查看: 1412|回复: 4
[讨论]:拖动选择集
发表于 2002-9-10 09:56:33 | 显示全部楼层 |阅读模式
我做了一个拖动选择集,但不知在下面 update()中还要加些什么,另外程序运行是出错,出错信息在附件中
class AsdkEllipse : public AcEdJig
class SelectionSet : public AcDbEntity
        AcDbObjectIdArray m_idArray;
        AcGeMatrix3d m_mat;
    public:
        void setTransform(const AcGeMatrix3d& mat)
                m_mat = mat;
        Acad::ErrorStatus setSelectionSet(const ads_name ss)
                long len;
                Acad::ErrorStatus es;;
                if (acedSSLength(ss,& len)!=RTNORM)
                        return Acad::eInvalidInput;
                        ads_name ename;
                        AcDbObjectId id;
                        for (int i=0;i < len;i++)
                        if (acedSSName(ss,i,ename)!=RTNORM)
                        if ((es=acdbGetObjectId(id,ename))!=Acad::eOk)
                        return es;
                        m_idArray.append(id);
                if (m_idArray.length()==0)
                        return Acad::eOk;
public :
        AsdkEllipse();
        void doIt();
        virtual DragStatus sampler();
        virtual Adesk::Boolean update();
        virtual AcDbEntity * entity()const;
private:
        SelectionSet pZFSSelect;
        AcGePoint3d m_point1,m_point2;
        ads_name m_name;
AsdkEllipse::AsdkEllipse()
void AsdkEllipse::doIt()
        if(acedSSGet(NULL,NULL,NULL,NULL,m_name)!=RTNORM)
                return;
        if(acedGetPoint(NULL,NULL,asDblArray(m_point1))!=RTNORM)
                return;
        pZFSSelect.setSelectionSet(m_name);
        AcEdJig::DragStatus stat=drag();
        append();
        acedSSFree(m_name);
AcEdJig::DragStatus AsdkEllipse::sampler()
        DragStatus stat;
        static AcGePoint3d p1;
        stat=acquirePoint(m_point2);
        if(m_point2!=p1)
                p1=m_point2;
        else if(stat==AcEdJig::kNormal)
                return AcEdJig::kNoChange;
        return stat;
Adesk::Boolean AsdkEllipse::update()
        AcGeMatrix3d mat;
        mat(0,0)=1,mat(0,1)=0,mat(0,2)=0,mat(0,3)=m_point2.x-m_point1.x;
        mat(1,0)=0,mat(1,1)=1,mat(1,2)=0,mat(1,3)=m_point2.y-m_point1.y;
        mat(2,0)=0,mat(2,1)=0,mat(2,2)=1,mat(2,3)=0;
        mat(3,0)=0,mat(3,1)=0,mat(3,2)=0,mat(3,3)=1;
        pZFSSelect.setTransform(mat);
        return Adesk::kTrue;
AcDbEntity * AsdkEllipse::entity()const
        return const_cast < AsdkEllipse::SelectionSet* >(&pZFSSelect);
void SUYxuanzedd()
        AsdkEllipse *pJig=new AsdkEllipse;
        pJig->doIt();
        delete pJig;
 楼主| 发表于 2002-9-10 10:35:08 | 显示全部楼层
我重做了一个,还是有错误,如果我不加“pLine->upgradeOpen();”提示另一个错误
public :
        AsdkEllipse();
        void doIt();
private:
        AcDbLine *pLine;
        ads_point p1;
        ads_name name1;
        AcDbObjectId objId;
        acedEntSel(NULL,name1,p1);
        acdbGetObjectId(objId,name1);
        acdbOpenAcDbEntity((AcDbEntity *&)pLine,objId,AcDb::kForRead);
        m_point1=asPnt3d(p1);
        append();
        DragStatus stat;
        stat=acquirePoint(m_point2,m_point1);
        if(m_point2!=p1)
                p1=m_point2;
        return stat;
        AcGeMatrix3d mat;
        pLine->transformBy(mat);
        return pLine;
void SUYtrddaa()
        AsdkEllipse *pJig=new AsdkEllipse();
        pJig->doIt();
        delete pJig;
发表于 2002-9-10 11:07:37 | 显示全部楼层
我估计,我以前做过一个和你的思路相似的东西,可以交流一下,不过,首先,你得说明一下,什么是拖动选择集?和AutoCAD中的什么命令相似
 楼主| 发表于 2002-9-10 13:36:50 | 显示全部楼层
类似move命令,选择一部分对象(自己给的,不需要用户选择),然后鼠标离动时,这些对象能跟着离动
发表于 2005-2-22 21:48:42 | 显示全部楼层
有点看不明白啊!
GMT+8, 2026-11-6 08:14 , Processed in 0.368136 second(s), 41 queries , Gzip On.
