查看: 3098|回复: 12
把文字加删除线[分享]
发表于 2002-1-24 20:07:54 | 显示全部楼层 |阅读模式
  1. ;;;把文字加删除线
  2. ;;;程序设计:赖云龙;;;
  3. ;;;---------------;;;
  4. (defun C:MT  (/             HOLDOSMODE           HOLDCLAYER         SS        TEXTM  TEXTM1
  5.               M10    M40    M42           M43          M50         M71        PT1    PT2
  6.               PT3    PT4    PT5           PT6          PT7         PT8        PT9    RT
  7.               TB     DIST   DIST1  D          ANG
  8.              )
  9.   (command "_.UNDO" "BE")
  10.   (setq HOLDOSMODE (getvar "OSMODE"))
  11.   (setq HOLDCLAYER (getvar "CLAYER"))
  12.   (setvar "OSMODE" 0)
  13.   (if (= (tblsearch "LAYER" "DIM") NIL)
  14.     (command "_.layer" "m"         "dim"           "c"             "cyan"
  15.              ""               "lt"         "continuous"             ""
  16.              ""
  17.             )
  18.   )
  19.   (setvar "CLAYER" HOLDCLAYER)
  20.   (setq TEXTM1 (car (nentsel)))
  21.   (setq TEXTM (entget TEXTM1))
  22.   (cond
  23.     ((= "MTEXT" (cdr (assoc 0 TEXTM)))
  24.      (command "_.ucs" "W")
  25.      (setq M10 (cdr (assoc 10 TEXTM)))
  26.      (setq M40 (cdr (assoc 40 TEXTM)))
  27.      (setq M42 (cdr (assoc 42 TEXTM)))
  28.      (setq M43 (cdr (assoc 43 TEXTM)))
  29.      (setq M50 (cdr (assoc 50 TEXTM)))
  30.      (setq M71 (cdr (assoc 71 TEXTM)))
  31.      (setq PT9 (list (+ (car M10) M42) (cadr M10) (caddr M10)))
  32.      (setq PT3 (list (car PT9) (+ (cadr PT9) M43) (caddr PT9)))
  33.      (setq PT1 (list (car M10) (+ (cadr M10) M43) (caddr M10)))
  34.      (setq PT8 (list (+ (car M10) (/ M42 2)) (cadr M10) (caddr M10)))
  35.      (setq PT4 (list (car M10) (+ (cadr M10) (/ M43 2)) (caddr M10)))
  36.      (setq PT2 (list (+ (car M10) (/ M42 2))
  37.                      (+ (cadr M10) M43)
  38.                      (caddr M10)
  39.                )
  40.      )
  41.      (setq PT6 (list (+ (car M10) M42)
  42.                      (+ (cadr M10) (/ M43 2))
  43.                      (caddr M10)
  44.                )
  45.      )
  46.      (setq SS (ssadd))
  47.      (setq ANG (angle M10 PT1))
  48.      (setq M101 (polar M10 ANG (/ M40 3.0)))
  49.      (setq PT91 (polar PT9 ANG (/ M40 3.0)))
  50.      (command "_.LINE" M101 PT91 "")
  51.      (ssadd (entlast) SS)
  52.      (setq SS1 (entlast))
  53.      (command "_.OFFSET" (/ M40 3.0) (entlast) M101 "")
  54.      (ssadd (entlast) SS)
  55.      (setq PT5 (inters M10 PT3 PT9 PT1))
  56.      (cond
  57.        ((= 1 M71) (command "._move" SS "" PT1 M10)) ;1 = Top left
  58.        ((= 2 M71) (command "._move" SS "" PT2 M10)) ;2 = Top center
  59.        ((= 3 M71) (command "._move" SS "" PT3 M10)) ;3 = Top right
  60.        ((= 4 M71) (command "._move" SS "" PT4 M10)) ;4 = Middle left
  61.        ((= 5 M71) (command "._move" SS "" PT5 M10)) ;5 = Middle center
  62.        ((= 6 M71) (command "._move" SS "" PT6 M10)) ;6 = Middle right
  63. ;;;    ((= 7 M71) (command "._move" SS "" M10 M10)) ;7 = Bottom left
  64.        ((= 8 M71) (command "._move" SS "" PT8 M10)) ;8 = Bottom center
  65.        ((= 9 M71) (command "._move" SS "" PT9 M10)) ;9 = Bottom right
  66.      )
  67.      (command "_.ROTATE" SS "" M10 (/ (* 180 M50) pi))
  68.      (command "_.CHANGE" SS "" "P" "LA" "DIM" "C" 6 "")
  69.      (setq DIST (* M40 1.66))
  70.      (setq DIST1 (fix (/ M43 DIST)))
  71.      (setq D 1)
  72.      (repeat DIST1
  73.        (command        "_.COPY"
  74.                 SS
  75.                 ""
  76.                 M10
  77.                 (polar M10 (+ M50 (/ pi 2)) (* DIST D))
  78.        )
  79.        (setq D (+ 1 D))
  80.      )
  81.      (command "_.ucs" "p")
  82.     )
  83.     ((= "TEXT" (cdr (assoc 0 TEXTM)))
  84.      (command "_.ucs" "Object" TEXTM1)
  85.      (setq TB (textbox (list (cons -1 TEXTM1))))
  86.      (setq PT1 (car TB)
  87.            PT2 (cadr TB)
  88.            PT3 (list (car PT1) (cadr PT2))
  89.            PT4 (list (car PT2) (cadr PT1))
  90.      )
  91.      (setq DIST (/ (distance PT1 PT3) 3.0))
  92.      (setq ANG (angle PT1 PT3))
  93.      (setq SS (ssadd))
  94.      (command "_.LINE" PT1 PT4 "")
  95.      (ssadd (entlast) SS)
  96.      (command "_.MOVE"
  97.               (entlast)
  98.               ""
  99.               "0,0"
  100.               (polar '(0 0) ANG DIST)
  101.      )
  102.      (command "_.OFFSET" DIST (entlast) PT3 "")
  103.      (ssadd (entlast) SS)
  104.      (command "_.CHANGE" SS "" "P" "LA" "DIM" "C" 6 "")
  105.      (command "_.ucs" "p")
  106.     )
  107.   )
  108.   (setvar "OSMODE" HOLDOSMODE)
  109.   (command "_.UNDO" "END")
  110.   (princ)
  111. )
已领礼包: 8个
发表于 2002-1-26 09:50:07 | 显示全部楼层
  1. (Defun c:ourwjc1        (/     count lyx   doc         ben   handles           l1         l2
  2.                  lyx   lyy   count x1         x2    y1    y2           ELI         pp
  3.                  ent
  4.                 )
  5.   (setq pp nil)
  6.   (setq count 0)
  7.   (setq lyx nil)
  8.   (setq lyy nil)
  9.   (vl-load-com)
  10.   (SetQ doc (VLA-Get-ActiveDocument (VLAX-Get-ACAD-Object)))
  11.   (prompt "\n 请选择实体:..")
  12.   (setq ben (ssget))
  13.   (if ben
  14.     (progn
  15.       (while (< count (sslength ben))
  16.         (setq ent (ssname ben count))
  17.         (SetQ
  18.           handles
  19.            (Cdr (Assoc 5 (EntGet ent)))
  20.         )
  21.         (VLA-GetBoundingBox
  22.           (VLA-HandleToObject doc handles)
  23.           'llp
  24.           'urp
  25.         )
  26.         (setq l1 (VLAX-SafeArray->List llp))
  27.         (setq lyx (cons (Car l1) lyx))
  28.         (setq lyy (cons (Cadr l1) lyy))
  29.         (setq l2 (VLAX-SafeArray->List urp))
  30.         (setq lyx (cons (Car l2) lyx))
  31.         (setq lyy (cons (Cadr l2) lyy))
  32.         (setq count (1+ count))
  33.       )
  34.       (setq lyx (vl-sort lyx '<))
  35.       (setq lyy (vl-sort lyy '<))
  36.       (setq x1 (nth 0 lyx)
  37.             x2 (last lyx)
  38.       )
  39.       (setq y1 (nth 0 lyy)
  40.             y2 (last lyy)
  41.       )
  42. ;;;      (setq p1 (list x1 y2)
  43. ;;;            p2 (list x1 y1)
  44. ;;;      )
  45. ;;;      (setq eli        (list (cons 0 "LINE")
  46. ;;;                      (cons 8 "外框")
  47. ;;;                      (cons 10 P1)
  48. ;;;                      (cons 11 P2)
  49. ;;;                )
  50. ;;;      )
  51. ;;;      (entmake eli)
  52. ;;;      (setq p1 (list x2 y1))
  53. ;;;      (setq eli        (list (cons 0 "LINE")
  54. ;;;                      (cons 8 "外框")
  55. ;;;                      (cons 10 P1)
  56. ;;;                      (cons 11 P2)
  57. ;;;                )
  58. ;;;      )
  59. ;;;      (entmake eli)
  60. ;;;      (setq p2 (list x2 y2))
  61. ;;;      (setq eli        (list (cons 0 "LINE")
  62. ;;;                      (cons 8 "外框")
  63. ;;;                      (cons 10 P1)
  64. ;;;                      (cons 11 P2)
  65. ;;;                )
  66. ;;;      )
  67. ;;;      (entmake eli)
  68. ;;;      (setq p1 (list x1 y2))
  69. ;;;      (setq eli        (list (cons 0 "LINE")
  70. ;;;                      (cons 8 "外框")
  71. ;;;                      (cons 10 P1)
  72. ;;;                      (cons 11 P2)
  73. ;;;                )
  74. ;;;      )
  75. ;;;      (entmake eli)
  76. ;;;      (setq p1 nil
  77. ;;;            p2 nil
  78. ;;;      )
  79.       (setq p1 (list x1 y1)
  80.             p2 (list x2 y2)
  81.       )
  82.       (setlay "取消" 2 "HIDDEN")
  83.       (setq eli        (list (cons 0 "LINE")
  84.                       (cons 8 "取消")
  85.                       (cons 10 P1)
  86.                       (cons 11 P2)
  87.                 )
  88.       )
  89.       (entmake eli)
  90.       (setq p1 (list x1 Y2)
  91.             p2 (list x2 y1)
  92.       )
  93.       (setq eli        (list (cons 0 "LINE")
  94.                       (cons 8 "取消")
  95.                       (cons 10 P1)
  96.                       (cons 11 P2)
  97.                 )
  98.       )
  99.       (entmake eli)
  100.     )
  101.                                         ;progn
  102.     (prompt "\n 未选取到实体:..")
  103.   )
  104.   (SETQ        BEN NIL
  105.         ent nil
  106.         handles        nil
  107.         llp nil
  108.         urp nil
  109.         l1 nil
  110.         lyx nil
  111.         lyy nil
  112.         l2 nil
  113.         x1 nil
  114.         x2 nil
  115.         y1 nil
  116.         y2 nil
  117.         l nil
  118.         pp nil
  119.         ls nil
  120.         p1 nil
  121.         p2 nil
  122.         eli nil
  123.   )
  124.   (princ)
  125. )
  126. ;;;
已领礼包: 8个
发表于 2002-1-26 11:16:35 | 显示全部楼层
呵呵,文字.实体都可以
发表于 2005-2-18 09:23:27 | 显示全部楼层
修改图的时候可以用到,很直观反映修改前后的情况
发表于 2005-6-11 10:26:49 | 显示全部楼层
上面两个,用哪一个?
发表于 2005-6-15 11:23:57 | 显示全部楼层
呵呵,文字.实体都可以
好像不能使用
请选择实体:..
选择对象: 找到 1 个
选择对象:
no function definition: SETLAY
发表于 2005-7-3 22:55:57 | 显示全部楼层
第一个程序只对文字有效,第二个对各种实体都有效,但是我也出现了“no function definition: SETLAY ”的问题,我干脆把SETLAY这句取消就可以了,不知道这句的作用时什么。
发表于 2005-11-13 23:36:41 | 显示全部楼层
好东西。已收藏
发表于 2005-12-18 11:51:18 | 显示全部楼层
 我也做一下,很好的东西哦!
发表于 2005-12-18 11:58:13 | 显示全部楼层
可以给文字(单行文本)加单下划线、双下划线、双删除线和矩形外框
http://www.xdcad.net/forum/showthread.php?s=&threadid=498681
发表于 2006-8-22 15:30:57 | 显示全部楼层
好像用处不是很大啊
发表于 2007-5-1 19:44:06 | 显示全部楼层
实体可以?怎么不行?
发表于 2007-5-28 09:26:05 | 显示全部楼层
直接画不好吗????
GMT+8, 2026-11-3 00:57 , Processed in 0.515538 second(s), 56 queries , Gzip On.
