查看: 1486|回复: 0
所有区块全部炸开(有待改进)[试用]
发表于 2002-1-25 12:55:45 | 显示全部楼层 |阅读模式
  1. ;;;所有区块全部炸开(效率不好,有待改进)
  2. ;;;程序设计:赖云龙;;;
  3. ;;;---------------;;;
  4. (defun C:E3DB (/ K QQ1 QQ HOLDECHO HOLDBLIP A AA AAA AL LAY)
  5.   (command "_.undo" "_group")
  6.   (setq HOLDECHO (getvar "cmdecho"))
  7.   (setq HOLDBLIP (getvar "blipmode"))
  8.   (setvar "cmdecho" 0)
  9.   (setvar "blipmode" 0)
  10.   (setq A (getstring "\n所有区块(A)/<选择对象>: "))
  11.   (if (/= A "")
  12.     (progn
  13.       (if (= (getvar "TILEMODE") 1)
  14.         (setq AA (ssget "x" (list (cons 0 "INSERT") (cons 67 0))))
  15.         (setq AA (ssget "x" (list (cons 0 "INSERT") (cons 67 1))))
  16.       )
  17.     )
  18.     (setq AA (ssget '((0 . "INSERT"))))
  19.   )
  20.   (if (/= AA NIL)
  21.     (progn
  22.       (setq QQ1 (ssadd))
  23.       (setq LAY 1)
  24.       (while (/= QQ 0)
  25.         (prompt
  26.           "\n                                 爆开区块要花点时间处理....."
  27.         )
  28.         (setq AL (sslength AA))
  29.         (setq QQ AL)
  30.         (repeat        AL
  31.           (prompt (strcat "\r第"
  32.                           (itoa LAY)
  33.                           "层共 "
  34.                           (itoa QQ)
  35.                           " 个区块 >>> 余"
  36.                           (itoa AL)
  37.                           "     "
  38.                   )
  39.           )
  40.           (setq AAA (ssname AA (- AL 1)))
  41.           (if
  42.             (/=        (cdr
  43.                   (assoc 70
  44.                          (tblsearch "layer" (cdr (assoc 8 (entget AAA))))
  45.                   )
  46.                 )
  47.                 4
  48.             )
  49.              (progn
  50.                (command "_.EXPLODE" AAA)
  51.                (setq WWW (ssget "p" '((0 . "INSERT"))))
  52.                (setq K 0)
  53.                (if (/= WWW NIL)
  54.                  (repeat (sslength WWW)
  55.                    (ssadd (ssname WWW K) QQ1)
  56.                    (setq K (1+ K))
  57.                  )
  58.                )
  59.              )
  60.              (progn
  61.                (prompt (strcat "\n区块""
  62.                                (cdr (assoc 2 (entget AAA)))
  63.                                ""  因在锁护图层""
  64.                                (cdr (assoc 8 (entget AAA)))
  65.                                ""上,故无法炸开"
  66.                        )
  67.                )
  68.                (prompt
  69.                  "\n                                 爆开区块要花点时间处理....."
  70.                )
  71.              )
  72.           )
  73.           (setq AL (1- AL))
  74.         )
  75.         (setq LAY (1+ LAY))
  76.         (setq QQ (sslength QQ1))
  77.         (setq AA QQ1)
  78.         (setq QQ1 (ssadd))
  79.       )
  80.     )
  81.   )
  82.   (setvar "blipmode" HOLDBLIP)
  83.   (setvar "cmdecho" HOLDECHO)
  84.   (command "_.undo" "_end")
  85.   (princ)
  86. )
;|以下供参考效率比较好
        (while
          (setq AA (ssget "X" (list (cons 0 "INSERT") (cons 67 0))))
           (command "_.EXPLODE" AA)
        (while
          (setq AA (ssget "X" (list (cons 0 "INSERT") (cons 67 1))))
GMT+8, 2026-11-22 11:01 , Processed in 0.316382 second(s), 11 queries , Gzip On, File On.
