查看: 1079|回复: 0
[VBA程序]:设置BLOCK和LAYER的“过滤器”
发表于 2002-10-9 13:57:24 | 显示全部楼层 |阅读模式
  1. [FONT=century gothic]
  2. How to setup selectionset filters for a block or layer?
  3. ID    19147
  4. Applies to:    AutoCAD 2000
  5. This document is part of    Layers   Block Reference   COM-ActiveX Interfaces   Selecting Entities   Selection Sets   VBA
  6. Question
  7. How do I use a selection set filter to select a block with a particular name
  8. that is on a particular layer ?
  9. Answer
  10. The following sample code allows you to select blocks based on this criteria:
  11. 1. selectALayer() - create a selectionset with entities on "layer1"
  12. 2. selectABlock() - create a selectionset with a block insert "testBlock"
  13. 3. selectABlockOnALayer() - create a selectionset with a block insert
  14. "testBlock"
  15.   on "layer1"
  16. Sub selectALayer()
  17.    Dim sset As Object
  18.
  19.    Set sset = ThisDrawing.SelectionSets.Add("TestSet1")
  20.    Dim filterType As Variant
  21.    Dim filterData As Variant
  22.    Dim p1(0 To 2) As Double
  23.    Dim p2(0 To 2) As Double
  24.
  25.    Dim grpCode(0) As Integer
  26.    grpCode(0) = 8
  27.    filterType = grpCode
  28.    Dim grpValue(0) As Variant
  29.    grpValue(0) = "layer1"
  30.    filterData = grpValue
  31.
  32.    sset.Select acSelectionSetAll, p1, p2, filterType, filterData
  33.
  34. End Sub
  35. Sub selectABlock()
  36.    Dim sset As Object
  37.
  38.    Set sset = ThisDrawing.SelectionSets.Add("TestSet2")
  39.    Dim filterType As Variant
  40.    Dim filterData As Variant
  41.    Dim p1(0 To 2) As Double
  42.    Dim p2(0 To 2) As Double
  43.
  44.    Dim grpCode(0) As Integer
  45.    grpCode(0) = 2
  46.    filterType = grpCode
  47.    Dim grpValue(0) As Variant
  48.    grpValue(0) = "testBlock"
  49.    filterData = grpValue
  50.
  51.    sset.Select acSelectionSetAll, p1, p2, filterType, filterData
  52. End Sub
  53. Sub selectABlockOnALayer()
  54.    Dim sset As Object
  55.
  56.    Set sset = ThisDrawing.SelectionSets.Add("TestSet3")
  57.    Dim filterType As Variant
  58.    Dim filterData As Variant
  59.    Dim p1(0 To 2) As Double
  60.    Dim p2(0 To 2) As Double
  61.
  62.    Dim grpCode(0 To 1) As Integer
  63.    grpCode(0) = 8
  64.    grpCode(1) = 2
  65.    filterType = grpCode
  66.    Dim grpValue(0 To 1) As Variant
  67.    grpValue(0) = "layer1"
  68.    grpValue(1) = "testBlock"
  69.    filterData = grpValue
  70.
  71.    sset.Select acSelectionSetAll, p1, p2, filterType, filterData
  72. End Sub[/FONT]
GMT+8, 2026-11-22 09:44 , Processed in 0.378413 second(s), 10 queries , Gzip On, File On.
