查看: 1910|回复: 2
[求助] [求助]:帮我看看这个lsp程序是什么地方的问题
发表于 2009-6-22 19:45:13 | 显示全部楼层 |阅读模式
(vmon)
(defun c:main()
(load "dfh")
(load "lfhdraw")
(load "lfhdraw1")
(load "lfhdraw2")
(load "lfhdraw3")
(load "lfhdraw4")
(load "lfhmain")
(load "textfh")
(load "pmfh")
(load "Qmfh")
(load "smfh")
(load "MyHelp")
(initget (+ 1 2 4))
(setq scale (getreal "\n输入比例尺(500/2000):"))
(setq as (strcat "1:" (rtos scale 2 2)))
(setq scl (/ scale 1000.0))
(setvar "ltscale" scl)
(setvar "plinegen" 1)
(setvar "modemacro" as)
(princ "\n   E_Map自动化符号化程序-武汉市勘测院测量一室 99.8")
;(princ "\n          帮助请输入MYHELP")
(princ)
加载说是函数错误?
发表于 2009-6-23 08:43:36 | 显示全部楼层
只能在您的机了子上才查得到问题所在
您这样子依序在命令列调试....
Commend: (load "dfh")
Commend: (load "lfhdraw")
Commend: (load "lfhdraw1")
Commend: (load "MyHelp")
直到出现错误....
 楼主| 发表于 2009-6-23 15:41:30 | 显示全部楼层
这个lsp程序时在r14下运行的
它的原程序是:
(load "dfh")
(load "lfhdraw")
(load "lfhdraw1")
(load "lfhdraw2")
(load "lfhdraw3")
(load "lfhdraw4")
(load "lfhmain")
(load "textfh")
(load "pmfh")
(load "Qmfh")
(load "smfh")
(load "MyHelp")
(initget (+ 1 2 4))
(princ)
没有命令,有些是我加的,要怎么改才能在cad2004上运行。
GMT+8, 2026-11-22 08:07 , Processed in 0.266860 second(s), 14 queries , Gzip On, File On.
