查看: 981|回复: 4
[分享]:动态旋转复制程序
发表于 2004-3-3 10:35:07 | 显示全部楼层 |阅读模式
模仿sketchup的动态旋转复制程序
[PHP]
(defun zf_dynamic_rotate(/ p1 p2 p3 a1 cn cnn tmp e s)
  ;_____________________________
  (defun rc (os / ns ne)
    (setq ne (entlast)
          ns (ssadd)
    (command "copy" os ""  "0,0"   "0,0")
    (while (setq ne (entnext ne))
      (setq ns (ssadd ne ns))
    ns
  (defun ttt (ss n / m ee ns sn )
    (setq ee e
      ns (ssadd)
    (while (setq ee (entnext ee))
      (setq ns (ssadd ee ns))
    (command "erase" ns "")
    (if (member (substr n (strlen n)) '("/" "*"))
      (progn
        (setq m 0)
        (repeat        (atoi n)
          (setq m (1+ m))
          (setq sn(rc ss))
          (cond
            ((= "/" (substr n (strlen n)))
             (command  "rotate" sn "" p1 (* m (/ a1 (atof n))))
            ((= "*" (substr n (strlen n)))
             (command  "rotate" sn "" p1 (* m a1))
      (progn
        (setq sn(rc ss))
      (command  "rotate" sn "" p1 (setq a1 (atof n)))
  (princ "\n动态旋转程序__BY__WKAI__晓东CAD空间论坛")
  (princ "\n选择要旋转的物体:")
  (setq s (ssget))
  (setq p1 (getpoint "\n旋转基点"))
  (setq p2 (getpoint p1 "\n旋转起点"))
  (command "undo" "be" "line"  p1  p2 "")
  (setq e (entlast))
  (setq p3 (getpoint p1 "\n旋转终点"))
  (setq tmp (rc s) )
  (command  "rotate" tmp ""  p1 "r"  p1  p2  p3)
  (setq cn "1*" a1 (* 180 (/ (-(angle p1 p3)(angle p1 p2))pi)))
  (while cn
    (ttt s cn)
    (initget 128)
    (princ "\n输入坐标=旋转终点                         输入数值=旋转角度 ")
    (princ "\n输入数值n并以 / 结束=角度内等分n次复制    输入数值n并以 * 结束=按角度复制n次 ")
    (setq cnn (getpoint "\n请按提示输入<退出>:"))
    (if        (= 'LIST (type cnn))
      (setq p3 cnn
      (setq cn cnn)
  (entdel e)
  (command "undo" "e")
  (princ)
[/PHP]
发表于 2005-7-20 19:00:10 | 显示全部楼层
怎么用啊?!
发表于 2005-7-21 21:53:32 | 显示全部楼层
我下不了爱心太少了
发表于 2005-9-19 15:06:47 | 显示全部楼层
输入角度时并不能得到正确的结果
发表于 2005-10-19 15:56:45 | 显示全部楼层
最初由 czad 发布
[B]怎么用啊?! [/B]
开玩笑吧!老兄都是超级会员了。
使用启动组加载或手动加载(如使用appload函数)后在命令行输入(zf_dynamic_rotate)即可。
GMT+8, 2026-11-6 15:50 , Processed in 0.833089 second(s), 40 queries , Gzip On.
