查看: 1718|回复: 7
[求助]:怎么没人回我的AcEdjig啊?
发表于 2004-1-9 16:45:31 | 显示全部楼层 |阅读模式
我的jig实现block的拖动,可是总是别的arx使用acedCommand调用就死掉。发现实在update出的pBlockReference->setBlockTransform(xform);
函数如下
// This function is called to update the entity based on the
// input values.
Adesk::Boolean
AsdkMyJig::update()
    switch (mPromptCounter) {
    case 0:
                xform=moveForm;
        break;
    case 1:
                        xform.setToProduct(rotateForm,moveForm);
        break;
    // Now update the ellipse with the latest setting.
        return Adesk::kTrue;
// This function must be implemented to return a pointer to
// the entity being manipulated by the jig.
AcDbEntity*
AsdkMyJig::entity() const
    return pBlockReference;
发表于 2004-1-9 17:15:10 | 显示全部楼层
代码太少,看不出什么问题
 楼主| 发表于 2004-1-9 20:05:31 | 显示全部楼层
能给一个block的jig例子看么?
今天网络太慢,发不上来呢
class AsdkMyJig : public AcEdJig
public:
        AcDbObjectId m_ublkID;
    AsdkMyJig(AcDbObjectId blkId,AcGeVector3d& normal);
    virtual ~AsdkMyJig();
    void doIt();
    virtual DragStatus sampler();
    virtual Adesk::Boolean update();
    virtual AcDbEntity* entity() const;
private:
        AcGeMatrix3d rotateForm;
        AcGeMatrix3d moveForm;
        double mAng;
        AcDbBlockReference* pBlockReference;
        AcGeMatrix3d xform;
    AcGePoint3d mInsertPt;
    AcGeVector3d  mNormal;
    int mPromptCounter;
// The following defines the constructor that accepts a point to be used as the
// centerpoint of the ellipse and the current UCS normal
// vector to be used as the normal for the ellipse.  It
// also initializes the radius ratio to a small value so
// that during selection of the major axis, the ellipse
// will appear as a line.  The prompt counter is also
// initialized to 0.
AsdkMyJig::AsdkMyJig(AcDbObjectId blkId,AcGeVector3d& normal):mPromptCounter(0)//,mNormal(normal)
        m_ublkID=blkId;
        mNormal=normal;
        pBlockReference=NULL;
AsdkMyJig::~AsdkMyJig()
        pBlockReference->close();
// This function creates an AcDbEllipse object and gets the
// jig started acquiring the necessary info to properly fill
// it in.
void
AsdkMyJig::doIt()
        pBlockReference=new AcDbBlockReference;//(AcGePoint3d(0.0,0.0,0.0),m_ublkID);
        pBlockReference->setBlockTableRecord(m_ublkID);
        AcEdJig::DragStatus stat;
    // Get the major axis vector from the user.
    // At this time, mPromptCounter == 0
    setDispPrompt("\ninsert point: ");
    stat = drag();
    // Get the ellipse's radius ratio.
    mPromptCounter++;   // now == 1
    setDispPrompt("\ninput angle: ");
    stat = drag();
    // Now add the ellipse to the database's current space.
    append();
// This function is called by the drag function to
// acquire a sample input.
AcEdJig::DragStatus
AsdkMyJig::sampler()
    DragStatus stat;
    setUserInputControls((UserInputControls)
        (AcEdJig::kAccept3dCoordinates
                | AcEdJig::kNoNegativeResponseAccepted
                | AcEdJig::kNoZeroResponseAccepted));
    if (mPromptCounter == 0) {
        static AcGePoint3d axisPointTemp;
                const AcGePoint3d basePt(0.0,0.0,0.0);
        stat = acquirePoint(mInsertPt, basePt);
        if (axisPointTemp != mInsertPt)
            axisPointTemp = mInsertPt;
                        AcGeVector3d Vector(mInsertPt[X],mInsertPt[Y],mInsertPt[Z]);
                        moveForm.setToTranslation(Vector);
        else if (stat == AcEdJig::kNormal)
            return AcEdJig::kNoChange;
    else if (mPromptCounter == 1) {
                static double angTemp=-1;
                //AcGePoint3d basePnt=mInsertPt;
        stat = acquireAngle(mAng, mInsertPt);
        if (angTemp != mAng)
            angTemp = mAng;
                        rotateForm.setToRotation(mAng,mNormal,mInsertPt);
    return stat;
// input values.
Adesk::Boolean
AsdkMyJig::update()
    case 0:
                xform=moveForm;
        break;
    case 1:
        break;
AcDbEntity*
发表于 2004-1-18 11:15:47 | 显示全部楼层
块进行写操作时
需刷新图形缓冲,一般操作中,cad会自动进行,但在jig中不会(可以问问cad为什么),
也就是说,acquireAngle得不到正确结果.
如果jig玩\完了,你没刷新图形缓冲,用acedgetpoint函数将得不到正确结果,不信可试试!
 楼主| 发表于 2004-1-18 17:04:58 | 显示全部楼层
的确没错的。只能是使用了。getpoint才行了。有没有其他的函数直接刷新缓冲区呢?
发表于 2004-1-19 00:18:04 | 显示全部楼层
最初由 ssh 发布
[B]的确没错的。只能是使用了。getpoint才行了。有没有其他的函数直接刷新缓冲区呢? [/B]
我已经把JIG拖动Block的例子发到了你的email!!!
睡觉喽,明天回家过年去了!!三周上不了网了!!!
发表于 2005-2-22 21:41:36 | 显示全部楼层
楼上的那位大哥,可以把你的代码也发给我吗?谢谢
my-email:zqljgvc@hotmail.com
发表于 2005-8-27 23:36:19 | 显示全部楼层
我在写AcEdJig程序时,发现一个低级的错误,上来一看代码就解决了
谢谢ssh提供宝贵的代码支持
GMT+8, 2026-11-22 09:39 , Processed in 0.414479 second(s), 24 queries , Gzip On, File On.
