查看: 1314|回复: 0
[编程申请]:请哪位大师将下面这个程序改为标高自动增加两个插入点y值(最好包含天
发表于 2009-7-9 13:41:34 | 显示全部楼层 |阅读模式
(vl-load-com)
(if (not $ea_copy_bj)
  (setq $ea_copy_bj 0.0)
(defun c:tt (/ ss ssl tf tf0 str jd p p1 e el _copy_bj s1)
  (if (setq ss (ssget))
    (progn
      (if (setq s1 (ssget "p" '((0 . "text"))))
        (progn
          (setq        ssl (sslength s1)
                tf  t
          (while (and tf (> ssl 0))
            (setq e (ssname s1 (setq ssl (1- ssl))))
            (if        (and (= (cdr (assoc 0 (setq el (entget e)))) "TEXT")
                     (setq
                       tf0 (or (distof (setq str (cdr (assoc 1 el))))
                               (and
                                 (wcmatch (strcase str) "%%P*")
                                 (distof (vl-string-left-trim "%Pp" str))
              (setq tf nil)
          (if tf0
            (progn
              (if (vl-string-search "." str)
                (setq
                  jd (1- (- (strlen str) (vl-string-search "." str)))
              (setq _copy_bj
                     (getdist (strcat "\n增量<"
                                      (vl-princ-to-string $ea_copy_bj)
              (if _copy_bj
                (setq $ea_copy_bj _copy_bj)
              ;;(setvar "osmode" 0)
              (if (setq p (getpoint "\n基点: "))
                (while (setq p1 (getpoint p "\n目标点: "))
                  (vl-cmdf ".copy" ss "" "0,0,0" "@")
                  (vl-cmdf ".move" ss "" p p1)
                  (vla-put-textstring
                    (vlax-ename->vla-object e)
                    (if        jd
                      (setq str (rtos (+ (atof str) $ea_copy_bj) 2 jd))
                      (setq str        (vl-princ-to-string
                  (setq p p1)
  (princ)
GMT+8, 2026-11-22 08:30 , Processed in 0.331615 second(s), 10 queries , Gzip On, File On.
