- UID
- 1
- 积分
- 16123
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
AutoCAD VBA example that implements a function similar to the Lengthen command
ID 73114
Applies to: AutoCAD 2000
AutoCAD 2000I
AutoCAD 2002
Date 6/2/2002
Question
Is there an example that uses GetEntity and GetPoint to implement a function
that will work like the Lengthen command on a line?
Answer
Here is an example procedure that is similar to the LENGTHEN command with the
DY parameter. There is not any error checking for clarity and would work on
LINE entities only.
Public Sub lengthenExample()
Dim oLine As AcadLine
Dim angle1 As Double
Dim dist1 As Double, dist2 As Double, distStPntPickPnt As Double, halfLenOfLine As Double
Dim pickedPnt2 As Variant, returnPnt As Variant
Dim basePnt(0 To 2) As Double
Dim lineObj As AcadLine
Dim intPoints As Variant
Dim myRay As AcadRay
ThisDrawing.Utility.GetEntity oLine, pickedPnt2, "select object to lengthen"
' distance between the startpoint and
' the picked point
dist1 = Abs((oLine.StartPoint(0) - pickedPnt2(0)) * (oLine.StartPoint(0) - pickedPnt2(0)))
dist2 = Abs((oLine.StartPoint(1) - pickedPnt2(1)) * (oLine.StartPoint(1) - pickedPnt2(1)))
distStPntPickPnt = Sqr(dist1 + dist2)
' Debug.Print "Distance between stPnt and pickedPnt " & dist3 ' for testing
' Use to determine which point should be modified
halfLenOfLine = oLine.Length / 2
' this is 90 degrees
angle1 = oLine.Angle - 1.57
' basePnt needs to be either the StartPoint or EndPoint
' of the selected line
If distStPntPickPnt < halfLenOfLine Then
basePnt(0) = oLine.StartPoint(0)
basePnt(1) = oLine.StartPoint(1)
basePnt(2) = oLine.StartPoint(2)
Else
basePnt(0) = oLine.EndPoint(0)
basePnt(1) = oLine.EndPoint(1)
basePnt(2) = oLine.EndPoint(2)
End If
returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
Dim polarPnt As Variant
Dim distance As Double
' the distance value is not important
' this line is going to be erased, it is just
' need for the IntersectWith function below
distance = 5
polarPnt = ThisDrawing.Utility.PolarPoint(returnPnt, angle1, distance)
' Create a ray from the base point to the polar point
Set myRay = ThisDrawing.ModelSpace.AddRay(returnPnt, polarPnt)
' Find the intersection points
' intPoints = oLine.IntersectWith(lineObj, acExtendBoth)
intPoints = oLine.IntersectWith(myRay, acExtendBoth)
' Change the StartPoint or EndPoint of the line
basePnt(0) = intPoints(0)
basePnt(1) = intPoints(1)
basePnt(2) = intPoints(2)
oLine.StartPoint = basePnt
Else
oLine.EndPoint = basePnt
End If
myRay.Delete
ThisDrawing.Regen acActiveViewport
End Sub |
