查看: 737|回复: 1
[必看]:SelectService上的公告,关于使用网络共享的文件
发表于 2004-3-15 10:19:05 | 显示全部楼层 |阅读模式
Technical Bulletin
Potential file corruption and loss of data when Using Windows XP Clients with Windows 2000 Server.
Description
Microsoft has found and fixed a serious problem that can permanently corrupt files that are edited over a network. The problem exists only when using MicroStation and other programs from a Windows XP client with Service Pack 1 (SP1) installed, editing files residing on a Windows 2000 Server. This problem affects all versions of MicroStation, including MicroStation/J and V8.
Once a DGN file becomes corrupted from this error, it often becomes unusable and must be restored from a backup.
Resolution
The problem can be resolved by either NOT installing SP1 on Windows XP clients, or, preferably, by installing Service Pack 4 of Windows Server 2000.
Please refer to the following links for more information regarding this issue:
Microsoft information on the issue: http://support.microsoft.com/default.aspx?kbid=321733
Windows 2000 SP4 patch which addresses the issue: http://www.microsoft.com/windows ... cks/sp4/default.asp
This Technical Bulletin is also available in TechNote format.
发表于 2004-3-15 19:04:21 | 显示全部楼层
我习惯先拷贝后操作, 不习惯直接操作网络文件!
GMT+8, 2026-11-3 20:01 , Processed in 0.490736 second(s), 34 queries , Gzip On.
