查看: 1002|回复: 0
[求助]:谁能帮帮我,help
发表于 2006-12-15 21:10:30 | 显示全部楼层 |阅读模式
由于我要用别人的lsp程序,在acad2007.lsp内加入了下面所示一部分内容
  (setvar "modemacro" (strcat
;    "$(getvar,clayer)"
;    " Ti_$(substr,$(rtos,$(getvar,cdate),2,6),10,2):"
;    "$(substr,$(rtos,$(getvar,cdate),2,6),12)"
    " BL_$(rtos,$(getvar,userr1),2,0)"
    " $(getvar,textstyle)_$(getvar,textsize)"
    " Fi_$(getvar,filletrad)"
    " Pl_$(getvar,plinewid)"
    " Df_$(getvar,dimlfac)"
    "$(if,$(>,$(getvar,osmode),0), Os_$(getvar,osmode))"))
;    "$(if,$(>,$(getvar,orthomode),0), Ot)"))
;    "$(if,$(>,$(getvar,snapmode),0), Sn)"
;    " $(substr,$(getvar,dwgname),4)")
;    " $(getvar,cmdnames)"))
  (setq fh78 0 fh65 0 fh72 0 fh85 0 fh70 370)
  (setq bl (getvar "USERR1"))
  (if (= bl 0.0) (setq bl 1.0))
  (setq blx (/ bl 100.0))
  (setq d0 (* bl 10) d1 (* bl 15) d2 (* bl 43) d3 (* bl 47))
  (setq d4 (* bl 15) d5 (* bl 25) d6 (* bl 35) d7 (* bl 51) d8 (* bl 37))
  (setvar "textsize" (* bl 2.5))
  (setvar "DIMgap" (* bl 0.8))
;  (setvar "DIMtsty" "RMS")
  (setvar "DIMdec" 0)
  (setvar "DIMtdec" 0)
  (setvar "DIMfit" 5)
(defun *error* (msg)
  (princ (strcat "\nerror: " msg "\n"))
  (princ)
然后加载上的lsp就可以正常运行了,不过cad的最下面出现了如下图所示的东西 就是坐标前多了一排东西,不知道是什么意思,怎么能去掉还能不影响cad及lsp功能的正常使用
GMT+8, 2026-11-22 09:35 , Processed in 0.330043 second(s), 10 queries , Gzip On, File On.
