查看: 2043|回复: 0
[转贴]:lisp的一些标准函数的lisp实现
发表于 2002-9-11 21:18:07 | 显示全部楼层 |阅读模式
  1. [font=courier]
  2. ; 下面是common lisp代码(不是autolisp)
  3. ; The Lisp defined in McCarthy's 1960 paper, translated into CL.
  4. ; Assumes only quote, atom, eq, cons, car, cdr, cond.
  5. ; Bug reports to [email]lispcode@paulgraham.com[/email].
  6. (defun null. (x)
  7.   (eq x '()))
  8. (defun and. (x y)
  9.   (cond (x (cond (y 't) ('t '())))
  10.         ('t '())))
  11. (defun not. (x)
  12.   (cond (x '())
  13.         ('t 't)))
  14. (defun append. (x y)
  15.   (cond ((null. x) y)
  16.         ('t (cons (car x) (append. (cdr x) y)))))
  17. (defun pair. (x y)
  18.   (cond ((and. (null. x) (null. y)) '())
  19.         ((and. (not. (atom x)) (not. (atom y)))
  20.          (cons (list (car x) (car y))
  21.                (pair. (cdr x) (cdr y))))))
  22. (defun assoc. (x y)
  23.   (cond ((eq (caar y) x) (cadar y))
  24.         ('t (assoc. x (cdr y)))))
  25. (defun eval. (e a)
  26.   (cond
  27.     ((atom e) (assoc. e a))
  28.     ((atom (car e))
  29.      (cond
  30.        ((eq (car e) 'quote) (cadr e))
  31.        ((eq (car e) 'atom)  (atom   (eval. (cadr e) a)))
  32.        ((eq (car e) 'eq)    (eq     (eval. (cadr e) a)
  33.                                     (eval. (caddr e) a)))
  34.        ((eq (car e) 'car)   (car    (eval. (cadr e) a)))
  35.        ((eq (car e) 'cdr)   (cdr    (eval. (cadr e) a)))
  36.        ((eq (car e) 'cons)  (cons   (eval. (cadr e) a)
  37.                                     (eval. (caddr e) a)))
  38.        ((eq (car e) 'cond)  (evcon. (cdr e) a))
  39.        ('t (eval. (cons (assoc. (car e) a)
  40.                         (cdr e))
  41.                   a))))
  42.     ((eq (caar e) 'label)
  43.      (eval. (cons (caddar e) (cdr e))
  44.             (cons (list (cadar e) (car e)) a)))
  45.     ((eq (caar e) 'lambda)
  46.      (eval. (caddar e)
  47.             (append. (pair. (cadar e) (evlis. (cdr e) a))
  48.                      a)))))
  49. (defun evcon. (c a)
  50.   (cond ((eval. (caar c) a)
  51.          (eval. (cadar c) a))
  52.         ('t (evcon. (cdr c) a))))
  53. (defun evlis. (m a)
  54.   (cond ((null. m) '())
  55.         ('t (cons (eval.  (car m) a)
  56.                   (evlis. (cdr m) a)))))
GMT+8, 2026-11-3 02:43 , Processed in 0.444228 second(s), 31 queries , Gzip On.
