查看: 974|回复: 2
[求助]:ObjectARX中为何不能向ComboBox控件加字符串?
发表于 2004-1-28 22:49:33 | 显示全部楼层 |阅读模式
我编写的基于MFC的ObjectARX程序中,不能够像一般的MFC程序一样用AddString和
InsertString向ComboBox种添加字符串,请高手指教。
IMPLEMENT_DYNAMIC(CComboDlg, CDialog)
CComboDlg::CComboDlg(CWnd* pParent /*=NULL*/)
        : CDialog(CComboDlg::IDD, pParent)
        , m_ComboDlg(0)
CComboDlg::~CComboDlg()
void CComboDlg::DoDataExchange(CDataExchange* pDX)
        CDialog::DoDataExchange(pDX);
        DDX_Control(pDX, IDC_COMBO1, m_ComboBox);
BEGIN_MESSAGE_MAP(CComboDlg, CDialog)
END_MESSAGE_MAP()
// CComboDlg 消息处理程序
BOOL CComboDlg::OnInitDialog()
        CDialog::OnInitDialog();
    m_ComboBox.AddString("123");
    m_ComboBox.AddString("456");
    m_ComboBox.AddString("789");
        return TRUE;  // return TRUE  unless you set the focus to a control
发表于 2004-1-29 19:37:50 | 显示全部楼层
多半你将其设置为自绘制的了
 楼主| 发表于 2004-2-1 12:12:10 | 显示全部楼层
这个问题已经解决,发出来与大家共享!
1。在AutoDesk的网上是这样讨论的:
Posted by: Rizzo, Jon
Date: Sep/09/02 - 09:46 (GMT)
I am having a problem with an owner drawn combo box.
In my OnInitDialog(), I am adding code to an instance of my combo box class.
When I call AddString(), the function executes, but it appears to store a
garbage string, instead of the string that is passed.. The same garbage
string can be retrieved using GetLBText(), so the problem appears to be in
storing the string, rather than displaying it.
What I am trying to do is not complicated, and I tested the code outside of
AutoCAD (in a dialog based application) & did not have the same problem. I
added a CAcModuleResourceOverride object to the command that calls this
dialog, but that did not help.
Any ideas what could be causing this problem, or how to fix it?
Thanks in advance,
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
Reply From: Blattel, Byron
Date: Sep/09/02 - 09:53 (GMT)
    Re: Problem with owner drawn combo box
If you are creating it via CComboBox::Create() don't forget to use
CBS_HASSTRINGS...
实际上的做法是要确保你的对话框中ComboBox控件设置
CBS_OwnerDraw 选“否“,CBS_HasString选“false".
2。经过本人认真研究ObjectARX的例题,在VStudio.net中用
Wizard后,加入的ComboBox的默认高度是12,这个值太小了,
在OnInitDialog后根本显不出来,修改如下。
打开*.rc文件,找到如下代码
COMBOBOX        IDC_COMBO1,48,12,27,12,CBS_DROPDOWN |     WS_VSCROLL |  WS_TABSTOP
将其中的后一个 12 改写为大一些的值,100就行!这四个数分
别代表了起点的x坐标,y坐标,长度和高度。
GMT+8, 2026-11-3 06:09 , Processed in 0.435240 second(s), 36 queries , Gzip On.
