查看: 1398|回复: 1
[VBA程序]:求高手帮我分析一下。。。
发表于 2002-12-14 16:55:23 | 显示全部楼层 |阅读模式
Private Sub ComboBox1_Click()
Dim cn As Connection
Set cn = New Connection
cn.Open "PROVIDER=Microsoft.Jet.OLEDB.3.51;Data Source=d:\cf.mdb;"
Dim cmd As New ADODB.Command
Set cmd.ActiveConnection = cn
cmd.CommandText = "select b,h,name from cf1 where name='" & ComboBox1.Text & "'"
Dim rst As New ADODB.Recordset
rst.CursorLocation = adUseClient
rst.Open cmd, , adOpenStatic, adLockBatchOptimistic
Do While Not rst.EOF
UserForm1.TextBox1.Text = rst("h")
UserForm1.TextBox2.Text = rst("b")
rst.MoveNext
Loop
rst.Clone
End Sub
Private Sub CommandButton1_Click()
UserForm1.Hide
Dim pt As Variant
pt = ThisDrawing.Utility.GetPoint(, "拾取插入点:")
h = Val(UserForm1.TextBox1.Text)
b = Val(UserForm1.TextBox2.Text)
Dim ax1(0 To 2) As Double
Dim ax2(0 To 2) As Double
Dim ax3(0 To 2) As Double
Dim ax4(0 To 2) As Double
ax1(0) = pt(0)
ax1(1) = pt(1)
ax1(2) = pt(2)
ax2(0) = pt(0) + b
ax2(1) = pt(1)
ax2(2) = pt(2)
ax3(0) = pt(0)
ax3(1) = pt(1) + h
ax3(2) = pt(2)
ax4(0) = pt(0) + b
ax4(1) = pt(1) + h
ax4(2) = pt(2)
Dim linea, lineb, linec, lined As AcadLine
Set linea = ThisDrawing.ModelSpace.AddLine(ax1, ax2)
Set lineb = ThisDrawing.ModelSpace.AddLine(ax2, ax3)
Set linec = ThisDrawing.ModelSpace.AddLine(ax3, ax4)
Set lined = ThisDrawing.ModelSpace.AddLine(ax4, ax1)
End Sub
Private Sub UserForm_Initialize()
ComboBox1.AddItem "10*20"
ComboBox1.AddItem "15*30"
ComboBox1.AddItem "20*40"
End Sub
执行以后出现这句提示:实时错误‘-2147217904(80040阿0)’:至少一个参数没有被指定值。
已领礼包: 181个
发表于 2002-12-15 15:10:19 | 显示全部楼层
上面的Command对象不必声明,可直接用Recordset对象来获取查询记录,如下:
rst.Open select b,h,name from cf1 where name='" & ComboBox1.Text & "'", cn, adOpenStatic, adLockBatchOptimistic
GMT+8, 2026-11-2 16:38 , Processed in 0.491153 second(s), 34 queries , Gzip On.
