查看: 796|回复: 1
[求助]:鼠标中键的设置问题
发表于 2004-3-5 14:56:12 | 显示全部楼层 |阅读模式
重装了2002,可发觉鼠标中键不是原来的功能了,不知怎样设置。
发表于 2004-3-5 15:08:00 | 显示全部楼层
检查一下系统变量 MBUTTONPAN
Type: Integer
Saved in: Registry
Initial Value: 1
Controls the behavior of the third button or wheel on the pointing device.
0 Supports the action defined in the menu (.mnu) file
1 Supports panning when you hold and drag the button or wheel
GMT+8, 2026-11-5 03:51 , Processed in 0.436499 second(s), 33 queries , Gzip On.
