查看: 681|回复: 0
[VBA程序]:求教,如何用差集剪去一个阵列
发表于 2004-4-14 15:59:08 | 显示全部楼层 |阅读模式
请高手指点,下面是一个关于用大圆柱减去小圆柱陈列的程序,即在大圆柱上挖这样的四个孔出来。但执行错误,且最后一句话始终错误。请专家告诉我怎么减去一个阵列。谢谢
'建立一个大圆柱
Dim  cylinderobj1  As  Acad3DSolid
Dim  cylindercenter1(0  To  2)  As  Double
Dim  cylindderradius1  As  Double
Dim  cylindherheight1  As  Double
cylindercenter1(0)  =  0#:  cylindercenter1(1)  =  0#:  cylindercenter1(2)  =  0#
cylinderradius1  =  10
cylinderheight1  =  20
Set  cylinderobj1  =  ThisDrawing.ModelSpace.AddCylinder(cylindercenter1,  cylinderradius1,  cylinderheight1)
cylinderobj1.color  =  acWhite
'建立小圆柱,并建立其阵列
Dim  cylinderobj3  As  Acad3DSolid
Dim  cylindercenter3(0  To  2)  As  Double
Dim  cylindderradius3  As  Double
Dim  cylindherheight3  As  Double
cylindercenter3(0)  =  5:  cylindercenter3(1)  =  0:  cylindercenter3(2)  =  0#
cylinderradius3  =  2
cylinderheight3  =  20
Set  cylinderobj3  =  ThisDrawing.ModelSpace.AddCylinder(cylindercenter3,  cylinderradius3,  cylinderheight3)
cylinderobj3.color  =  acWhite
Dim  noofobjects  As  Integer
Dim  angletofill  As  Double
Dim  basepnt(0  To  2)  As  Double
noofobjects  =  4
angletofill  =  3.14
basepnt(0)  =  0#:  basepnt(1)  =  0#:  basepnt(2)  =  0#
Dim  retobj  As  Variant
retobj  =  cylinderobj3.ArrayPolar(noofobjects,  angletofill,  basepnt)
ZoomAll
'大圆柱剪去阵列(就这里总是错,是不是要换个其它语句才能剪去阵列了?)
cylinderobj1.Boolean  acSubtraction,  retobj
GMT+8, 2026-11-3 06:04 , Processed in 0.627730 second(s), 32 queries , Gzip On.
