查看: 1779|回复: 0
[LISP程序]:测井曲线的读取-问题何在
发表于 2009-11-28 19:28:42 | 显示全部楼层 |阅读模式
(defun C:WTCJ ()
  (command "osnap" "off" )
  (COMMAND "insert" "c:\\Temp\\AB线CD段EF隧道DZ-01-023孔.dwg" "0,0,0" "1" "1" "0")
  (COMMAND "_explode" "all")
  (COMMAND "_zoom" "e")
  (princ "\n读取综合测井文件数据,绘制曲线。")
  (if (setq FILE (getfiled "选择dat文件"
      "dat"
      4
    (progn
      ;;读模式打开lsp文件
      (setq A1 (open FILE "r"))
      ;;逐行读入
      (while (/= A1 nil)
(setq STR (repeat 2 (read-line F1)))
(if(= F1 "自然电位")
(progn
        (setq min1 (getreal "请输入自然电位最小值"))
        (setq max1 (getreal "请输入自然电位最大值"))
        (rtos (setq mid1 (/ max1 4)));转成字符串
        (rtos (setq mid2 (/ max1 2)))
        (rtos (setq mid3 (* (/ max1 4) 3)))
        (setq mid (strcat mid1 "   " mid2 "   " mid3))
        (command "text" "s" "BG_ST" "j" "bc" "110.012,2.375,0" "2.5" "90d" mid)
        (setq STR (repeat 4 (read-line F1)));钻孔编号
        (setq LST STR)
        (command "text" "s" "BG_ST" "j" "bl" "-140.524,42.492,0" "3.6" "90d" LST);写图签
        (setq len (strlen STR))
             (setq LST1 (strcat(substr STR 1 1) "  "))
             (setq len (- len 1))
             (if (/= len 0)
                (progn
;                      (setq n 1)
                      (setq n (+ n 1))
                      (setq LST1 (strcat LST1 (substr LST1 n 1) "  "))
        (command "text" "s" "BG_ST" "j" "bl" "90.960,48.634,0" "5.0" "90d" LST1);写标题
        (setq STR (repeat 3 (read-line F1)));套管长度
        (setq LST2 (strcat STR "m"))
        (command "text" "s" "BG_ST" "j" "bl" "217.39,32.308,0" "2.5" "90d" LST2)
        (atoi LST2)
        (setq LST3 (* LST2 2));1:500故乘2
        (setq pa1 (polar '(30.0 0.0) (* pi 1.5) LST3))
        (setq pa2 (polar '(80.0 0.0) (* pi 1.5) LST3))
        (setq pa3 (polar '(32.382 -2.608) (* pi 1.5) (- LST3 2)))
        (setq pa4 (polar '(32.154 -2.608) (* pi 1.5) (- LST3 2)))
        (command "pline" '(32.382 -2.608) pa3 "")
        (command "pline" '(32.154 -2.608) pa4 "")
        (command "pline" pa1 pa2 "")
        (command "text" "s" "BG_ST" "j" "bc" "55,-116,0" "2.0" "90d" LST3)
        (command "text" "s" "BG_ST" "j" "bc" "70,-116,0" "2.0" "90d" "套管")
        (setq STR (read-line F1));测试日期
        (command "text" "s" "BG_ST" "j" "mc" "-58.524,11.258,0" "2.4" "90d" STR)
        (setq STR (repeat 2 (read-line F1)));钻孔标高
        (setq LST4 (strcat STR "m"))
        (command "text" "s" "BG_ST" "j" "bl" "103.604,32.308,0" "2.5" "90d" LST4)
        (setq STR (repeat 140 (read-line F1)));测井数据152行
        (atof STR);转成实数
        (list STR);转到串行
        (setq data1 (car STR))
        (setq data2 (cadr STR))
        (setq data11 (atof data1))
        (setq data21 (atof data2))
        (setq Y (* data11 -2));1:500计算Y坐标
        (if(< data21 min1) (setq X 90))
        (if(> data21 max1) (setq X 130))
        (if(and (> data21 min1) (< data21 max1))
             (setq X (+ (* (/ (- data21 min1) (- max1 min1)) 40) 90));min1<data21<max1时,X=[(data21-min1)/(max1-min1)]*40+90
             (setq G1 '(X,Y))
             (while (/= STR nil)
                    (line-line())
                    (command "layer" "s" "图层8" "")
                    (command "pline" G1 G2 "w" "0.0" "0.0")
                    (setq G1 G2)
             (defun line-line (STR)
             (progn
                   (atof STR)
                   (list STR)
                       (setq G2 '(X,Y))
     (close A1)
     (princ "\nOK!")
     (prompt "\n********* << C:WTCJ >> *********")
问题:函数的功能是读测井曲线,并画在CAD图上。为什么会是参数类型错误呢?要怎么改?
GMT+8, 2026-11-22 08:29 , Processed in 0.451703 second(s), 10 queries , Gzip On, File On.
