查看: 1261|回复: 0
[分享]:资料,Qleader的设置
发表于 2002-9-18 12:40:30 | 显示全部楼层 |阅读模式
QLEADER Settings
ID    58545
Applies to:    AutoCAD 2000
AutoCAD 2002
Date    8/14/2001
This document is part of   Dimensions   VBA   Visual Basic
Question
Where is the QLEADER settings information stored and how to access it using VBA?
Answer
The QLEADER settings information is stored in the named object dictionary under
ACADDIM as an Xrecord. Please find below a sample VBA code, which shows how
to access the xrecord information:
Sub test()
   Dim obj As Object
   Dim xrec As AcadXRecord
   Set obj = ThisDrawing.Dictionaries("ACADDIM")
   Set xrec = obj
   xrec.GetXRecordData xrectype, xrecdata
   For i = 0 To UBound(xrectype) - 1
    ret = MsgBox("Xrecord Type: " & xrectype(i) & vbCrLf & "Xrecord Data: "
& xrecdata(i), vbOKCancel)
    If ret = 2 Then
        Exit Sub
    End If
   Next i
End Sub
End Sub
Following is a listing of the various DXF codes and its descriptions (as in the
QLEADER dialog):
DXF code Description
3 Arrowhead block name
60 0 MText
1 Copy an Object
2 Tolerance
3 Block Reference
4 None
61 0 None
1 Reuse Next
2 Reuse Current
60 0 MText
1 Copy an Object
2 Tolerance
3 Block Reference
4 None
62 0 Text on right - Top of top
1 Text on right - Middle of top
2 Text on right - Middle of multi-line
3 Text on right - Middle of bottom
4 Text on right - Bottom of bottom
63 0 Text on Left - Top of top
1 Text on Left - Middle of top
2 Text on Left - Middle of multi-line
3 Text on Left - Middle of bottom
4 Text on Left - Bottom of bottom
64 0 Underline bottom line - OFF
1 Underline bottom line - ON
65 0 Straight
1 Spline
66 0 No Limit - On
1 No Limit - Off
67 Maximum number of points
68 0 Prompt for width - OFF
1 Prompt for width - ON
69 0 Always Left justify - OFF
69 1 Always Left justify - ON
70 & 71 0 = Any angle
1 = Horizontal
2 = 90
3 = 45
4 = 30
5 = 15
72 0 Frame Text - OFF
72 1 Frame Text - ON
GMT+8, 2026-11-22 09:58 , Processed in 0.348818 second(s), 11 queries , Gzip On, File On.
