查看: 816|回复: 1
[日积月累]:有用的lisp小工具(6)--画正弦曲线
发表于 2004-2-1 15:17:28 | 显示全部楼层 |阅读模式
说明:
制作正弦曲线的小程序,结果是拟合的pline。
注意:1,为了让曲线光滑些,每波点数不要太少。
2,使用时请关闭捕捉。
  1. (defun c:sin( / p0 p1 p2 hi x1 y1 ang dis steps n y0)
  2.   (setvar "cmdecho" 0)
  3.   (setvar "plinewid" 0)
  4.   (setq p0 (getpoint "\n起始点: ")
  5.         hi (getdist p0 "\n半径: ")
  6.         dis (getdist "\n波长: ")
  7.         steps (getint "\n每波的点数: ")
  8.         n (getint "\n波数: "))
  9.   (setq p1 p0 x1 (car p1) y0 (cadr p1) xt (car p2) ang 0)
  10.   (command "pline" p1)
  11.   (repeat (* n steps)
  12.     (command
  13.      (setq x1 (+ x1 (/ dis steps))
  14.           ang (+ ang (/ pi steps 0.5))
  15.           y1 (+ y0 (* hi (sin ang)))
  16.           p1 (list x1 y1))
  17.     )
  18.   )
  19.   (command "")
  20.   (command "pedit" "l" "f" "x")
  21.   (princ)
  22. )
已领礼包: 488个
发表于 2004-2-1 15:49:42 | 显示全部楼层
正弦?
波长=4*弓高.
把凸度改为1和-1就行了
GMT+8, 2026-11-7 00:00 , Processed in 0.408491 second(s), 34 queries , Gzip On.
