查看: 901|回复: 0
[ARX程序]:请大家帮我指出那儿出错
发表于 2004-4-20 12:52:39 | 显示全部楼层 |阅读模式
我在ARX程序中添加了一个命令PIPE,运行时发现程序中由acedcommand发出的Move命令不能正确执行,而当在AutoCad2000中执行一遍Move命令后,PIPE就能正确执行,我觉得很惊奇,不知道其原因,请大家帮助分析一下。另外,当我用acedcommand执行Rotate3d命令时,AutoCad2000报告Rotate3d为未知命令。不知这是什么原因?
// This is command 'PIPE'
void lnpupipe()
        AcGePoint3d m_StartPoint(0,0,0),m_EndPoint(100,100,100);
        double m_OuterDiameter,m_Thickness;
        m_OuterDiameter=20;
        m_Thickness=2;//本应提示用户输入
        lnpuCPipe *m_pipe=new lnpuCPipe;//自定义Cpipe类,从acdbSolid3d导出
        bool m_bool;
        m_bool=m_pipe->create           (m_StartPoint,m_EndPoint,m_OuterDiameter,m_Thickness);
        //m_pipe->
        if (!m_bool) {
                acutPrintf("\n出错!");
                return;
        try
                AcDbObjectId m_PipeID;
                ARXOK(postToDatabase(m_pipe,m_PipeID));//向数据库添加实体
                ads_name m_CurrentPipe;
                ads_point m_BasePoint,m_SecondPoint;
                //AcGePoint3d m_OffsetPoint;
                double m_length=m_StartPoint.distanceTo(m_EndPoint);
                m_BasePoint[X]=0;
                m_BasePoint[Y]=0;
                m_BasePoint[Z]=-0.5*m_length;
                m_SecondPoint[X]=m_StartPoint.x;
                m_SecondPoint[Y]=m_StartPoint.y;
                m_SecondPoint[Z]=m_StartPoint.z;
                acdbEntLast(m_CurrentPipe);
                acedCommand(RTSTR,"MOVE",RTENAME,m_CurrentPipe,RTSTR,"",RT3DPOINT,m_BasePoint,
                                                RT3DPOINT,m_SecondPoint,RTNONE);
        catch (Acad::ErrorStatus *es) {
                acutPrintf("\n出错");
                delete es;
                return;
GMT+8, 2026-11-22 11:29 , Processed in 0.416163 second(s), 10 queries , Gzip On, File On.
