查看: 1087|回复: 1
[LISP程序]:把图纸视埠设为1xp
发表于 2002-2-1 16:03:11 | 显示全部楼层 |阅读模式
  1. ;;;把图纸视埠设为1xp;;;
  2. ;;; 程序设计:赖云龙 ;;;
  3. ;;;-----------------;;;
  4. (defun C:1XP        (/          HOLDECHO HOLDBLIP ORIG_OSNAP
  5.                  ORIG_UCSFOLLOW           A            AL             A0              W
  6.                  WDXF               W69      W410
  7.                  R15            CH          XP
  8.                 )
  9.   (command "_.undo" "_group")
  10.   (setq HOLDECHO (getvar "cmdecho"))
  11.   (setq HOLDBLIP (getvar "blipmode"))
  12.   (setq ORIG_OSNAP (getvar "osmode"))
  13.   (setq ORIG_UCSFOLLOW (getvar "ucsfollow"))
  14.   (setvar "cmdecho" 0)
  15.   (setvar "blipmode" 0)
  16.   (setvar "osmode" 0)
  17.   (setvar "ucsfollow" 0)
  18.   (setvar "tilemode" 0)
  19.   (command "_.PSPACE")
  20.   (setq        CH (getstring
  21.              "\n所有视埠改为1XP(A)/<选择视埠改为1XP>: "
  22.            )
  23.   )
  24.   (if (= CH "")
  25.     (setq A (ssget '((0 . "VIEWPORT"))))
  26.     (setq A (ssget "x" (list (cons 0 "VIEWPORT"))))
  27.   )
  28.   (setq AL (sslength A))
  29.   (setq A0 0)
  30.   (repeat AL
  31.     (command "_.PSPACE")
  32.     (setq W (ssname A (- AL 1)))
  33.     (setq WDXF (entget W))
  34.     (setq W69 (cdr (assoc 69 WDXF)))
  35.     (if        (wcmatch (getvar "acadver") "15*")
  36.       (progn
  37.         (setq W410 (cdr (assoc 410 WDXF)))
  38.         (setq R15 (getvar "ctab"))
  39.       )
  40.       (setq W410 R15)
  41.     )
  42.     (if        (and (/= W69 1) (/= W69 0) (= W410 R15))
  43.       (progn
  44.         (command "_.MSPACE")
  45.         (command "_.cvport" W69)
  46.         (COMMAND "_.ZOOM" "1XP")
  47.       )
  48.     )
  49.     (setq AL (- AL 1))
  50.   )
  51.   (command "_.pspace")
  52.   (setvar "blipmode" HOLDBLIP)
  53.   (setvar "osmode" ORIG_OSNAP)
  54.   (setvar "ucsfollow" ORIG_UCSFOLLOW)
  55.   (setvar "cmdecho" HOLDECHO)
  56.   (command "_.undo" "_end")
  57.   (princ)
  58. )
发表于 2005-2-18 09:13:44 | 显示全部楼层
图纸视埠是什么
GMT+8, 2026-11-3 08:04 , Processed in 0.453615 second(s), 34 queries , Gzip On.
