查看: 1136|回复: 0
[CP原创]VLISP函数: 弧度转换为全角或汉字格式字符串
发表于 2002-1-27 03:22:07 | 显示全部楼层 |阅读模式
[CP]VLISP函数: 弧度转换为全角或汉字格式字符串
  1. ;;;======================================================================;
  2. ;;;弧度转换为28°5′20″(全角)或28度5分20秒(汉字)格式字符串              ;
  3. ;;;======================================================================;
  4. (defun myvl_RadToStr (Rad Fmt / str)
  5.   (setq str (angtos Rad 1 6))
  6.   (if (= Fmt T)
  7.     (setq str (vl-string-subst "°" "d" str);28°5′20″(全角)
  8.           str (vl-string-subst "′" "'" str)
  9.           str (vl-string-subst "″" """ str)
  10.     )
  11.     (setq str (vl-string-subst "度" "d" str);28度5分20秒(汉字)
  12.           str (vl-string-subst "分" "'" str)
  13.           str (vl-string-subst "秒" """ str)
  14.     )
  15.   )
  16. )
GMT+8, 2026-11-3 09:41 , Processed in 0.385263 second(s), 32 queries , Gzip On.
