查看: 1019|回复: 0
[VBA程序]:获得封闭多义线的型心
发表于 2002-9-27 17:50:05 | 显示全部楼层 |阅读模式
Getting the centroid of a closed polyline
ID    35353
Applies to:    AutoCAD Map
AutoCAD Map
AutoCAD Map 2000
This document is part of    Polyline   Regions   VBA   AutoCAD MAP Technical Newsletter - January 2000   Map Automation
  1. [FONT=courier new]
  2. Question
  3. How do I get the centroid of a closed polyline in AutoCAD Map 5 without
  4. creating a topology?
  5. Answer
  6. You need to form a Region object from the polyline and then calculate the
  7. centroid of the region. The Visual Basic code example that follows shows how
  8. this is done.
  9. Sub GetCentroid()
  10. Dim Doc As AcadDocument
  11. Dim Entity As AcadEntity
  12. Dim Region As AcadRegion
  13. Dim Polylist(0 To 0) As AcadEntity
  14. Dim Entities As AcadModelSpace
  15. Dim nPoly As Integer  'number of polylines
  16. Dim i As Integer
  17. Set Doc = ThisDrawing
  18. Set Entities = Doc.ModelSpace
  19. Dim Centroid As Variant
  20. 'Form a region from each polyline
  21. For Each Entity In Entities
  22. If Entity.ObjectName = "AcDbPolyline" Then  'Polyline ?
  23.     Set Polylist(0) = Entity
  24.     Entities.AddRegion Polylist
  25.    MsgBox Entity.ObjectName
  26. End If
  27.
  28. Next
  29. 'Find centroid of each region
  30. For i = 0 To Entities.Count - 1
  31. If Entities.Item(i).ObjectName = "AcDbRegion" Then  'Region ?
  32.     Set Region = Entities.Item(i)
  33.     Centroid = Region.Centroid
  34.     MsgBox "Centroid X: " & Centroid(0) & vbCrLf & "Centroid Y: " & Centroid(1)
  35. End If
  36.
  37. Next
  38. End Sub
  39. [/FONT]
GMT+8, 2026-11-22 09:44 , Processed in 0.130736 second(s), 10 queries , Gzip On, File On.
