查看: 922|回复: 3
[VBA程序]:请问在VB例如和设置VBA开发环境?
发表于 2002-9-18 10:23:47 | 显示全部楼层 |阅读模式
CAD里的VBA(IDE)不能用,请问在VB例如和设置?
发表于 2002-9-18 10:38:58 | 显示全部楼层
不用设置,引用一下库后直接用即可。
you must first reference the AutoCAD type library. To do this in VB, select the References option from the Project menu to launch the Reference dialog box. From the References dialog box, choose AutoCAD Type Library, and then press OK.
例程:
  1. [FONT=courier new]
  2. Sub Ch2_ConnectToAcad()
  3.     Dim acadApp As AcadApplication
  4.     On Error Resume Next
  5.
  6.     Set acadApp = GetObject(, "AutoCAD.Application")
  7.     If Err Then
  8.         Err.Clear
  9.         Set acadApp = CreateObject("AutoCAD.Application")
  10.         If Err Then
  11.             MsgBox Err.Description
  12.             Exit Sub
  13.         End If
  14.     End If
  15.     MsgBox "Now running " + acadApp.Name + _
  16.            " version " + acadApp.Version
  17. End Sub
  18. [/FONT]
VB与VBA程序比较
VBA:
  2. Sub Ch2_AddLineVBA()
  3.     ' This example adds a line
  4.     ' in model space
  5.     Dim lineObj As AcadLine
  6.     Dim startPoint(0 To 2) As Double
  7.     Dim endPoint(0 To 2) As Double
  8.
  9.     ' Define the start and end
  10.     ' points for the line
  11.     startPoint(0) = 1
  12.     startPoint(1) = 1
  13.     startPoint(2) = 0
  14.     endPoint(0) = 5
  15.     endPoint(1) = 5
  16.     endPoint(2) = 0
  17.
  18.     ' Create the line in model space
  19.     Set lineObj = ThisDrawing. _
  20.         ModelSpace.AddLine _
  21.         (startPoint, endPoint)
  22.
  23.     ' Zoom in on the newly created line
  24.     ZoomAll
  25. End Sub
  26. [/FONT]
VB:
  2. Sub Ch2_AddLineVB()
  3.     On Error Resume Next
  4.
  5.     ' Connect to the AutoCAD application
  6.     Dim acadApp As AcadApplication
  7.     Set acadApp = GetObject _
  8.                   (, "AutoCAD.Application")
  9.     If Err Then
  10.         Err.Clear
  11.         Set acadApp = CreateObject _
  12.                   ("AutoCAD.Application")
  13.         If Err Then
  14.             MsgBox Err.Description
  15.             Exit Sub
  16.         End If
  17.     End If
  18.
  19.     ' Connect to the AutoCAD drawing
  20.     Dim acadDoc As AcadDocument
  21.     Set acadDoc = acadApp.ActiveDocument
  22.
  23.     ' Establish the endpoints of the line
  24.     Dim lineObj As AcadLine
  25.     Dim startPoint(0 To 2) As Double
  26.     Dim endPoint(0 To 2) As Double
  27.     startPoint(0) = 1
  28.     startPoint(1) = 1
  29.     startPoint(2) = 0
  30.     endPoint(0) = 5
  31.     endPoint(1) = 5
  32.     endPoint(2) = 0
  33.     ' Create a Line object in model space
  34.     Set lineObj = acadDoc.ModelSpace.AddLine _
  35.                          (startPoint, endPoint)
  36.     ZoomAll
  37.     acadApp.visible = True
  38. End Sub
  39. [/FONT]
 楼主| 发表于 2002-9-18 10:58:05 | 显示全部楼层
谢谢秋枫,
我是指在VB开发界面里如何设置AUTOTCAD 2000 VBA的开发环境?
发表于 2002-9-18 10:59:02 | 显示全部楼层
看一下顶上那一段英文啊。
GMT+8, 2026-11-22 09:43 , Processed in 0.563389 second(s), 18 queries , Gzip On, File On.
