查看: 3074|回复: 8
[推荐]:lisp快速展点程序
发表于 2006-4-25 18:48:02 | 显示全部楼层 |阅读模式
LISP快速展点程序
;LISP展点程序
;展1000点:在HP(AMD Athlon64  3000+  256MB)电胶上仅耗时0.142秒;
;                    在金利(Geleron(R) CPU 2.40GHz 256MB)电胶上耗时0.882秒
;数据文件格式为:每一点的数据(点号、X、Y、H)为一行,用逗号或空格作为分隔符,即
;点号1  X1  Y1 H1   或者 点号1,  X1,  Y1, H1
;点号2  X2  Y2 H2   或者 点号2,  X2,  Y2, H2
;点号3  X3  Y3 H3   或者 点号3,  X3,  Y3, H3
;点号n  Xn  Yn Hn   或者 点号n,  Xn,  Yn, Hn1
(defun c:kszd()
    (setq  ff (open (getfiled "请选择要展点的数据文件" "" "txt" 2) "r")
           fhb nil  t0 (getvar "cdate")
           cm (getvar "cmdecho") os (getvar "osmode")
           tcm1 "高程注记"   tcm2 "点记"
    (setvar "cmdecho" 0)(setvar "osmode" 0)
    (if (= (tblsearch "layer" tcm1) nil) (command "layer" "n" tcm1 ""))
    (if (= (tblsearch "layer" tcm2) nil) (command "layer" "n"  tcm2 ""))
    (while (setq zb (read-line ff))
        (while (vl-string-search "," zb) (setq zb (vl-string-subst " " "," zb)))
        (setq zb  (read (strcat "(" zb ")"))
              zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string  (last zb)));注记高程
              ;zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string  (car zb)));提示:注记点号请用该行
              fhb (append fhb (list zb))
    (setq t1 (getvar "cdate"))
    (close ff)
    (setq zb (vl-sort fhb '(lambda (e1 e2) (< (car (car e1)) (car (car e2)))))
          x0 (car (car (car zb)))  x1 (car (car (last zb)))
          zb (vl-sort fhb '(lambda (e1 e2) (< (cadr (car e1)) (cadr (car e2)))))
          y0 (cadr (car (car zb)))  y1 (cadr (car (last zb)))
    (command "zoom" "w" (list x0 y0) (list x1 y1))
    (setq t2 (getvar "cdate"))
    (foreach zb fhb
        (setq zfc (last zb)
              ;pt  (mapcar '+ (car zb) '(1.5 -1.25));这行改为如下
              pt  (car zb)
        (entmake (list '(0 . "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText")
         '(62 . 1) '(40 . 2.5) '(50 . 0.0)
          ;(cons 8 tcm1)   (cons 1 zfc)  (cons 10 pt);这行改为如下
          (cons 8 tcm1)   (cons 1 zfc)  (cons 10 (mapcar '+ pt  '(1.5 -1.25)))                      )
        (entmake (list '(0 . "POINT") '(100 . "AcDbEntity") '(100 . "AcDbPoint")
         '(62 . 2)
          (cons 8 tcm2)  (cons 10 pt)
    (setq t3 (getvar "cdate")
          dt1 (* 1000000 (- t1 t0))
        dt2 (* 1000000 (- t3 t2))
    (princ (strcat "读入数据共耗时:" (rtos dt1 2 3)
     "秒   展点共耗时" (rtos dt2 2 3) "秒"
                   "展点数:" (itoa (length fhb))
     "个  每展一点耗:"
     (rtos (/ dt2 (length fhb)) 2 10) "秒"
    (setvar "cmdecho" cm)(setvar "osmode" os)(princ)
发表于 2006-4-26 07:51:09 | 显示全部楼层
你这家伙把我的程序弄到这里来也不吭一声?
 楼主| 发表于 2006-4-26 09:32:35 | 显示全部楼层
兄弟,如果你是原作者,冒犯之处还请见谅!!!
发表于 2006-4-26 23:00:33 | 显示全部楼层
用来干什么的呀
发表于 2006-4-27 16:55:21 | 显示全部楼层
难道这还有假,请看http://www.celiang.net/celiang/a ... 378&author=yshf
发表于 2006-4-29 12:06:58 | 显示全部楼层
我还准备自己编一个看样子不用了!
发表于 2006-4-29 17:51:37 | 显示全部楼层
地形测量中碎部展点
发表于 2013-8-10 15:44:48 | 显示全部楼层
东西在哪啊?擦你妈啊!
发表于 2013-8-15 09:00:11 | 显示全部楼层
顶,,,,,,,
GMT+8, 2026-11-22 08:13 , Processed in 0.488716 second(s), 26 queries , Gzip On, File On.
