查看: 1120|回复: 1
[ADN开发资料]:转换3DFACE到POLYLINE...
已领礼包: 145个
发表于 2002-9-19 11:56:56 | 显示全部楼层 |阅读模式
Converting 3dface to a polyline
ID    52821
Applies to:    AutoCAD 2000
Date    5/8/2000
This document is part of   Visual Lisp   AutoCAD Visual Lisp Technical Newsletter - May 2000
Question
How do I convert 3dFaces to polylines ?
Answer
There's no mechanism available to do this directly. What you'll need to do is
collect the 3dFace vertex data, and create a polyline using that information.
Since a 3dFace will probably be construced with differing X,Y, and Z coordinates
you can only re-create them as a 3dPolyline. If the face's Z coordinates are on
the same elevation, you could re-create them as a 2d polyline. Here's some lisp
code to demonstrate this:
  1. [FONT=courier new]
  2. (defun C:3DFtoPL(/ ss1 sl i)
  3.   (setq ss1 (ssget "X" (list (cons '0 "3DFACE"))))
  4.   (setq sl (sslength ss1))
  5.   (setq i 0)
  6.   (while (< i sl)
  7.      (setq ent1 (entget (setq e1 (ssname ss1 i))))
  8.      (setq pt1 (cdr (assoc '10 ent1)))
  9.      (setq pt2 (cdr (assoc '11 ent1)))
  10.      (setq pt3 (cdr (assoc '12 ent1)))
  11.      (setq pt4 (cdr (assoc '13 ent1)))
  12.      ;  Plain 2D Polylines
  13.      ;(command "PLINE" pt1 pt2 pt3)
  14.      ; 3dPolylines ->
  15.      (command "3DPOLY" pt1 pt2 pt3)
  16.      (if (/= pt3 pt4) (command pt4 "c") (command "c") )
  17.      (entdel e1)
  18.      (setq i (1+ i))
  19.   )
  20.   (setq ss1 nil)
  21.   (princ)
  22. )
  23. (princ "\nC:3DFtoPL loaded, to run type 3DFtoPL.")
  24. (princ)[/FONT]
发表于 2006-3-15 23:39:21 | 显示全部楼层
好用,给我解决了大问题
GMT+8, 2026-11-7 01:45 , Processed in 0.511155 second(s), 34 queries , Gzip On.
