查看: 1470|回复: 1
[求助] [求助]:(自动分层)指定命令到图层函数错在那里?
发表于 2007-4-19 12:06:06 | 显示全部楼层 |阅读模式
指定命令到图层函数错在那里(自动分层)谁能完善它!!!
    (defun c:da( / cly oldtev oldcmd)
    (setq cly (getvar"clayer"))
    (if (= nil (tblsearch "layer" "dim")) (command"-layer" "m" "dim") (setvar"clayer" "dim"))
    (setq oldtev (getvar"texteval"))
    (setq oldcmd (getvar"cmdecho"))
    (setvar"cmdecho" 1)
    (setvar "texteval" 1)
    (command"BHATCH")
    (while (/= 0 (getvar"cmdactive"))
    (command pause)
    (setvar "clayer" cly)
    (setvar"texteval" oldtev)
    (setvar"cmdecho" oldcmd)
    (princ)
    ;不过,标注的时候不要点右键或按ESC,否则不能返回当前层
    ;当然,你可以加一个错误处理,即使点右键或按ESC也能返回当前层
    (defun *error*(msg)
    (if (/= nil cly)
    (progn
    (setvar"clayer" cly)
    (setq cly nil)
就是第一次运行命令会出现:
『da BHATCH
无效的选项关键字。
输入选项
[?/生成(M)/设置(S)/新建(N)/开(ON)/关(OFF)/颜色(C)/线型(L)/线宽(LW)/打印(P)/冻结(
F)/解冻(T)/锁定(LO)/解锁(U)/状态(A)]: *取消*』的提示
第二次就正常!
显示为:
『DA BHATCH
当前填充图案:  ANGLE
指定内部点或
[特性(P)/选择对象(S)/绘图边界(W)/删除边界(B)/高级(A)/绘图次序(DR)/原点(O)]:
*取消*』
发表于 2007-4-19 13:51:28 | 显示全部楼层
  (command "-layer" "m" "dim")
  (setvar "clayer" "dim")
  (command "-layer" "m" "dim" "")
GMT+8, 2026-11-22 09:33 , Processed in 0.339331 second(s), 12 queries , Gzip On, File On.
