查看: 1058|回复: 0
[教学]:替换ACAD内部命令的方法...
发表于 2002-1-13 17:42:09 | 显示全部楼层 |阅读模式
  1. Replacing Acad's Internal Commands
  2. ID    1957
  3. Applies to:    AutoCAD
  4. AutoCAD 2000I
  5. AutoCAD R14
  6. Date    12/24/2001
  7. This document is part of    AcEd
  8. Question
  9. How do I define my own commands that replace AutoCAD's ?
  10. Answer
  11. The ObjectARX API doesn't provide an ARX method to override an AutoCAD internal
  12. command. This can only be achieved by using the "UNDEFINE" command. In the following
  13. sample, undocumented function acedPostCommand() is used to post a lisp expression
  14. that uses the UNDEFINE command to undefine the "OPEN" and "SAVEAS" command.
  15. Also, ObjectARX does provide two functions to undefine certain type of commands,
  16. they are:
  17. 1)  acedUndef()
  18. Undefines a function (an AutoLISP external function) that was previously defined
  19. by a call to acedDefun().
  20. 2) acedCmdUndefine().
  21. acedCmdUndefine only works with ARX registered commands.
  22. For example, if you want to override OPEN and SAVEAS commands, you need to do
  23. the following:
  24. // declare the following function
  25. int acedPostCommand(const char*);
  26. // place the following lines in acrxEntryPoint()'s case AcRx::kInitAppMsg:
  27.   case AcRx::kInitAppMsg:
  28.   acedPostCommand("(command "_undefine" "_open") ");
  29.   acedPostCommand("(command "_undefine" "_saveas") ");
  30. // ** do this always **
  31.   acedRegCmds->addCommand("MYCOMMAND_GRP", "OPEN", "_OPEN", ACRX_CMD_MODAL, rx_open);
  32.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVE", "_SAVE",  ACRX_CMD_MODAL, rx_saveAs);
  33.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVEAS", "_SAVEAS", ACRX_CMD_MODAL, rx_saveAs);
  34. #include <afxdlgs.h>
  35. void rx_open()
  36. {
  37.   CFileDialog FDialog (TRUE, "dwg", "",OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT, _T("AutoCAD Drawing Files (*.dwg)|*.dwg||"));
  38.
  39.   if (FDialog.DoModal() == IDOK)
  40.   {
  41.    char* pFile = new char[512];
  42.    strcpy(pFile, FDialog.GetPathName());
  43.    if(acedSyncFileOpen(pFile) != Acad::eOk)
  44.     acutPrintf("\nError open drawing file.");
  45.    delete [] pFile;
  46.   }
  47. }
  48. void rx_saveAs()
  49. {
  50.   CFileDialog FDialog (FALSE, "dwg", "",
  51.    OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT,
  52.    _T("Save AutoCAD Drawing File As (*.dwg)|*.dwg||"));
  53.
  54.   if (FDialog.DoModal() == IDOK)
  55.   {
  56.    char* pFile = new char[512];
  57.    strcpy(pFile, FDialog.GetPathName());
  58.    // user can obtain the database object through readDwgFile()
  59.    // for an external database
  60.    AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
  61.    if(pDb->saveAs(pFile) != Acad::eOk)
  62.     acutPrintf("\nError saving drawing file.");
  63.    //clean up
  64.    delete [] pFile;
  65.   }
  66. }
  67. Note:
  68. 1) You can always use the original native ACAD command by prefixing the command
  69. name with a "." even if it is already undefined.
  70. 2) The above code runs only in SDI mode due to the use of acedSyncFileOpen() method.
GMT+8, 2026-11-22 10:29 , Processed in 0.378847 second(s), 11 queries , Gzip On, File On.
