter)
ID_dbConnect   [$(if,$(and,$(getvar,dbcstate),1),!.)&dbConnect
Ctrl+6]$M=$(if,$(and,$(getvar,dbcstate),1),^C^C_dbcClose,^C^C_dbConnect)
ID_Appload     [&Load Application...]^C^C_appload
ID_Script      [&Run Script...]'_script
ID_VBAMacro    [->M&acro]
ID_VBARun        [&Macros...        Alt+F8]^C^C_vbarun
ID_VBALoad       [&Load Project...]^C^C_vbaload
ID_VBAMan        [&VBA Manager...]^C^C_vbaman
ID_VBAIDE        [<-Visual &Basic Editor         Alt+F11]^C^C_vbaide
ID_AutoLisp    [->AutoLI&SP]
ID_AULPLoad      [&Load...]^C^C_appload
ID_AULPIDE       [<-&Visual LISP Editor]^C^C_vlide
ID_MnImage     [->Displa&y Image]
ID_Replay        [&View...]^C^C_replay
ID_Saveimg       [<-&Save...]^C^C_saveimg
ID_Dducs       [Named &UCS...]^C^C_+ucsman 0
ID_UcsOrtho    [->Ort&hographic UCS]
ID_Dducsp        [&Preset...]^C^C_+ucsman 1
ID_UcsTop        [&Top]^C^C_ucs _g _t
ID_UcsBottom     [&Bottom]^C^C_ucs _g _b
ID_UcsLeft       [&Left]^C^C_ucs _g _l
ID_UcsRight      [&Right]^C^C_ucs _g _r
ID_UcsFront      [&Front]^C^C_ucs _g _f
ID_UcsBack       [<-Bac&k]^C^C_ucs _g _ba
ID_UcsMove     [Mo&ve UCS]^C^C_ucs _move
ID_MnUCS       [->Ne&w UCS]
ID_UcsWorld      [&World]^C^C_ucs _w
ID_UcsObject     [&Object]^C^C_ucs _ob
ID_UcsFace       [&Face]^C^C_ucs _fa
ID_UcsView       [&View]^C^C_ucs _v
ID_UcsOrigin     [Origi&n]^C^C_ucs _o
ID_UcsZAxVec     [Z &Axis Vector]^C^C_ucs _zaxis
ID_Ucs3point     [&3 Point]^C^C_ucs _3
ID_UcsXAxRot     [&X]^C^C_ucs _x
ID_UcsYAxRot     [&Y]^C^C_ucs _y
ID_UcsZAxRot     [&Z]^C^C_ucs _z
ID_UcsApply      [<-A&pply]^C^C_ucs _apply
ID_Wizard      [->Wi&zards]
ID_Publish       [Publish to &Web...]^C^C_publishtoweb
ID_AddPlotter    [Add &Plotter...]^C^C^P(if(startapp "addplwiz.exe")(princ)) ^P
ID_AddPlStyle    [Add Plot &Style Table....]^C^C^P(if(startapp "styshwiz.exe")(princ)) ^P
ID_PenSetting    [$(if,$(eq,$(getvar,pstylemode),1),Add Color-&Dependent Plot Style Table...,Add
&Named Plot Style Table...)]^C^C_r14penwizard
ID_CreateLayout   [&Create Layout...]^C^C_layoutwizard
ID_ImpPlotSet    [<-&Import Plot Settings...]^C^C_pcinwizard
ID_Ddrmodes    [Dra&fting Settings...]'_dsettings
ID_MnTablet    [->Ta&blet]
ID_TabletOn      [$(if,$(getvar,tabmode),!.)&On]^C^C_tablet _on
ID_TabletOff     [$(if,$(eq,$(getvar,tabmode),0),!.)O&ff]^C^C_tablet _off
ID_TabletCal     [&Calibrate]^C^C_tablet _cal
ID_TabletCfg     [<-Co&nfigure]^C^C_tablet _cfg
ID_Customize   [->&Customize]
ID_Menuload      [&Menus...]^C^C_menuload
ID_CToolbar      [&Toolbars...]^C^C_+customize 1
ID_CKeyboard     [<-&Keyboard...]^C^C_+customize 3
ID_Preferenc   [Optio&ns...]^C^C_options
***POP9
**MODIFY
ID_MnModify    [&Modify]
ID_Ai_propch   [&Properties]^C^C_properties
ID_Matchprop   [&Match Properties]'_matchprop
ID_MnObject    [->&Object]
ID_MnExterna     [->&External Reference]
ID_Xbind           [&Bind...]^C^C_xbind
ID_Xclipfram
[<-$(if,$(eq,$(getvar,xclipframe),1),!.)&Frame]$M=$(if,$(eq,$(getvar,xclipframe),1),^C^C_xclipframe
0,^C^C_xclipframe 1)
ID_MnImage       [->&Image]
ID_Imageadju       [&Adjust...]^C^C_imageadjust
ID_Imagequal       [&Quality]^C^C_imagequality
ID_Transpare       [&Transparency]^C^C_transparency
ID_Imagefram       [<-&Frame]^C^C_imageframe
ID_Hatchedit     [&Hatch...]^C^C_hatchedit
ID_Pedit         [&Polyline]^C^C_pedit
ID_Splinedit     [&Spline]^C^C_splinedit
ID_Mledit        [&Multiline...]^C^C_mledit
ID_MnAttribu     [->&Attribute]
ID_EAttEdit        [&Single...]^C^C_eattedit
ID_AtteditGlo      [&Global]^C^C_-attedit
ID_BattMan         [<-&Block Attribute Manager...]^C^C_battman
ID_Blockdsc      [&Block Description...]^C^C_block
ID_MnText        [->&Text]
ID_Ddedit          [&Edit...]^C^C_ddedit
ID_Scaletext       [&Scale]^C^C_scaletext
ID_Justifyte       [<-<-&Justify]^C^C_justifytext
ID_Clip        [->&Clip]
ID_ImageClip     [&Image]^C^C_imageclip
ID_XrefClip      [&Xref]^C^C_xclip
ID_VportClip     [<-&Viewport]^C^C_vpclip
ID_Refedit     [->In-place Xref and &Block Edit]
ID_RefEditor     [&Edit Reference]^C^C_refedit;
ID_RefAdd        [$(if,$(eq,$(getvar,refeditname),""),~,)&Add to Working
set]$M=$(if,$(eq,$(getvar,refeditname),""),^C^C^P(ai_refedit_alert);^P,$(if,$(and,$(=,$(getvar,tilemod
e),0),$(=,$(getvar,cvport),1)),^C^C_refset;,^C^C_refset _add;))^Z
ID_RefRemove     [$(if,$(eq,$(getvar,refeditname),""),~,)&Remove from Working
e),0),$(=,$(getvar,cvport),1)),^C^C_refset;,^C^C_refset _rem;))^Z
ID_RefSave       [$(if,$(eq,$(getvar,refeditname),""),~,)&Save Reference
Edits]$M=$(if,$(eq,$(getvar,refeditname),""),^C^C^P(ai_refedit_alert)^P,^C^C_refclose _sav)
ID_RefDscrd      [<-$(if,$(eq,$(getvar,refeditname),""),~,)&Discard Reference
Edits]$M=$(if,$(eq,$(getvar,refeditname),""),^C^C^P(ai_refedit_alert)^P,^C^C_refclose _disc)
ID_Erase       [&Erase]^C^C_erase
ID_Copy        [Cop&y]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
ID_Mirror      [M&irror]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror)
ID_Offset      [Off&set]^C^C_offset
ID_Array       [&Array...]^C^C_array
ID_Move        [Mo&ve]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move)
ID_Rotate      [&Rotate]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_rotate,^C^C_rotate)
ID_Scale       [Sca&le]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale)
ID_Stretch     [Stretc&h]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_stretch,^C^C_stretch)
ID_Lengthen    [Len&gthen]^C^C_lengthen
ID_Trim        [&Trim]^C^C_trim
ID_Extend      [Exten&d]^C^C_extend
ID_Break       [Brea&k]^C^C_break
ID_Chamfer     [&Chamfer]^C^C_chamfer
ID_Fillet      [&Fillet]^C^C_fillet
ID_Mn3dopera   [->&3D Operation]
ID_3darray       [&3D Array]^C^C_3darray
ID_Mirror3d      [&Mirror 3D]^C^C_mirror3d
ID_Rotate3d      [&Rotate 3D]^C^C_rotate3d
ID_Align         [<-A&lign]^C^C_align
ID_SolidsEdi   [->Solids Editi&ng]
ID_Union         [&Union]^C^C_union
ID_Subtract      [&Subtract]^C^C_subtract
ID_Intersect     [&Intersect]^C^C_intersect
ID_FaceExtru     [&Extrude faces]^C^C_solidedit _face _extrude
ID_FaceMove      [&Move faces]^C^C_solidedit _face _move
ID_FaceOffse     [&Offset faces]^C^C_solidedit _face _offset
ID_FaceDel       [&Delete faces]^C^C_solidedit _face _delete
ID_FaceRotat     [Rot&ate faces]^C^C_solidedit _face _rotate
ID_FaceTaper     [&Taper faces]^C^C_solidedit _face _taper
ID_FaceColor     [&Color faces]^C^C_solidedit _face _color
ID_FaceCopy      [Copy &faces]^C^C_solidedit _face _copy
ID_EdgeColor     [Co&lor edges]^C^C_solidedit _edge _color
ID_EdgeCopy      [Copy ed&ges]^C^C_solidedit _edge _copy
ID_Imprint       [&Imprint]^C^C_solidedit _body _imprint
ID_BodyCln       [Clea&n]^C^C_solidedit _body _clean
ID_Separate      [&Separate]^C^C_solidedit _body _separate
ID_Shell         [S&hell]^C^C_solidedit _body _shell
ID_BodyChk       [<-Chec&k]^C^C_solidedit _body _check
ID_Explode     [E&xplode]^C^C_explode
***POP10
ID_MnFoldScreen [屏风]
               [屏风设计]^C^CFoldScr2
               [款式及其数据管理]^C^CFsStyleno
               [->多单元设计(框架式)装配]
                 [T形连接]^C^CFsFix
                 [<-十字连接]^C^CCross_FsFix
               [->单个单元设计(柱式)装配]
                 [直线连接]^C^CLine_FixFs2
                 [无柱直线连接]^C^CLineFix_NoClm
                 [L连接]^C^CL_FixFs2
                 [非90度L连接]^C^CLnot90_Fs2
                 [T连接]^C^CT_FixFs2
                 [星形连接]^C^CStar_FixFs2
                 [十字连接]^C^CCross_FixFs2
                 [<-加端柱]^C^CAddEndColoum
               [柱式屏风连接柱定义]^C^CFsColoumDef
               [柱式屏风连接柱管理]^C^CFsStyCol
               [屏风桌板]^C^CFsDeskBdFix
               [平面转立体]^C^CProduct2dto3d
               [立体转平面]^C^CProduct3dto2d
               [屏风恢复平面图标显示]^C^CFsTransToPlan
               [屏风面1面2显示]^C^CShowFsFace1Face2
               [多块修改]^C^CModifyFs2
               [屏风参数]^C^CFSData
***POP11
ID_MnLayout    [环境布置]
               [->结构]
                 [直线轴网...]^C^Cc_raxis
                 [弧线轴网...]^C^Cc_caxis
                 [显示轴网]^C^Clayer t axis_line;;
                 [<-隐藏轴网]^C^Clayer f axis_line;;
               [->墙壁]
                 [新建墙]^C^Cc_wall
                 [网建墙]^C^Cc_axis_wall
                 [线建墙]^C^Cc_entity_wall
                 [建房间]^C^Cc_rectwall
                 [->墙壁编辑]
                   [更新]^C^Cc_updatewall
                   [改端点]^C^Cc_chanwall
                   [打断]^C^Cc_breakwall
                   [修剪]^C^Cc_trimwall
                   [截断]^C^Cc_cutwall;
                   [延伸]^C^Cc_extendwall
                   [倒圆]^C^Cc_wall_fillet
                   [等距]^C^Cc_offsetwall
                   [<-清墙角]^C^Cc_wallfix
                 [等距墙线]^C^Cc_wallline
                 [<-墙线]^C^Cc_wallpoly
               [->柱子]
                 [网插方柱]^C^Cc_axis_rcolumn
                 [网插圆柱]^C^Cc_axis_ccolumn
                 [单插方柱]^C^Cc_rect_column
                 [单插圆柱]^C^Cc_circ_column
                 [<-删柱子]^C^Cc_erasecolumn
               [->门窗]
                 [门窗图库...]^C^Cshowdoorlib
                 [墙洞]^C^Cc_wallhole
                 [更 新]^C^Cc_updatechild
                 [<-改开向]^C^Cc_cdoordir
               [->顶棚]
                 [顶棚基面]^C^C(topfunction 1)
                 [->显示控制]
                   [显示顶棚立体]vplayer t top_3d;;;
                   [显示顶棚平面]vplayer t top_2d;;;
                   [隐藏顶棚立体]vplayer f top_3d;;;
                   [<-<-隐藏顶棚平面]vplayer f top_2d;;;
               [->地面]
                 [地面分块]^C^Cfloorplan
                 [填充图案]^C^Cfloorhatch
                 [->显示控制]
                   [显示立体]vplayer t floor_3d;;;
                   [显示平面]vplayer t floor_2d;;;
                   [显示填色]vplayer t floorfill;;;
                   [隐藏立体]vplayer f floor_3d;;;
                   [隐藏平面]vplayer f floor_2d;;;
                   [<-<-隐藏填色]vplayer f floorfill;;;
               [->筒灯]
                 [自动布筒灯]^C^C(topfunction 8)
                 [任意布筒灯]^C^C(topfunction 7)
                 [<-顶棚开筒灯]^C^C(topfunction 3)
               [->尺寸]
                 [直线轴网标注]^C^Cc_raxis_dim
                 [弧线轴网标注]^C^Cc_caxis_dim
                 [逐点轴标]^C^Cc_picks_dim
                 [墙窗标注]^C^Cc_walldim
                 [门窗标注]^C^Cc_windim
                 [改轴号]^C^Cc_chaxis_num
                 [<-改圆圈]^C^Cchc
               [->一般图库]
                 [按路径排列]^C^CDIVIDESET
                 [显示图库]^C^Cshowlib
                 [<-隐藏图库]^C^Chidelib
               [造型图库]^C^Cshowproglib
               [产品资料]^C^CQuoDataLib
               [家具统计清单]^C^CCreateQuoReport
               [手工报价]^C^CCreateQuoReport1
               [输出家具统计数据]^C^COutputQuoData
***POP12
ID_MnRender    [渲染]
               [ACAD灯光...]^C^C_light
               [材料...]^C^CMatByEnt
               [家具零件自动指定材料]^C^CRrMat
               [材料库...]^C^C_matlib
               [自动贴图坐标]^C^CAutoMapUV
               [设贴图坐标...]^C^CSetUvByEnt
               [清除贴图坐标]^C^C(if (not c:setuv) (arxload "render")) (c:setuv "D" (ssget))
               [背景...]^C^C_background
               [雾...]^C^C_fog
               [放置植物...]^C^C_lsnew
               [编辑植物...]^C^C_lsedit
               [植物库...]^C^C_lslib
               [渲染设置...]^C^C_rpref
               [渲染...]^C^C_render
               [打开模型视窗]^C^CBOV
               [停止模型视窗]^C^CStopOV 家具布置轴测图]
                 [建立轴测图]^C^Cplanset
                 [<-恢复原图]^C^Cclearplanset
***POP13
**WINDOW
ID_MnWindow    [&Window]
ID_DWG_CLOSE   [Cl&ose]^C^C_close
ID_WINDOW_CLOSEALL [C&lose All]^C^C_closeall
ID_WINDOW_CASCADE [&Cascade]^C^C_syswindows;_cascade
ID_WINDOW_TILE_HORZ [Tile &Horizontally]^C^C_syswindows;_hor
ID_WINDOW_TILE_VERT [&Tile Vertically]^C^C_syswindows;_vert
ID_WINDOW_ARRANGE [&Arrange Icons]^C^C_syswindows;_arrange
***POP14
ID_MnOther     [其他]
               [总体设置...]^C^Cc_glboption
               [系统参数设置]^C^CSetPara
               [清理文件]^C^Cpurge
               [->工具条]
                 [圆方]^C^C-toolbar;ROOM.MAIN;S
                 [板件造型]^C^C-toolbar;Room.FDM_BOARD;S
                 [板件装饰]^C^C-toolbar;Room.FDM_BDADORN;S
                 [板件修改]^C^C-toolbar;Room.FDM_BDMODIFY;S
                 [信息查询]^C^C-toolbar;Room.FDM_BDINFORMATION;S
                 [屏风连接]^C^C-toolbar;Room.FDM_FSJOINT;S
                 [家具显隐]^C^C-toolbar;Room.FDM_BDHIDE;S
                 [五金件]^C^C-toolbar;Room.FDM_ANNECTENT;S
                 [<-自动零件图]^C^C-toolbar;Room.FDM_AUTOPART;S
               [计算器]^C^CWinCal
               [每日一提示]^C^CTipOfDay
               [联机帮助]^C^CFdmOnlineHelp
               [重要数据备份与恢复]^C^CBackUp
               [报表定制]^C^CExcelFormDef
               [家具消隐]^C^CHideFur
               [->隐藏/显示]
                 [->板隐藏]
                   [隐藏]^C^CHideBoard
                   [按名称隐藏]^C^CHideBdByName
                   [反向隐藏]^C^CRevHideBoard
                   [<-按名称反向隐藏]^C^CRevHideBdByName
                 [->板显示]
                   [全部]^C^CDisplayBdAll
                   [<-部分]^C^CDisplayBdPart
                 [板标隐藏]^C^CBdMarkOff
                 [板标显示]^C^CBdMarkOn
                 [五金件隐藏]^C^CHideHw
                 [五金件显示]^C^CDisplayHw
                 [木纹方向隐藏]^C^CHideTMark
                 [木纹方向显示]^C^CViewTMark
                 [显示玻璃]^C^CShowGlass
                 [<-隐藏玻璃]^C^CHideGlass
               [家具设计标准与规范]^C^CFdmBook
               [人体模型]^C^Cshowlib
               [产品资料浏览...]^C^CProductShow
               [访问圆方公司网页]^C^CGotoYF
               [进入AutoCAD]^C^C_ToAcad
               [在命令行运行 Fdm 返回]^C^C_redraw
***TOOLBARS
**ZOOM
**缩放
ID______0      [_Toolbar("缩放", _Left, _Show, 0, 1, 1)]
ID_Zoom_In_0   [_Button("放大", "ICON6962.bmp", "ICON_24_ZOOIN")]'zoom 1.66x
ID_Zoom_Out_0  [_Button("缩小", "ICON4464.bmp", "ICON_24_ZOOOUT")]'zoom 0.6x
ID_Zoom_Window_0 [_Button("窗口", "ICON0491.bmp", "ICON_24_ZOOWIN")]'_zoom;_w
ID_Zoom_Previous_0 [_Button("前一个", "ICON2995.bmp", "ICON_24_ZOOPRE")]'_zoom;_p
ID_Pan_Realtime_0 [_Button("扫视", "ICON9358.bmp", "ICON_24_RTPAN")]'_pan
ID__7          [_Button("大小切换", "ICON0006.bmp", "ICON_24_BLANK")]^C^Cswitchview
ID__8          [_Button("最大化", "ICON0007.bmp", "ICON_24_BLANK")]^C^Cmaxview
ID__9          [_Button("恢复", "ICON0008.bmp", "ICON_24_BLANK")]^C^Crestoreview
ID_Zoom_Extents_0 [_Button("全图", "ICON5705.bmp", "ICON_24_ZOOEXT")]'_zoom;_e
**OSNAP
**点捕捉
ID______0      [_Toolbar("点捕捉", _Floating, _Hide, 532, 302, 1)]
ID_Snap_to_Endpoint_1 [_Button("端点", "ICON1942.bmp", "ICON_24_OSNEND")]_endp
ID_Snap_to_Midpoint_0 [_Button("中点", "ICON8467.bmp", "ICON_24_OSNMID")]_mid
ID_Snap_to_Intersection_0 [_Button("交点", "ICON6334.bmp", "ICON_24_OSNINT")]_int
ID_Snap_to_Center_0 [_Button("圆心", "ICON6500.bmp", "ICON_24_OSNCEN")]_cen
ID_Snap_to_Quadrant_0 [_Button("四分点", "ICON9169.bmp", "ICON_24_OSNQUA")]_qua
ID_Snap_to_Perpendicular_0 [_Button("垂直点", "ICON5724.bmp", "ICON_24_OSNPER")]_per
ID_Snap_to_Nearest_0 [_Button("最近点", "ICON1478.bmp", "ICON_24_OSNNEA")]_nea
ID_Snap_to_Tangent_0 [_Button("切点", "ICON4827.bmp", "ICON_24_OSNTAN")]_tan
ID_Snap_to_Node_0 [_Button("节点", "ICON5436.bmp", "ICON_24_OSNNOD")]_nod
ID_Distance_0  [_Button("测距离", "ICON8145.bmp", "ICON_24_DIST")]'_dist
**EDIT
**编辑
ID______1      [_Toolbar("编辑", _Floating, _Hide, 0, 0, 1)]
ID_Move_0      [_Button("移动", "ICON0292.bmp", "ICON_24_MOVE")]^C^Cc_move
ID_Rotate_0    [_Button("旋转", "ICON2382.bmp", "ICON_24_ROTATE")]^C^Cc_rotate
ID__1          [_Button("改色", "ICON0015.bmp", "ICON_24_BLANK")]^C^Cchange_color
ID_Copy_Object_0 [_Button("复制", "ICON8716.bmp", "ICON_24_COPYOB")]^C^Cc_copy
ID_Mirror_0    [_Button("镜像", "ICON9718.bmp", "ICON_24_MIRROR")]^C^Cc_mirror
ID_Rectangular_Array_0 [_Button("阵列", "ICON9895.bmp", "ICON_24_ARRREC")]^C^Cc_array
ID__2          [_Button("螺旋", "ICON0016.bmp", "ICON_24_BLANK")]^C^Csparray
ID_Stretch_0   [_Button("拉伸", "ICON1726.bmp", "ICON_24_STRETC")]^C^Cc_stretch
ID__3          [_Button("打断", "ICON0017.bmp", "ICON_24_BLANK")]^C^Cbreak
ID_Trim_0      [_Button("修剪", "ICON1538.bmp", "ICON_24_TRIM")]^C^Cc_trim
ID_Extend_0    [_Button("延长", "ICON1869.bmp", "ICON_24_EXTEND")]^C^Cc_extend
ID_Offset_0    [_Button("等距", "ICON9912.bmp", "ICON_24_OFFSET")]^C^Cc_offset
ID_Fillet_0    [_Button("圆角", "ICON5667.bmp", "ICON_24_FILLET")]^C^Cfillet
ID_Erase_0     [_Button("删除", "ICON6299.bmp", "ICON_24_ERASE")]^C^Cc_erase
**SHOW
**显示
ID______1      [_Toolbar("显示", _Floating, _Hide, 0, 0, 1)]
ID_Hide_0      [_Button("消隐", "ICON3811.bmp", "ICON_24_HIDE")]^C^Chide
ID_Redraw_All_0 [_Button("重画", "ICON1322.bmp", "ICON_24_REDALL")]'_redrawall
ID__6          [_Button("重生成", "ICON0013.bmp", "ICON_24_BLANK")]^C^Cregen
ID_Box_0       [_Button("显示立体", "ICON7673.bmp", "ICON_24_BLANK")]^C^Cvplayer t 3d_mesh;;;
ID_Box_1       [_Button("隐藏立体", "ICON0014.bmp", "ICON_24_BLANK")]^C^Cvplayer f 3d_mesh;;;
ID_Tiled_Model_Space_0 [_Button("设置视窗", "ICON5141.bmp", "ICON_24_VIETMS")]^C^Cviewconfig
ID_Bottom_View_0 [_Button("平面视图", "ICON7711.bmp", "ICON_24_VIEBOT")]^C^Ctopview
ID_Front_View_0 [_Button("正立面视图", "ICON8253.bmp", "ICON_24_VIEFRO")]^C^Cfrnview
ID_Left_View_0 [_Button("左立面视图", "ICON6868.bmp", "ICON_24_VIELEF")]^C^Clefview
ID_SW_Isometric_View_0 [_Button("3D视图", "ICON5547.bmp", "ICON_24_VIESWI")]^C^Cusrview
**CAMERA
**相机
ID______2      [_Toolbar("相机", _Floating, _Hide, 0, 0, 1)]
ID__10         [_Button("新建", "ICON0009.bmp", "ICON_24_BLANK")]^C^Cc_newcam
ID__11         [_Button("移动", "ICON0010.bmp", "ICON_24_BLANK")]^C^Cc_cam_move
ID__12         [_Button("改焦距", "ICON0011.bmp", "ICON_24_BLANK")]^C^Cc_chcam
ID__13         [_Button("显示", "ICON0012.bmp", "ICON_24_BLANK")]^C^Cc_show
**MAIN
**圆方
ID______0      [_Toolbar("圆方", _Right, _Show, 0, 1, 1)]
ID__0          [_Button("属性编辑", "mgxattr.bmp", "ICON_24_BLANK")]^C^Cmgxea
ID__1          [_Button("点捕捉", "ICON0002.bmp", "ICON_24_TRACK")]^C^C-toolbar;ROOM.OSNAP;S
ID__2          [_Flyout("编辑", ICON0001.bmp, ICON_24_TOOMOD, _OwnIcon, ROOM.EDIT)]
ID__3          [_Flyout("相机", ICON0005.bmp, ICON_24_BLANK, _OwnIcon, ROOM.CAMERA)]
ID__4          [_Button("缩放", "ICON0003.bmp", "ICON_24_RTZOOM")]^C^C-toolbar;ROOM.ZOOM;S
ID__5          [_Flyout("显示", ICON5141.bmp, ICON_24_VIETMS, _OwnIcon, ROOM.SHOW)]
ID__6          [_Button("回退", "ICON3281.bmp", "ICON_24_UNDO")]_u
**FDM_AUTOPART
**自动零件图
ID______0      [_Toolbar("自动零件图", _Left, _Hide, 4, 0, 1)]
ID__0          [_Button("生成", "fdm_2010.bmp", "ICON_24_PLANDRAW")]^C^Cplandraw
ID__1          [_Button("检索", "fdm_2020.bmp", "ICON_24_QUREYDRW")]^C^Cqureydrw
ID__2          [_Button("视窗中心", "fdm_2030.bmp", "ICON_24_CVIEWCENTER")]^C^CViewCenter
ID__3          [_Button("恢复显示", "fdm_2040.bmp", "ICON_24_RESTOREVP")]^C^CrestoreVp
ID__4          [_Button("显示图框", "fdm_2050.bmp", "ICON_24_SHOWDRAWINGVP")]^C^CShowDrawingVp
ID__5          [_Button("隐藏图框", "fdm_2060.bmp", "ICON_24_HIDEDRAWINGVP")]^C^CHideDrawingVp
ID__6          [_Button("编辑图框", "fdm_2070.bmp", "ICON_24_PAPERATTR")]^C^CPaperAttr
ID__7          [_Button("标题栏文字", "fdm_2080.bmp", "ICON_24_CHANGEFRAMTITLE")]^C^CChangeFrameTitle
ID__8          [_Button("转换图框", "fdm_2090.bmp", "ICON_24_CONVERTFRAMETONEW")]^C^CConvertFrameToNew
ID__9          [_Button("尺寸合并", "fdm_2100.bmp", "ICON_24_CUNITDIM")]^C^CUniteDim
ID__10         [_Button("孔位连续尺寸", "fdm_dim01.bmp", "ICON_24_CUNITDIM")]^C^CCMD2_continueDim
ID__11         [_Button("自动打印", "fdm_2110.bmp", "ICON_24_PLANAUTOPLOT")]^C^CPlanAutoPlot
ID__12         [_Button("半自动打印", "fdm_2120.bmp", "ICON_24_ATUOPLOT")]^C^CAutoPlot
**FDM_BDADORN
**板件装饰
ID______0      [_Toolbar("板件装饰", _Left, _Hide, 300, 160, 1)]
ID__0          [_Button("设定板面", "fdm_3050.bmp", "ICON_24_BOARDUCS")]^C^CBoardUcs
ID__1          [_Button("回到世界坐标", "fdm_3090.bmp", "ICON_24_UCS")]^C^Cucs w
ID__2          [_Button("生成孔", "fdm_3010.bmp", "ICON_24_MAKECAVE")]^C^CMakeCave
ID__3          [_Button("删除孔", "fdm_3020.bmp", "ICON_24_DELCAVE")]^C^CDelCave
ID__4          [_Button("生成槽", "fdm_3030.bmp", "ICON_24_MILLCAVE")]^C^CMillCave
ID__5          [_Button("删除槽", "fdm_3040.bmp", "ICON_24_DELMILLCAVE")]^C^CDelMillCave
ID__6          [_Button("加饰面", "fdm_3060.bmp", "ICON_24_ELEVP1")]^C^CElevP1
ID__7          [_Button("附着到板", "fdm_3070.bmp", "ICON_24_ATTACHTOBD")]^C^CAttachToBd
ID__8          [_Button("从板分离", "fdm_3080.bmp", "ICON_24_DETACHFROMBD")]^C^CDetachFromBd
**FDM_BOARD
**板件造型
ID______0      [_Toolbar("板件造型", _Floating, _Hide, 250, 149, 1)]
ID__0          [_Flyout("旁板", fdm_1010.bmp, ICON_24_SIDEBD, _OwnIcon, ROOM.FDM_SIDEBD)]
ID__1          [_Flyout("顶板", fdm_1020.bmp, ICON_24_TOPBD, _OwnIcon, ROOM.FDM_TOPBD)]
ID__2          [_Flyout("底板", fdm_1030.bmp, ICON_24_BOOTOMBD, _OwnIcon, ROOM.FDM_BOOTOMBD)]
ID__3          [_Flyout("背板", fdm_1040.bmp, ICON_24_BACKBD, _OwnIcon, ROOM.FDM_BACKBD)]
ID__4          [_Button("立隔板", "fdm_1050.bmp", "ICON_24_BERBOARD")]^C^CVerBoard
ID__5          [_Button("横隔板", "fdm_1060.bmp", "ICON_24_SHELF")]^C^CShelf
ID__6          [_Button("滑动门板", "fdm_1070.bmp", "ICON_24_SHIFT_DOOR")]^C^Cshift_door
ID__7          [_Button("旋转门板", "fdm_1080.bmp", "ICON_24_INLAY_DOOR")]^C^Cinlay_door
ID__8          [_Button("望板", "fdm_1090.bmp", "ICON_24_LOOKBOARD")]^C^CLookBoard
ID__9          [_Button("通用板", "fdm_1100.bmp", "ICON_24_GENERALBD")]^C^CGeneralBd
ID__10         [_Button("曲线板", "fdm_1110.bmp", "ICON_24_CREATECURVEBD")]^C^CCreateCurveBd
**FDM_SIDEBD
**旁板
ID______0      [_Toolbar("旁板", _Left, _Hide, 300, 220, 1)]
ID__SIDEBD1    [_Button("左旁板", "fdm_1011.bmp", "ICON_24_LS_BOARD")]^C^Cls_board
ID__SIDEBD2    [_Button("右旁板", "fdm_1012.bmp", "ICON_24_RS_BOARD")]^C^Crs_board
ID__SIDEBD3    [_Button("左右旁板", "fdm_1013.bmp", "ICON_24_LEFTRIGHT")]^C^Cleftright
**FDM_TOPBD
**顶板
ID______0      [_Toolbar("顶板", _Left, _Hide, 4, 0, 1)]
ID__TOPBD1     [_Button("平头顶板", "fdm_1021.bmp", "ICON_24_PT_TOP")]^C^Cpt_top
ID__TOPBD2     [_Button("出头顶板", "fdm_1022.bmp", "ICON_24_CT_TOP")]^C^Cct_top
ID__TOPBD3     [_Button("夹顶板", "fdm_1023.bmp", "ICON_24_IN_TOP")]^C^Cin_top
**FDM_BOOTOMBD
**底板
ID______0      [_Toolbar("底板", _Left, _Hide, 4, 0, 1)]
ID__BOOTOMBD1  [_Button("平头底板", "fdm_1031.bmp", "ICON_24_PT_FLOOR")]^C^Cpt_floor
ID__BOOTOMBD2  [_Button("出头地板", "fdm_1032.bmp", "ICON_24_CT_FLOOR")]^C^CCt_Floor
ID__BOOTOMBD3  [_Button("夹底板", "fdm_1033.bmp", "ICON_24_IN_FLOOR")]^C^Cin_floor
**FDM_BACKBD
**背板
ID______0      [_Toolbar("背板", _Left, _Hide, 300, 320, 1)]
ID__BACKBD1    [_Button("背板加强条", "fdm_1041.bmp", "ICON_24_CBACKBELT")]^C^Cbackbelt
ID__BACKBD2    [_Button("柜类背板", "fdm_1042.bmp", "ICON_24_BOARD")]^C^Cback_board
ID__BACKBD3    [_Button("桌类背板", "fdm_1043.bmp", "ICON_24_TABLEBACK")]^C^CTableback
**FDM_BDINFORMATION
**信息查询
ID______0      [_Toolbar("信息查询", _Left, _Hide, 3, 0, 1)]
ID__0          [_Button("板尺寸", "fdm_4010.bmp", "ICON_24_BOARD_DIM")]^C^CBoard_dim
ID__1          [_Button("板面积", "fdm_4020.bmp", "ICON_24_BDAREA")]^C^CBdArea
ID__2          [_Button("板周长", "fdm_4030.bmp", "ICON_24_BDCIRCUM")]^C^CBdCircum
ID__3          [_Button("板内侧距", "fdm_4040.bmp", "ICON_24_DIST_INT")]^C^Cdist_in
ID__4          [_Button("板外侧距", "fdm_4050.bmp", "ICON_24_DIST_OUT")]^C^Cdist_out
ID__5          [_Button("板中心距", "fdm_4060.bmp", "ICON_24_DIST_CENTER")]^C^Cdist_center
ID__6          [_Button("两面距离", "fdm_4070.bmp", "ICON_24_FACEDIST")]^C^Cfacedist
ID__7          [_Button("板正面", "fdm_4080.bmp", "ICON_24_GETPOSFACE")]^C^CGetPosFace
ID__8          [_Button("板边号", "fdm_4090.bmp", "ICON_24_GETEDGE")]^C^CGetEdge
ID__9          [_Button("两板夹角", "fdm_4100.bmp", "ICON_24_ANGDISPLAY")]^C^CAngDisplay
**FDM_BDMODIFY
**板件修改
ID______0      [_Toolbar("板件修改", _Left, _Hide, 300, 600, 1)]
ID__0          [_Button("厚向排列", "fdm_5010.bmp", "ICON_24_MAKECAVE")]^C^Carrayboard
ID__1          [_Button("区间均布", "fdm_5020.bmp", "ICON_24_MAKECAVE")]^C^Carrayboard1
ID__2          [_Flyout("改板间距", fdm_5030.bmp, ICON_24_BDDIST, _OwnIcon, ROOM.FDM_BDDIST)]
ID__3          [_Button("板向动态缩放", "fdm_5130.bmp", "ICON_24_SCALEXY")]^C^CScaleXY
ID__4          [_Button("厚向动态缩放", "fdm_5120.bmp", "ICON_24_SCALEH")]^C^CScaleH
ID__5          [_Flyout("对齐", fdm_5050.bmp, ICON_24_BDORDER, _OwnIcon, ROOM.FDM_BDORDER)]
ID__6          [_Button("面定位", "fdm_5080.bmp", "ICON_24_FACEFIX")]^C^Cfacefix
ID__7          [_Button("边面定位", "fdm_5090.bmp", "ICON_24_EDGEFACEFIX")]^C^CEdgeFacefix
ID__8          [_Button("面移动", "fdm_5100.bmp", "ICON_24_MOVEFACE")]^C^CMoveFace
ID__9          [_Flyout("板移动", fdm_5070.bmp, ICON_24_BDMOVE, _OwnIcon, ROOM.FDM_BDMOVE)]
ID__10         [_Button("更新", "fdm_5110.bmp", "ICON_24_UPDATEBD")]^C^CUpdateBd
ID__11         [_Flyout("运动与复位", fdm_5060.bmp, ICON_24_BDSPORT, _OwnIcon, ROOM.FDM_BDSPORT)]
ID__12         [_Flyout("板件尺寸修改", fdm_5040.bmp, ICON_24_BDSPORT, _OwnIcon, ROOM.FDM_BDREWORK)]
**FDM_BDREWORK
**板件尺寸修改
ID______0      [_Toolbar("板件尺寸修改", _Left, _Hide, 160, 60, 1)]
ID__BDREWORK1  [_Button("修剪", "fdm_5041.bmp", "ICON_24_BOARDTRIM")]^C^CBoardTrim
ID__BDREWORK2  [_Button("延伸", "fdm_5042.bmp", "ICON_24_BOARDEXTEND")]^C^CBoardExtend
ID__BDREWORK3  [_Button("断开", "fdm_5043.bmp", "ICON_24_BOARDBREAK")]^C^CBoardBreak
**FDM_BDORDER
**板件对齐
ID______0      [_Toolbar("板件对齐", _Left, _Hide, 160, 100, 1)]
ID__BDORDER1   [_Button("按正面对齐", "fdm_5051.bmp", "ICON_24_PAR_JUSTIFY1")]^C^CPar_Justify1
ID__BDORDER2   [_Button("按反面对齐", "fdm_5052.bmp", "ICON_24_PAR_JUSTIFY2")]^C^CPar_Justify3
ID__BDORDER3   [_Button("按中心对齐", "fdm_5053.bmp", "ICON_24_PAR_JUSTIFY3")]^C^CPar_Justify2
ID__BDORDER4   [_Button("对齐到正面", "fdm_5054.bmp", "ICON_24_PER_JUSTIFY1")]^C^CPer_Justify1
ID__BDORDER5   [_Button("对齐到反面", "fdm_5055.bmp", "ICON_24_PER_JUSTIFY2")]^C^CPer_Justify2
**FDM_BDDIST
**改板间距
ID______0      [_Toolbar("改板间距", _Left, _Hide, 4, 0, 1)]
ID__BDDIST1    [_Button("内侧距", "fdm_5031.bmp", "ICON_24_ADJUST_INNERDIST")]^C^CAdjust_InnerDist
ID__BDDIST2    [_Button("外侧距", "fdm_5032.bmp", "ICON_24_ADJUST_OUTDIST")]^C^CAdjust_OutDist
ID__BDDIST3    [_Button("中心距", "fdm_5033.bmp", "ICON_24_ADJUST_CENDIST")]^C^CAdjust_CenDist
**FDM_BDMOVE
**板移动
ID______0      [_Toolbar("板移动", _Left, _Hide, 160, 200, 1)]
ID__BDMOVE1    [_Button("居中", "fdm_5071.bmp", "ICON_24_LAYMID")]^C^CLayMid
ID__BDMOVE2    [_Button("厚向", "fdm_5072.bmp", "ICON_24_THICKDRAG")]^C^CThickDrag
ID__BDMOVE3    [_Button("板面", "fdm_5073.bmp", "ICON_24_DRAGXY")]^C^CDragXY
**FDM_BDSPORT
**运动与复位
ID______0      [_Toolbar("运动与复位", _Left, _Hide, 160, 260, 1)]
ID__BDSPORT1   [_Button("开门", "fdm_5061.bmp", "ICON_24_OPENBD")]^C^CopenBd
ID__BDSPORT2   [_Button("关门", "fdm_5062.bmp", "ICON_24_CLOSEBD")]^C^CcloseBd
ID__BDSPORT3   [_Button("开抽屉", "fdm_5063.bmp", "ICON_24_OPENDRAWER")]^C^Copendrawer
ID__BDSPORT4   [_Button("关抽屉", "fdm_5064.bmp", "ICON_24_CLOSEDDRAWER")]^C^CClosedrawer
ID__BDSPORT5   [_Button("全部复位", "fdm_5065.bmp", "ICON_24_RESOTREALL")]^C^CResotreAll
**FDM_BDHIDE
**家具显隐
ID______0      [_Toolbar("家具显隐", _Floating, _Hide, 138, 214, 1)]
ID__0          [_Button("家具隐藏", "fdm_6010.bmp", "ICON_24_HIDEFUR")]^C^CHideFur
ID__1          [_Button("板隐藏", "fdm_6020.bmp", "ICON_24_HIDEBOARD")]^C^CHideBoard
ID__2          [_Button("板反向隐藏", "fdm_6040.bmp", "ICON_24_REVHIDEBOARD")]^C^CRevHideBoard
ID__3          [_Button("板标隐藏", "fdm_6050.bmp", "ICON_24_BDMARKOFF")]^C^CBdMarkOff
ID__4          [_Button("木纹方向隐藏", "fdm_6060.bmp", "ICON_24_HIDETMARK")]^C^CHideTMark
ID__5          [_Button("玻璃隐藏", "fdm_6070.bmp", "ICON_24_HIDEGLASS")]^C^CHideGlass
ID__6          [_Button("板显示", "fdm_6080.bmp", "ICON_24_DISPLAYBAALL")]^C^CDisplayBdAll
ID__7          [_Button("板部分显示", "fdm_6090.bmp", "ICON_24_DISPLAYBDPART")]^C^CDisplayBdPart
ID__8          [_Button("板标显示", "fdm_6100.bmp", "ICON_24_BDMARKON")]^C^CBdMarkOn
ID__9          [_Button("木纹方向显示", "fdm_6110.bmp", "ICON_24_VIEWTMARK")]^C^CViewTMark
ID__10         [_Button("玻璃显示", "fdm_6120.bmp", "ICON_24_SHOWGLASS")]^C^CShowGlass
**FDM_ANNECTENT
**五金件
ID______0      [_Toolbar("五金件", _Left, _Hide, 160, 600, 1)]
ID__1          [_Button("偏心件圆榫定位生成", "                hw_bias.bmp",
"ICON_24_BIASDOWELFIX")]^C^CBiasDowelFix
ID__2          [_Button("自定义布置方案", "                        hw_bias2.bmp",
"ICON_24_BIASDOWELFIX")]^C^CBiasDef
ID__3          [_Button("偏心件圆榫自定义布置", "                hw_bias1.bmp",
"ICON_24_BIASDOWELFIX")]^C^CDefBiasDowelFix
ID__4          [_Button("偏心件圆榫复制", "                        hw_bias3.bmp",
"ICON_24_BIASDOWELFIX")]^C^CcpDiasDowel
ID__5          [_Button("偏心件圆榫反面定位", "                hw_bias5.bmp",
"ICON_24_BIASDOWELFIX")]^C^CBiasDowel_CF
ID__6          [_Button("五金件改位置", "                hw_dowel.bmp",
"ICON_24_BIASDOWELFIX")]^C^CHardwareMove
ID__7          [_Button("五金件库及安装", "                hw_bias6.bmp",
"ICON_24_BIASDOWELFIX")]^C^CHardwareLib
ID__8          [_Button("自由钻孔", "                hw_bias9.bmp", "ICON_24_BIASDOWELFIX")]^C^CRandomHole
**FDM_FSJOINT
**屏风连接
ID_JOINT_0     [_Toolbar("屏风连接", _Left, _Show, 0, 0, 1)]
ID_JOINT_T1    [_Button("多单元设计T形连接", "FS_T1.bmp", "ICON_24_BLANK")]^C^CFsFix
ID_JOINT_X1    [_Button("多单元设计十字连接", "FS_X1.bmp", "ICON_24_BLANK")]^C^CCross_FsFix
ID_JOINT_LINE1 [_Button("无柱直线连接", "FS_LINE1.bmp", "ICON_24_BLANK")]^C^CLineFix_NoClm
ID_JOINT_LINE  [_Button("直线连接", "FS_LINE.bmp", "ICON_24_BLANK")]^C^CLine_FixFs2
ID_JOINT_L     [_Button("L形连接", "FS_L.bmp", "ICON_24_BLANK")]^C^CL_FixFs2
ID_JOINT_V     [_Button("非90度L连接", "FS_V.bmp", "ICON_24_BLANK")]^C^CLnot90_Fs2
ID_JOINT_T     [_Button("T形连接", "FS_T.bmp", "ICON_24_BLANK")]^C^CT_FixFs2
ID_JOINT_Y     [_Button("Y连接", "FS_Y.bmp", "ICON_24_BLANK")]^C^CStar_FixFs2
ID_JOINT_X     [_Button("十字连接", "FS_X.bmp", "ICON_24_BLANK")]^C^CCross_FixFs2
ID_JOINT_E     [_Button("端柱", "FS_EDGE.bmp", "ICON_24_BLANK")]^C^CAddEndColoum
ID_UserButton_2 [_Button("屏风", "ICON0106.bmp", "ICON_16_BLANK")]^C^CFoldScr2
ID_UserButton_0 [_Button("图库", "ICON9040.bmp", "ICON_16_BLANK")]^C^Cshowlib
ID_UserButton_1 [_Button("桌板", "ICON8942.bmp", "ICON_16_BLANK")]^C^CFsdeskBdfix
**TB_DIMENSION
**DIMENSION
ID_TbDimensi   [_Toolbar("Dimension", _Top, _Show, 1, 1, 1)]
ID_Dimlinear   [_Button("Linear Dimension", "ICON_16_DIMLIN", "ICON_24_DIMLIN")]^C^C_dimlinear
ID_Dimaligne   [_Button("Aligned Dimension", "ICON_16_DIMALI", "ICON_24_DIMALI")]^C^C_dimaligned
ID_Dimordina   [_Button("Ordinate Dimension", "ICON_16_DIMORD", "ICON_24_DIMORD")]^C^C_dimordinate
ID_Dimradius   [_Button("Radius Dimension", "ICON_16_DIMRAD", "ICON_24_DIMRAD")]^C^C_dimradius
ID_Dimdiamet   [_Button("Diameter Dimension", "ICON_16_DIMDIA", "ICON_24_DIMDIA")]^C^C_dimdiameter
ID_Dimangula   [_Button("Angular Dimension", "ICON_16_DIMANG", "ICON_24_DIMANG")]^C^C_dimangular
ID_Dimbaseli   [_Button("Baseline Dimension", "ICON_16_DIMBAS", "ICON_24_DIMBAS")]^C^C_dimbaseline
ID_Dimcontin   [_Button("Continue Dimension", "ICON_16_DIMCON", "ICON_24_DIMCON")]^C^C_dimcontinue
ID_Leader      [_Button("Leader", "ICON_16_DIMLEA", "ICON_24_DIMLEA")]^C^C_leader
ID_Tolerance   [_Button("Tolerance", "ICON_16_TOLERA", "ICON_24_TOLERA")]^C^C_tolerance
ID_Dimcenter   [_Button("Center Mark", "ICON_16_DIMCEN", "ICON_24_DIMCEN")]^C^C_dimcenter
ID_Dimedit     [_Button("Dimension Edit", "ICON_16_DIMNEW", "ICON_24_DIMNEW")]^C^C_dimedit
ID_Dimtedit    [_Button("Dimension Text Edit", "ICON_16_DIMHOM", "ICON_24_DIMHOM")]^C^C_dimtedit
ID_Ddim        [_Button("Dimension Style", "ICON_16_DIMSTY", "ICON_24_DIMSTY")]^C^C_ddim
ID_DimUpdate   [_Button("Dimension Update", "ICON_16_DIMUPD", "ICON_24_DIMUPD")]^C^C_dim _update
**TB_DRAW
**DRAW
ID_TbDraw      [_Toolbar("Draw", _Left, _Show, 2, 0, 1)]
ID_Line        [_Button("Line", "ICON_16_LINE", "ICON_24_LINE")]^C^C_line
ID_Xline       [_Button("Construction Line", "ICON_16_XLINE", "ICON_24_XLINE")]^C^C_xline
ID_Mline       [_Button("Multiline", "ICON_16_MLINE", "ICON_24_MLINE")]^C^C_mline
ID_Pline       [_Button("Polyline", "ICON_16_PLINE", "ICON_24_PLINE")]^C^C_pline
ID_Polygon     [_Button("Polygon", "ICON_16_POLYGO", "ICON_24_POLYGO")]^C^C_polygon
ID_Rectang     [_Button("Rectangle", "ICON_16_RECTAN", "ICON_24_RECTAN")]^C^C_rectang
ID_Arc         [_Button("Arc", "ICON_16_ARC3PT", "ICON_24_ARC3PT")]^C^C_arc
ID_Circle      [_Button("Circle", "ICON_16_CIRRAD", "ICON_24_CIRRAD")]^C^C_circle
ID_Spline      [_Button("Spline", "ICON_16_SPLINE", "ICON_24_SPLINE")]^C^C_spline
ID_Ellipse     [_Button("Ellipse", "ICON_16_ELLCEN", "ICON_24_ELLCEN")]^C^C_ellipse
ID_TbInsert    [_Flyout("Block", ICON_16_BLOCK, ICON_24_BLOCK, _OtherIcon, ACAD.TB_INSERT)]
ID_Bmake       [_Button("Make Block", "ICON_16_BLOCK", "ICON_24_BLOCK")]^C^C_bmake
ID_Point       [_Button("Point", "ICON_16_POINT", "ICON_24_POINT")]*^C^C_point
ID_Bhatch      [_Button("Hatch", "ICON_16_BHATCH", "ICON_24_BHATCH")]^C^C_bhatch
ID_Region      [_Button("Region", "ICON_16_REGION", "ICON_24_REGION")]^C^C_region
ID_Mtext       [_Button("Multiline Text", "ICON_16_MTEXT", "ICON_24_MTEXT")]^C^C_mtext
**TB_EXTERNAL_DATABASE
ID_TbExtdb     [_Toolbar("External Database", _Floating, _Hide, 100, 150, 1)]
ID_Aseadmin    [_Button("Administration", "ICON_16_ASEADM", "ICON_24_ASEADM")]^C^C_aseadmin
ID_Aserows     [_Button("Rows", "ICON_16_ASEROW", "ICON_24_ASEROW")]^C^C_aserows
ID_Aselinks    [_Button("Links", "ICON_16_ASELIN", "ICON_24_ASELIN")]^C^C_aselinks
ID_Aseselect   [_Button("Select Objects", "ICON_16_ASESEL", "ICON_24_ASESEL")]^C^C_aseselect
ID_Aseexport   [_Button("Export Links", "ICON_16_ASEEXP", "ICON_24_ASEEXP")]^C^C_aseexport
ID_Asesqled    [_Button("SQL Editor", "ICON_16_ASESQL", "ICON_24_ASESQL")]^C^C_asesqled
**TB_INQUIRY
**INQUIRY
ID_TbInquiry   [_Toolbar("Inquiry", _Left, _Show, 1, 1, 1)]
ID_Dist        [_Button("Distance", "ICON_16_DIST", "ICON_24_DIST")]'_dist
ID_Area        [_Button("Area", "ICON_16_AREA", "ICON_24_AREA")]^C^C_area
ID_Massprop    [_Button("Mass Properties", "ICON_16_MASSPR", "ICON_24_MASSPR")]^C^C_massprop
ID_List        [_Button("List", "ICON_16_LIST", "ICON_24_LIST")]^C^C_list
ID_Id          [_Button("Locate Point", "ICON_16_ID", "ICON_24_ID")]'_id
**TB_INSERT
**INSERT
ID_TbInsert    [_Toolbar("Insert", _Floating, _Hide, 100, 190, 1)]
ID_Ddinsert    [_Button("Insert Block", "ICON_16_DINSER", "ICON_24_DINSER")]^C^C_ddinsert
ID_Xref        [_Button("External Reference", "ICON_16_XREATT", "ICON_24_XREATT")]^C^C_xref
ID_Image       [_Button("Image", "ICON_16_IMAGE", "ICON_24_IMAGE")]^C^C_image
ID_Import      [_Button("Import", "ICON_16_IMPORT", "ICON_24_IMPORT")]^C^C_import
ID_Insertobj   [_Button("OLE Object", "ICON_16_INSOLE", "ICON_24_INSOLE")]^C^C_insertobj
**TB_MODIFY
**MODIFY
ID_TbModify    [_Toolbar("Modify", _Floating, _Hide, 403, 141, 1)]
ID_Move        [_Button("Move", "ICON_16_MOVE",
"ICON_24_MOVE")]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),grip),_move,^C^C_move)
ID_Rotate      [_Button("Rotate", "ICON_16_ROTATE",
"ICON_24_ROTATE")]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),grip),_rotate,^C^C_rotate)
ID_Scale       [_Button("Scale", "ICON_16_SCALE",
"ICON_24_SCALE")]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),grip),_scale,^C^C_scale)
ID_Stretch     [_Button("Stretch", "ICON_16_STRETC", "ICON_24_STRETC")]^C^C_stretch
ID_Lengthen    [_Button("Lengthen", "ICON_16_LENGTH", "ICON_24_LENGTH")]^C^C_lengthen
ID_Trim        [_Button("Trim", "ICON_16_TRIM", "ICON_24_TRIM")]^C^C_trim
ID_Extend      [_Button("Extend", "ICON_16_EXTEND", "ICON_24_EXTEND")]^C^C_extend
ID_Break       [_Button("Break", "ICON_16_BRE2PT", "ICON_24_BRE2PT")]^C^C_break
ID_Chamfer     [_Button("Chamfer", "ICON_16_CHAMFE", "ICON_24_CHAMFE")]^C^C_chamfer
ID_Fillet      [_Button("Fillet", "ICON_16_FILLET", "ICON_24_FILLET")]^C^C_fillet
**TB_MODIFY_II
ID_TbModifII   [_Toolbar("Modify II", _Floating, _Hide, 96, 257, 1)]
ID_Draworder   [_Button("Draworder", "ICON_16_DRWORD", "ICON_24_DRWORD")]^C^C_draworder
ID_Hatchedit   [_Button("Edit Hatch", "ICON_16_HATEDI", "ICON_24_HATEDI")]^C^C_hatchedit
ID_Pedit       [_Button("Edit Polyline", "ICON_16_PEDIT", "ICON_24_PEDIT")]^C^C_pedit
ID_Splinedit   [_Button("Edit Spline", "ICON_16_SPLEDI", "ICON_24_SPLEDI")]^C^C_splinedit
ID_Mledit      [_Button("Edit Multiline", "ICON_16_MLEDIT", "ICON_24_MLEDIT")]^C^C_mledit
ID_Ddatte      [_Button("Edit Attribute", "ICON_16_ATTEDI", "ICON_24_ATTEDI")]^C^C_ddatte
ID_Ddedit      [_Button("Edit Text", "ICON_16_TEXEDI", "ICON_24_TEXEDI")]^C^C_ddedit
**TB_OBJECT_PROPERTIES
**TB__OBJECT_PROPERTIES
ID_TbObjectP   [_Toolbar("_Object Properties", _Top, _Show, 0, 1, 1)]
ID_Preferenc_0 [_Button("Options", "ICON9264.bmp", "ICON_16_BLANK")]^C^C_options
ID_Ai_molc     [_Button("Make Object's Layer Current", "ICON_16_MOLC", "ICON_24_MOLC")]^C^Cai_molc
ID_Layer       [_Button("Layers", "ICON_16_LAYERS", "ICON_24_LAYERS")]'_layer
               [_Control(_Layer)]
               [_Control(_Color)]
ID_Linetype    [_Button("Linetype", "ICON_16_LINETY", "ICON_24_LINETY")]'_linetype
               [_Control(_Linetype)]
ID_Ai_propch   [_Button("Properties", "ICON_16_MODIFY", "ICON_24_MODIFY")]^C^Cai_propchk
**TB_OBJECT_SNAP
ID_TbOsnap     [_Toolbar("Object Snap", _Right, _Show, 0, 0, 1)]
ID_Tracking    [_Button("Tracking", "ICON_16_TRACK", "ICON_24_TRACK")]_tracking
ID_From        [_Button("Snap From", "ICON_16_OSNFRO", "ICON_24_OSNFRO")]_from
ID_OsnapEndp   [_Button("Snap to Endpoint", "ICON_16_OSNEND", "ICON_24_OSNEND")]_endp
ID_OsnapMidp   [_Button("Snap to Midpoint", "ICON_16_OSNMID", "ICON_24_OSNMID")]_mid
ID_OsnapInte   [_Button("Snap to Intersection", "ICON_16_OSNINT", "ICON_24_OSNINT")]_int
ID_OsnapAppa   [_Button("Snap to Apparent Intersect", "ICON_16_OSNAPP", "ICON_24_OSNAPP")]_appint
ID_OsnapCent   [_Button("Snap to Center", "ICON_16_OSNCEN", "ICON_24_OSNCEN")]_cen
ID_OsnapQuad   [_Button("Snap to Quadrant", "ICON_16_OSNQUA", "ICON_24_OSNQUA")]_qua
ID_OsnapTang   [_Button("Snap to Tangent", "ICON_16_OSNTAN", "ICON_24_OSNTAN")]_tan
ID_OsnapPerp   [_Button("Snap to Perpendicular", "ICON_16_OSNPER", "ICON_24_OSNPER")]_per
ID_OsnapInse   [_Button("Snap to Insert", "ICON_16_OSNINS", "ICON_24_OSNINS")]_ins
ID_OsnapNode   [_Button("Snap to Node", "ICON_16_OSNNOD", "ICON_24_OSNNOD")]_nod
ID_OsnapNear   [_Button("Snap to Nearest", "ICON_16_OSNNEA", "ICON_24_OSNNEA")]_nea
ID_OsnapQuic   [_Button("Snap to Quick", "ICON_16_OSNQUI", "ICON_24_OSNQUI")]_quick,^Z
ID_OsnapNone   [_Button("Snap to None", "ICON_16_OSNNON", "ICON_24_OSNNON")]_non
ID_Osnap       [_Button("Object Snap Settings", "ICON_16_OSNAP", "ICON_24_OSNAP")]'_osnap
**TB_REFERENCE
**REFERENCE
ID_TbReferen   [_Toolbar("Reference", _Floating, _Hide, 64, 374, 1)]
ID_Xattach     [_Button("External Reference Attach", "ICON_16_XATTAC", "ICON_24_XATTAC")]^C^C_xattach
ID_Xclip       [_Button("External Reference Clip", "ICON_16_XRECLI", "ICON_24_XRECLI")]^C^C_xclip
ID_Xbind       [_Button("External Reference Bind", "ICON_16_XBIND", "ICON_24_XBIND")]^C^C_xbind
ID_Xclipfram   [_Button("External Reference Clip Frame", "ICON_16_XCLIPFRAME",
"ICON_24_XCLIPFRAME")]^C^C_xclipframe
ID_ImageAtta   [_Button("Image Attach", "ICON_16_IMGATT", "ICON_24_IMGATT")]^C^C_imageattach
ID_Imageclip   [_Button("Image Clip", "ICON_16_IMGCLP", "ICON_24_IMGCLP")]^C^C_imageclip
ID_Imageadju   [_Button("Image Adjust", "ICON_16_IMGADJ", "ICON_24_IMGADJ")]^C^C_imageadjust
ID_Imagequal   [_Button("Image Quality", "ICON_16_IMGQUA", "ICON_24_IMGQUA")]^C^C_imagequality
ID_Transpare   [_Button("Image Transparency", "ICON_16_TRANSP", "ICON_24_TRANSP")]^C^C_transparency
ID_Imagefram   [_Button("Image Frame", "ICON_16_IMGFRAME", "ICON_24_IMGFRAME")]^C^C_imageframe
**TB_RENDER
**RENDER
ID_TbRender    [_Toolbar("Render", _Floating, _Hide, 118, 133, 1)]
ID_Hide        [_Button("Hide", "ICON_16_HIDE", "ICON_24_HIDE")]^C^C_hide
ID_Shade       [_Button("Shade", "ICON_16_SHADE", "ICON_24_SHADE")]^C^C_shade
ID_Render      [_Button("Render", "ICON_16_RENDER", "ICON_24_RENDER")]^C^C_render
ID_Scene       [_Button("Scenes", "ICON_16_SCENE", "ICON_24_SCENE")]^C^C_scene
ID_Light       [_Button("Lights", "ICON_16_LIGHT", "ICON_24_LIGHT")]^C^C_light
ID_Rmat        [_Button("Materials", "ICON_16_RMAT", "ICON_24_RMAT")]^C^C_rmat
ID_Matlib      [_Button("Materials Library", "ICON_16_MATLIB", "ICON_24_MATLIB")]^C^C_matlib
ID_Setuv       [_Button("Mapping", "ICON_16_SETUV", "ICON_24_SETUV")]^C^C_setuv
ID_Backgroun   [_Button("Background", "ICON_16_BACKGR", "ICON_24_BACKGR")]^C^C_background
ID_Fog         [_Button("Fog", "ICON_16_FOG", "ICON_24_FOG")]^C^C_fog
ID_Lsnew       [_Button("Landscape New", "ICON_16_LSNEW", "ICON_24_LSNEW")]^C^C_lsnew
ID_Lsedit      [_Button("Landscape Edit", "ICON_16_LSEDIT", "ICON_24_LSEDIT")]^C^C_lsedit
ID_Lslib       [_Button("Landscape Library", "ICON_16_LSLIB", "ICON_24_LSLIB")]^C^C_lslib
ID_Rpref       [_Button("Render Preferences", "ICON_16_RPREF", "ICON_24_RPREF")]^C^C_rpref
ID_Stats       [_Button("Statistics", "ICON_16_STATS", "ICON_24_STATS")]^C^C_stats
**TB_SOLIDS
**SOLIDS
ID_TbSolids    [_Toolbar("Solids", _Top, _Show, 1, 0, 1)]
ID_Box         [_Button("Box", "ICON_16_BOX", "ICON_24_BOX")]^C^C_box
ID_Sphere      [_Button("Sphere", "ICON_16_SPHERE", "ICON_24_SPHERE")]^C^C_sphere
ID_Cylinder    [_Button("Cylinder", "ICON_16_CYLIND", "ICON_24_CYLIND")]^C^C_cylinder
ID_Cone        [_Button("Cone", "ICON_16_CONE", "ICON_24_CONE")]^C^C_cone
ID_Wedge       [_Button("Wedge", "ICON_16_WEDGE", "ICON_24_WEDGE")]^C^C_wedge
ID_Torus       [_Button("Torus", "ICON_16_TORUS", "ICON_24_TORUS")]^C^C_torus
ID_Extrude     [_Button("Extrude", "ICON_16_EXTRUD", "ICON_24_EXTRUD")]^C^C_extrude
ID_Revolve     [_Button("Revolve", "ICON_16_REVOLV", "ICON_24_REVOLV")]^C^C_revolve
ID_Slice       [_Button("Slice", "ICON_16_SLICE", "ICON_24_SLICE")]^C^C_slice
ID_Section     [_Button("Section", "ICON_16_SECTIO", "ICON_24_SECTIO")]^C^C_section
ID_Interfere   [_Button("Interfere", "ICON_16_INTERF", "ICON_24_INTERF")]^C^C_interfere
ID_Soldraw     [_Button("Setup Drawing", "ICON_16_SOLDR", "ICON_24_SOLDR")]^C^C_soldraw
ID_Solview     [_Button("Setup View", "ICON_16_SOLVW", "ICON_24_SOLVW")]^C^C_solview
ID_Solprof     [_Button("Setup Profile", "ICON_16_SOLPR", "ICON_24_SOLPR")]^C^C_solprof
**TB_STANDARD
**TB__STANDARD_TOOLBAR
ID_TbStandar   [_Toolbar("_Standard Toolbar", _Top, _Show, 0, 0, 1)]
ID_New         [_Button("New", "ICON_16_NEW", "ICON_24_NEW")]^C^C_new
ID_Open        [_Button("Open", "ICON_16_OPEN", "ICON_24_OPEN")]^C^C_open
ID_Save        [_Button("Save", "ICON_16_SAVE", "ICON_24_SAVE")]^C^C_qsave
ID_Print       [_Button("Print", "ICON_16_PRINT", "ICON_24_PRINT")]^C^C_plot
ID_Preview     [_Button("Print Preview", "ICON_16_PREVIEW", "ICON_24_PREVIEW")]^C^C_preview
ID_Spell       [_Button("Spelling", "ICON_16_SPELL", "ICON_24_SPELL")]^C^C_spell
ID_Cutclip     [_Button("Cut to Clipboard", "ICON_16_CUT", "ICON_24_CUT")]'_cutclip
ID_Copyclip    [_Button("Copy to Clipboard", "ICON_16_COPY", "ICON_24_COPY")]'_copyclip
ID_Pasteclip   [_Button("Paste from Clipboard", "ICON_16_PASTE", "ICON_24_PASTE")]'_pasteclip
ID_Matchprop   [_Button("Match Properties", "ICON_16_MATCH", "ICON_24_MATCH")]_matchprop
ID_U           [_Button("Undo", "ICON_16_UNDO", "ICON_24_UNDO")]_u
ID_Redo        [_Button("Redo", "ICON_16_REDO", "ICON_24_REDO")]^C^C_redo
ID_Browser     [_Button("Launch Browser", "ICON_16_URL", "ICON_24_URL")]^C^C_browser;;
ID_TbOsnap     [_Flyout("Object Snap", ICON_16_OSNAP, ICON_24_OSNAP, _OtherIcon, ACAD.TB_OBJECT_SNAP)]
ID_TbUcs       [_Flyout("UCS", ICON_16_UCS, ICON_24_UCS, _OtherIcon, ACAD.TB_UCS)]
ID_TbInquiry   [_Flyout("Inquiry", ICON_16_LIST, ICON_24_LIST, _OtherIcon, ACAD.TB_INQUIRY)]
ID_Redrawall   [_Button("Redraw All", "ICON_16_REDRAW", "ICON_24_REDRAW")]^C^C_redrawall
ID_Dsviewer    [_Button("Aerial View", "ICON_16_AERIAL", "ICON_24_AERIAL")]'_dsviewer
ID_TbViewpoi   [_Flyout("Viewpoint", ICON_16_DDVIEW, ICON_24_DDVIEW, _OtherIcon, ACAD.TB_VIEWPOINT)]
ID_Pan         [_Button("Pan Realtime", "ICON_16_RTPAN", "ICON_24_RTPAN")]'_pan
ID_ZoomRealt   [_Button("Zoom Realtime", "ICON_16_RTZOOM", "ICON_24_RTZOOM")]'_zoom ;
ID_TbZoom      [_Flyout("Zoom", ICON_16_ZOOM, ICON_24_ZOOM, _OtherIcon, ACAD.TB_ZOOM)]
ID_ZoomPrevi   [_Button("Zoom Previous", "ICON_16_ZOOPRE", "ICON_24_ZOOPRE")]'_zoom;_p
ID_Help        [_Button("Help", "ICON_16_HELP", "ICON_24_HELP")]'_help
**TB_SURFACES
**SURFACES
ID_TbSurface   [_Toolbar("Surfaces", _Floating, _Hide, -45, 187, 1)]
ID_Solid       [_Button("2D Solid", "ICON_16_SOLID", "ICON_24_SOLID")]^C^C_solid
ID_3dface      [_Button("3D Face", "ICON_16_3DFACE", "ICON_24_3DFACE")]^C^C_3dface
ID_Ai_box      [_Button("Box", "ICON_16_SURBOX", "ICON_24_SURBOX")]^C^Cai_box
ID_Ai_wedge    [_Button("Wedge", "ICON_16_SURWED", "ICON_24_SURWED")]^C^Cai_wedge
ID_Ai_pyrami   [_Button("Pyramid", "ICON_16_SURPYR", "ICON_24_SURPYR")]^C^Cai_pyramid
ID_Ai_cone     [_Button("Cone", "ICON_16_SURCON", "ICON_24_SURCON")]^C^Cai_cone
ID_Ai_sphere   [_Button("Sphere", "ICON_16_SURSPH", "ICON_24_SURSPH")]^C^Cai_sphere
ID_Ai_dome     [_Button("Dome", "ICON_16_SURDOM", "ICON_24_SURDOM")]^C^Cai_dome
ID_Ai_dish     [_Button("Dish", "ICON_16_SURDIS", "ICON_24_SURDIS")]^C^Cai_dish
ID_Ai_torus    [_Button("Torus", "ICON_16_SURTOR", "ICON_24_SURTOR")]^C^Cai_torus
ID_Edge        [_Button("Edge", "ICON_16_EDGE", "ICON_24_EDGE")]^C^C_edge
ID_3dmesh      [_Button("3D Mesh", "ICON_16_3DMESH", "ICON_24_3DMESH")]^C^C_3dmesh
ID_Revsurf     [_Button("Revolved Surface", "ICON_16_REVSUR", "ICON_24_REVSUR")]^C^C_revsurf
ID_Tabsurf     [_Button("Tabulated Surface", "ICON_16_TABSUR", "ICON_24_TABSUR")]^C^C_tabsurf
ID_Rulesurf    [_Button("Ruled Surface", "ICON_16_RULESU", "ICON_24_RULESU")]^C^C_rulesurf
ID_Edgesurf    [_Button("Edge Surface", "ICON_16_EDGESU", "ICON_24_EDGESU")]^C^C_edgesurf
**TB_UCS
**UCS
ID_TbUcs       [_Toolbar("UCS", _Floating, _Hide, 37, 378, 2)]
ID_Ucs         [_Button("UCS", "ICON_16_UCS", "ICON_24_UCS")]^C^C_ucs
ID_Dducs       [_Button("Named UCS", "ICON_16_DDUCS", "ICON_24_DDUCS")]^C^C_dducs
ID_Dducsp      [_Button("Preset UCS", "ICON_16_UCSP", "ICON_24_UCSP")]^C^C_dducsp
ID_UcsPrevio   [_Button("UCS Previous", "ICON_16_UCSPRE", "ICON_24_UCSPRE")]^C^C_ucs _p
ID_UcsWorld    [_Button("World UCS", "ICON_16_UCSW", "ICON_24_UCSW")]^C^C_ucs _w
ID_UcsObject   [_Button("Object UCS", "ICON_16_UCSOBJ", "ICON_24_UCSOBJ")]^C^C_ucs _ob
ID_UcsOrigin   [_Button("Origin UCS", "ICON_16_UCSORI", "ICON_24_UCSORI")]^C^C_ucs _o
ID_UcsZAxVec   [_Button("Z Axis Vector UCS", "ICON_16_UCSZAV", "ICON_24_UCSZAV")]^C^C_ucs _zaxis
ID_Ucs3point   [_Button("3 Point UCS", "ICON_16_UCS3PT", "ICON_24_UCS3PT")]^C^C_ucs _3
ID_UcsXAxRot   [_Button("X Axis Rotate UCS", "ICON_16_UCSXAR", "ICON_24_UCSXAR")]^C^C_ucs _x
ID_UcsYAxRot   [_Button("Y Axis Rotate UCS", "ICON_16_UCSYAR", "ICON_24_UCSYAR")]^C^C_ucs _y
ID_UcsZAxRot   [_Button("Z Axis Rotate UCS", "ICON_16_UCSZAR", "ICON_24_UCSZAR")]^C^C_ucs _z
**TB_VIEWPOINT
**VIEWPOINT
ID_TbViewpoi   [_Toolbar("Viewpoint", _Left, _Show, 2, 1, 1)]
ID_Ddview      [_Button("Named Views", "ICON_16_DDVIEW", "ICON_24_DDVIEW")]^C^C_ddview
ID_VpointTop   [_Button("Top View", "ICON_16_VIETOP", "ICON_24_VIETOP")]^C^C_vpoint _non *0,0,1
ID_VpointBot   [_Button("Bottom View", "ICON_16_VIEBOT", "ICON_24_VIEBOT")]^C^C_vpoint _non *0,0,-1
ID_VpointLef   [_Button("Left View", "ICON_16_VIELEF", "ICON_24_VIELEF")]^C^C_vpoint _non *-1,0,0
ID_VpointRig   [_Button("Right View", "ICON_16_VIERIG", "ICON_24_VIERIG")]^C^C_vpoint _non *1,0,0
ID_VpointFro   [_Button("Front View", "ICON_16_VIEFRO", "ICON_24_VIEFRO")]^C^C_vpoint _non *0,-1,0
ID_VpointBac   [_Button("Back View", "ICON_16_VIEBAC", "ICON_24_VIEBAC")]^C^C_vpoint _non *0,1,0
ID_VpointSW    [_Button("SW Isometric View", "ICON_16_VIESWI", "ICON_24_VIESWI")]^C^C_vpoint _non *
-1,-1,1
ID_VpointSE    [_Button("SE Isometric View", "ICON_16_VIESEI", "ICON_24_VIESEI")]^C^C_vpoint _non
*1,-1,1
ID_VpointNE    [_Button("NE Isometric View", "ICON_16_VIENEI", "ICON_24_VIENEI")]^C^C_vpoint _non
*1,1,1
ID_VpointNW    [_Button("NW Isometric View", "ICON_16_VIENWI", "ICON_24_VIENWI")]^C^C_vpoint _non *
-1,1,1
**TB_ZOOM
**ZOOM
ID_TbZoom      [_Toolbar("Zoom", _Floating, _Hide, 100, 350, 1)]
ID_ZoomWindo   [_Button("Zoom Window", "ICON_16_ZOOWIN", "ICON_24_ZOOWIN")]'_zoom _w
ID_ZoomDynam   [_Button("Zoom Dynamic", "ICON_16_ZOODYN", "ICON_24_ZOODYN")]'_zoom _d
ID_ZoomScale   [_Button("Zoom Scale", "ICON_16_ZOOSCA", "ICON_24_ZOOSCA")]'_zoom _s
ID_ZoomCente   [_Button("Zoom Center", "ICON_16_ZOOCEN", "ICON_24_ZOOCEN")]'_zoom _c
ID_ZoomIn      [_Button("Zoom In", "ICON_16_ZOOIN", "ICON_24_ZOOIN")]'_zoom 2x
ID_ZoomOut     [_Button("Zoom Out", "ICON_16_ZOOOUT", "ICON_24_ZOOOUT")]'_zoom .5x
ID_ZoomAll     [_Button("Zoom All", "ICON_16_ZOOALL", "ICON_24_ZOOALL")]'_zoom _all
ID_ZoomExten   [_Button("Zoom Extents", "ICON_16_ZOOEXT", "ICON_24_ZOOEXT")]'_zoom _e
**BYEBYE
ID_byebye_0    [_Toolbar("byebye", _Floating, _Show, 141, 278, 1)]
ID_Copyclip_0  [_Button("Copy to Clipboard", "ICON_16_COPY", "ICON_16_COPY")]^C^C_copyclip
ID_Pasteclip_0 [_Button("Paste from Clipboard", "ICON_16_PASTE", "ICON_16_PASTE")]^C^C_pasteclip
ID_Ddinsert_0  [_Button("Insert Block", "ICON_16_DINSER", "ICON_16_DINSER")]^C^C_insert
ID_Matchprop_0 [_Button("Match Properties", "ICON_16_MATCH", "ICON_16_MATCH")]'_matchprop
ID_UcsView     [_Button("View UCS", "ICON_16_UCSVIE", "ICON_24_UCSVIE")]^C^C_ucs _v
ID_Scaletext_0 [_Button("Scale Text", "ICON_16_SCALETXT", "ICON_16_SCALETXT")]^C^C_scaletext
ID_Justifyte_0 [_Button("Justify Text", "ICON_16_JUSTIFYTXT", "ICON_16_JUSTIFYTXT")]^C^C_justifytext
ID_Rotate3d_0  [_Button("3D Operation Rotate 3D", "ICON2648.bmp", "ICON_16_BLANK")]^C^C_rotate3d
ID_Align_0     [_Button("3D Operation Align", "ICON7446.bmp", "ICON_16_BLANK")]^C^C_align
ID_Explode     [_Button("Explode", "ICON_16_EXPLOD", "ICON_24_EXPLOD")]^C^C_explode
ID_UserButton_3 [_Button("mview", "ICON5890.bmp", "ICON_16_BLANK")]^C^Cmview
ID_UserButton_4 [_Button("vports", "ICON6729.bmp", "ICON_16_BLANK")]^C^C-vports
**BYEBYE1
**TB_SOLIDS_EDITING
ID_byebye1_0   [_Toolbar("Solids Editing", _Left, _Show, 1, 0, 1)]
ID_Union       [_Button("Union", "ICON_16_UNION", "ICON_24_UNION")]^C^C_union
ID_Subtract    [_Button("Subtract", "ICON_16_SUBTRA", "ICON_24_SUBTRA")]^C^C_subtract
ID_Intersect   [_Button("Intersect", "ICON_16_INTERS", "ICON_24_INTERS")]^C^C_intersect
ID_FaceExtru_0 [_Button("Extrude Faces", "ICON_16_EXTRUD", "ICON_16_EXTRUD")]^C^C_solidedit _face
_extrude
ID_FaceMove_0  [_Button("Move Faces", "ICON_16_MOVEFACE", "ICON_16_MOVEFACE")]^C^C_solidedit _face
_move
ID_FaceOffse_0 [_Button("Offset Faces", "ICON_16_OFFSETFACE", "ICON_16_OFFSETFACE")]^C^C_solidedit
_face _offset
ID_FaceDel_0   [_Button("Delete Faces", "ICON_16_DELFACE", "ICON_16_DELFACE")]^C^C_solidedit _face
_delete
ID_FaceRotat_0 [_Button("Rotate Faces", "ICON_16_ROTATEFACE", "ICON_16_ROTATEFACE")]^C^C_solidedit
_face _rotate
ID_FaceTaper_0 [_Button("Taper Faces", "ICON_16_TAPER", "ICON_16_TAPER")]^C^C_solidedit _face _taper
ID_FaceColor_0 [_Button("Color Faces", "ICON_16_COLORFACE", "ICON_16_COLORFACE")]^C^C_solidedit _face
_color
ID_FaceCopy_0  [_Button("Copy Faces", "ICON_16_COPYFACE", "ICON_16_COPYFACE")]^C^C_solidedit _face
_copy
ID_EdgeColor_0 [_Button("Color Edges", "ICON_16_COLOREDGE", "ICON_16_COLOREDGE")]^C^C_solidedit _edge
_color
ID_EdgeCopy_0  [_Button("Copy Edges", "ICON_16_COPYEDGE", "ICON_16_COPYEDGE")]^C^C_solidedit _edge
_copy
ID_Imprint_0   [_Button("Imprint", "ICON_16_IMPRINT", "ICON_16_IMPRINT")]^C^C_solidedit _body _imprint
ID_BodyCln_0   [_Button("Clean", "ICON_16_CLEAN", "ICON_16_CLEAN")]^C^C_solidedit _body _clean
ID_Separate_0  [_Button("Separate", "ICON_16_SEPARATE", "ICON_16_SEPARATE")]^C^C_solidedit _body
_separate
ID_Shell_0     [_Button("Shell", "ICON_16_SHELL", "ICON_16_SHELL")]^C^C_solidedit _body _shell
ID_BodyChk_0   [_Button("Check", "ICON_16_CHECK", "ICON_16_CHECK")]^C^C_solidedit _body _check
**TOOLBAR1
ID_Toolbar1_0  [_Toolbar("Toolbar1", _Floating, _Hide, 811, 326, 1)]
ID_TbLayouts_1 [_Flyout("Layouts", ICON_16_LAYNEW, ICON_16_LAYNEW, _OtherIcon, ACAD.TB_LAYOUTS)]
***IMAGE
**IMAGE_3DOBJECTS
[三维对象]
[acad(Box3d,长方体)]^C^Cai_box
[acad(Pyramid,方锥体)]^C^Cai_pyramid
[acad(Wedge,楔体)]^C^Cai_wedge
[acad(Dome,圆顶)]^C^Cai_dome
[acad(Sphere,球体)]^C^Cai_sphere
[acad(Cone,圆锥体)]^C^Cai_cone
[acad(Torus,圆环体)]^C^Cai_torus
[acad(Dish,圆底)]^C^Cai_dish
[acad(Mesh,网格)]^C^Cai_mesh
**ICON
**FACES
[顶棚基面]
[object(face1)]^C^Cface1
[object(face2)]^C^Cface2
[object(face3)]^C^Cface3
[object(face4)]^C^Cface4
**POLY
[设置曲面平滑类型]
[acad(pm-quad,Quadric Fit Polymesh)]'surftype 5
[acad(pm-cubic,Cubic Fit Polymesh)]'surftype 6
[acad(pm-bezr,Bezier Fit Polymesh)]'surftype 8
[acad(pl-quad,Quadric Fit Polyline)]'splinetype 5
[acad(pl-cubic,Cubic Fit Polyline)]'splinetype 6
***SCREEN
**S
[圆方设计]$S=S
[回退]^C^Cu
[帮助]'HELP
[编辑]$S=clear $S=modify
[相机]$S=clear $S=camera
[缩放]$S=clear $S=zoom
[显示]$S=clear $S=view
**CLEAR 11
**ZOOM 11
[放大]'zoom 1.66x
[缩小]'zoom 0.6x
[窗口]'zoom w
[前一个]'zoom p
[扫视]'pan
[大小切换]^C^Cswitchview
[最大化]^C^Cmaxview
[恢复]^C^Crestoreview
[全图]^C^Czoom e
**CAMERA 11
[新建]^C^Cc_newcam
[移动]^C^Cc_cam_move
[改焦距]^C^Cc_chcam
[显示]^C^Cc_show
**MODIFY 11
[移动]^C^Cc_move
[旋转]^C^Cc_rotate
[改色]^C^Cchange_color
[复制]^C^Cc_copy
[镜象]^C^Cc_mirror
[阵列]^C^Cc_array
[螺旋]^C^Csparray
[拉伸]^C^Cc_stretch
[打断]^C^Cbreak
[修剪]^C^Cc_trim
[围栏修剪]^C^CFenceTrim
[延长]^C^Cc_extend
[等距]^C^Cc_offset
[圆角]^C^Cfillet
[删除]^C^Cc_erase
[墙清理]^C^Cc_clean
**VIEW 11
[消 隐]^C^Chide
[重生成]^C^Cregen
[重 画]^C^Credraw
[显示立体]^C^Cvplayer t 3d_mesh;;;
[隐藏立体]^C^Cvplayer f 3d_mesh;;;
[设置视窗]^C^Cviewconfig
[顶视图]^C^Ctopview
[底视图]^C^Cbotview
[前视图]^C^Cfrnview
[后视图]^C^Cbakview
[左视图]^C^Clefview
[右视图]^C^Crigview
[三维视图]^C^Cusrview
***HELPSTRINGS
ID_TBLAYOUTS_1 [Layouts Toolbar]
ID_SHELL_0     [Creates a hollow, thin wall with a specified thickness on a solid object:  SOLIDEDIT]
ID_BODYCLN_0   [Removes all redundant edges and vertices on a solid object:  SOLIDEDIT]
ID_BODYCHK_0   [Validates a 3D solid object as a valid ACIS solid:  SOLIDEDIT]
ID_PASTECLIP_0 [Inserts data from the Windows Clipboard:  PASTECLIP]
ID_MATCHPROP_0 [Applies the properties of a selected object to other objects:  MATCHPROP]
ID_FACEMOVE_0  [Moves selected faces on a solid object to a specified height or distance:  SOLIDEDIT]
ID_TBINQUIRY_0 [Inquiry Toolbar]
ID_FACECOLOR_0 [Changes the color of individual faces on a solid object:  SOLIDEDIT]
ID_FACEROTAT_0 [Rotates one or more faces on a solid object around a specified axis:  SOLIDEDIT]
ID_FACEEXTRU_0 [Extrudes selected faces on a solid object to a specified height or along a path:
SOLIDEDIT]
ID_FACECOPY_0  [Copies faces on a solid object as a region or a solid body:  SOLIDEDIT]
ID_JUSTIFYTE_0 [Sets justification for selected text:  JUSTIFYTEXT]
ID_IMPRINT_0   [Imprints geometry on a face of a solid object:  SOLIDEDIT]
ID_SCALETEXT_0 [Scales selected text objects:  SCALETEXT]
ID_ALIGN_0     [Aligns objects with other objects in 2D and 3D:  ALIGN]
ID_PREFERENC_0 [Customizes settings:  OPTIONS]
ID_EDGECOLOR_0 [Changes the color of individual edges on a solid object:  SOLIDEDIT]
ID_FACETAPER_0 [Tapers faces on a solid object with a specified angle:  SOLIDEDIT]
ID_USERBUTTON_0 [调用家具模块]
ID_USERBUTTON_1 [屏风桌板]
ID_SEPARATE_0  [Separates 3D solid objects with disjointed volumes into independent 3D solid objects:
SOLIDEDIT]
ID_FACEDEL_0   [Deletes or removes faces, including fillets or chamfers on a solid object:  SOLIDEDIT]
ID_DDINSERT_0  [Inserts a block or a drawing in the current drawing:  INSERT]
ID_ROTATE3D_0  [Moves objects about a three-dimensional axis:  ROTATE3D]
ID_USERBUTTON_2 [设计屏风]
ID_COPYCLIP_0  [Copies objects to the Windows Clipboard:  COPYCLIP]
ID_USERBUTTON_3 [mview]
ID_EDGECOPY_0  [Copies 3D edges on a solid object as an arc, circle, ellipse, line, or spline:
SOLIDEDIT]
ID_USERBUTTON_4 [vports]
ID_TBLAYOUTS_0 [Layouts Toolbar]
ID_FACEOFFSE_0 [Equally offsets faces on a solid object by a specified distance or point:  SOLIDEDIT]
//      End of AutoCAD menu file - C:\Fdm2000\System\FDM.mns
已领礼包: 145个
发表于 2002-8-30 13:12:44 | 显示全部楼层
修改后的菜单,你用用 MENU 命令加载一次MNU文件,以后就好了。
 楼主| 发表于 2002-8-30 16:27:33 | 显示全部楼层
老大就是高手,高手就是老大
原来在options里加载没有用,一定要用MENULOAD才有用!谢谢了。
已领礼包: 145个
发表于 2002-8-30 17:35:46 | 显示全部楼层
最初由 byebye11 发布
[B]老大就是高手,高手就是老大
原来在options里加载没有用,一定要用MENULOAD才有用!谢谢了。 [/B]
不要这样说,来这里的都是朋友,真诚的交流。
其实,你只要把同名的.mnc,.mns文件删除,启动后,自动替你编译的。
发表于 2002-9-2 12:44:37 | 显示全部楼层
用MENU加载应该可以吧
发表于 2002-9-27 08:54:03 | 显示全部楼层
用menu命令有点问题:第三方软件自己添加
的菜单项会消失,需手工重新加载。
发表于 2002-10-16 03:50:33 | 显示全部楼层
用 menuload 制作「部分菜单」,也许会是比较好的选择。透过 AutoLISP 功能,可以自动加载、自动卸载自订的菜单。
全宏工作室  http://www.taconet.com.tw/chuanhun/
已领礼包: 24个
发表于 2002-10-16 12:00:35 | 显示全部楼层
你看看AutoCAD的联机帮助中的自定义参考中的关于菜单的这些内容就知道*mns,*.mnu,*.mnc,*.mnr有何区别了。。。
已领礼包: 24个
发表于 2002-10-16 12:03:34 | 显示全部楼层
我的“钱”。。。。 8-P
拍照留念....
发表于 2002-11-4 20:37:57 | 显示全部楼层
应该修改*.mun文件,然后用menuload加载
GMT+8, 2026-11-2 23:10 , Processed in 0.695370 second(s), 51 queries , Gzip On.
