查看: 2418|回复: 1
[每日一码] [LISP程序]:地形图中的计曲线注记
发表于 2010-1-1 19:54:45 | 显示全部楼层 |阅读模式
  1. ;;;用于地形图绘制中的计曲线注记,提取标高并按指定角度注于线中间.
  2. ;;;wkq004QQ278416560
  3. (defun c:JQXZJ (/ osm sslist pickpoint textpoint jqxelev)
  4.   (setvar "cmdecho" 0)
  5.   (setq osm (getvar "osmode"))
  6.   (setvar "osmode" 0)
  7.   (command "_style" "标注字体样式" "黑体" "9" "1" "0" "N" "N")
  8.   (setq sslist (entsel "指定计曲线上的标注位置: "))
  9.   (setq pickpoint (cadr sslist))
  10.   (setq textpoint (osnap pickpoint "nea"))
  11.   (setq textpoint (list (car textpoint) (cadr textpoint)))
  12.   (setq jqxelev (fix (cdr (assoc 38 (entget (car sslist))))))
  13.   (command "_text" "m" textpoint 0 jqxelev)
  14.   (princ "/n指定字头方向: ")
  15.   (setvar "osmode" 512)
  16.   ;;最近点捉
  17.   (command "rotate" (ssadd (entlast)) "" textpoint pause)
  18.   ;;pause在绘制过程中等待用户交互操作.
  19.   (setvar "cmdecho" 1)
  20.   (setvar "osmode" osm)
  21.   (princ)
  22. )
发表于 2020-7-26 19:08:02 | 显示全部楼层
谢谢版主分享
发表于 2022-4-12 08:21:32 | 显示全部楼层
感谢楼主分享!
GMT+8, 2026-11-22 08:07 , Processed in 0.322962 second(s), 14 queries , Gzip On, File On.
