查看: 1267|回复: 3
[教学]:替换ACAD内部命令的ARX方法...
已领礼包: 145个
发表于 2002-2-2 01:35:14 | 显示全部楼层 |阅读模式
  1. Replacing Acad's Internal Commands
  2. ID    1957
  3. Applies to:    AutoCAD
  4. AutoCAD 2000I
  5. AutoCAD R14
  6. Date    12/24/2001
  7. This document is part of    AcEd
  8. Question
  9. How do I define my own commands that replace AutoCAD's ?
  10. Answer
  11. The ObjectARX API doesn't provide an ARX method to override an AutoCAD internal
  12. command. This can only be achieved by using the "UNDEFINE" command. In the following
  13. sample, undocumented function acedPostCommand() is used to post a lisp expression
  14. that uses the UNDEFINE command to undefine the "OPEN" and "SAVEAS" command.
  15. Also, ObjectARX does provide two functions to undefine certain type of commands,
  16. they are:
  17. 1)  acedUndef()
  18. Undefines a function (an AutoLISP external function) that was previously defined
  19. by a call to acedDefun().
  20. 2) acedCmdUndefine().
  21. acedCmdUndefine only works with ARX registered commands.
  22. For example, if you want to override OPEN and SAVEAS commands, you need to do
  23. the following:
  24. // declare the following function
  25. int acedPostCommand(const char*);
  26. // place the following lines in acrxEntryPoint()'s case AcRx::kInitAppMsg:
  27.   case AcRx::kInitAppMsg:
  28.   acedPostCommand("(command "_undefine" "_open") ");
  29.   acedPostCommand("(command "_undefine" "_saveas") ");
  30. // ** do this always **
  31.   acedRegCmds->addCommand("MYCOMMAND_GRP", "OPEN", "_OPEN", ACRX_CMD_MODAL, rx_open);
  32.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVE", "_SAVE",  ACRX_CMD_MODAL, rx_saveAs);
  33.   acedRegCmds->addCommand("MYCOMMAND_GRP", "SAVEAS", "_SAVEAS", ACRX_CMD_MODAL, rx_saveAs);
  34. #include <afxdlgs.h>
  35. void rx_open()
  36. {
  37.   CFileDialog FDialog (TRUE, "dwg", "",OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT, _T("AutoCAD Drawing Files (*.dwg)|*.dwg||"));
  38.
  39.   if (FDialog.DoModal() == IDOK)
  40.   {
  41.    char* pFile = new char[512];
  42.    strcpy(pFile, FDialog.GetPathName());
  43.    if(acedSyncFileOpen(pFile) != Acad::eOk)
  44.     acutPrintf("\nError open drawing file.");
  45.    delete [] pFile;
  46.   }
  47. }
  48. void rx_saveAs()
  49. {
  50.   CFileDialog FDialog (FALSE, "dwg", "",
  51.    OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT,
  52.    _T("Save AutoCAD Drawing File As (*.dwg)|*.dwg||"));
  53.
  54.   if (FDialog.DoModal() == IDOK)
  55.   {
  56.    char* pFile = new char[512];
  57.    strcpy(pFile, FDialog.GetPathName());
  58.    // user can obtain the database object through readDwgFile()
  59.    // for an external database
  60.    AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
  61.    if(pDb->saveAs(pFile) != Acad::eOk)
  62.     acutPrintf("\nError saving drawing file.");
  63.    //clean up
  64.    delete [] pFile;
  65.   }
  66. }
  67. Note:
  68. 1) You can always use the original native ACAD command by prefixing the command
  69. name with a "." even if it is already undefined.
  70. 2) The above code runs only in SDI mode due to the use of acedSyncFileOpen() method.
发表于 2002-2-3 12:32:56 | 显示全部楼层
替换后如果能在一定的条件下也能再调用原有命令就好了,比如说有一个开关,开就调用原有的open,闭就调用我自己的open
发表于 2002-2-3 12:36:09 | 显示全部楼层
版主,回复时我明明写了标题,怎么我一提交之后,怎么会没有呢?
发表于 2005-8-10 14:54:33 | 显示全部楼层
这个方法显然没用,只不过调用了一下AutoCAD本身的命令,稍微懂点的人来个redefine就破了!
GMT+8, 2026-11-6 03:22 , Processed in 0.506606 second(s), 38 queries , Gzip On.
