查看: 850|回复: 1
[求助] [求助]:怎样用lisp做一个二维螺旋线的程序
发表于 2004-5-6 21:29:09 | 显示全部楼层 |阅读模式
我是指由内向外渐大的那种,有点像蜗牛状的。请问各位高手怎么做
发表于 2004-5-7 12:45:25 | 显示全部楼层
我做过一个不过是由外向内的,看对你由无启发!
一个绘制容器中倒流板的程序,请各位高手指出不足之处,多谢!
(setq ag 0);;;原始角
(setq WE (+ ag pi));;;西
(setq NO (+ ag (/ pi 2)));;;北
(setq SO (+ WE (/ pi 2)));;;南
(SETQ EA AG);;;东
(SETQ WN (+ AG (* PI 0.75)));;;西北
(SETQ EN (+ AG (* PI 0.25)));;;东北
(SETQ WS (+ AG (* PI 1.25)));;;西南
(SETQ ES (+ AG (* PI 1.75)));;;南
(setq os (getvar "osmode" ))
(defun newos()
  (setvar "osmode" 0)
(defun oldos()
  (setvar "osmode" os)
(defun swdraw()
  (command "layer" "m" "draw" "" )
(defun swcenter()
  (command "layer" "m" "center" "" )
;;;绘制导流板
(defun c:dlb()
  (SETVAR "errno" 0)
  (setvar "cmdecho" 1)
  (setq lay (getvar "clayer"))
  (setq olderr *error*)
  (defun *error* (msg)
    (setq errno (getvar "errno"))
    ;(princ "\n")
    ;(princ msg)
    (reset)
    (princ"\n出错!再来")
    (c:dlb)
    ;(setvar *error* olderr)
  (setq dcl_id (load_dialog "dlb.dcl"))
  (if (not (new_dialog "dlb" dcl_id)
    (exit)
  ;;;初始化
  (setq tyft 1 nsz 1 listkswz 0 zxbj 150 listnum 0 nj 1000 bh 10 jj 200)
  (action_tile "tyft" "(progn (setq tyft (atoi $Value) dxft 0 pg 0)(mode_tile \"bh\" 0) )    ")
  (action_tile "dxft" "(progn (setq dxft (atoi $Value) tyft 0 pg 0)(mode_tile \"bh\" 0) )    ")
  (action_tile "pg" "(progn (setq pg (atoi $Value) tyft 0 dxft 0) (mode_tile \"bh\" 1) )    ")
  (action_tile "ssz" "(progn (setq ssz (atoi $Value) nsz 0) )    ")
  (action_tile "nsz" "(progn (setq nsz (atoi $Value) ssz 0) )    ")
  (action_tile "sc" "(progn (setq listnum (atoi $Value)) )    ")
  (action_tile "nj" "(progn (setq nj (atoi $Value)) )    ")
  (action_tile "bh" "(progn (setq bh (atoi $Value)) )    ")
  (action_tile "jj" "(progn (setq jj (atoi $Value)) )    ")
  (action_tile "zxbj" "(progn (setq zxbj(atoi $Value)) )    ")
  (action_tile "kswz" "(progn (setq listkswz(atoi $value)))")
  (action_tile "txt" "(progn (setq txt(atoi $value)))")
  (start_image "helpme")
  (slide_image 1 1 (dimx_tile "helpme") (dimy_tile "helpme") "orientation")
  (end_image)
  (action_tile "accept" "(setq flag 1)(done_dialog)")
  (action_tile "cancel" "(princ \n退出程序)")
  (action_tile "help" "(alert \"\\n1.本程序可以画封头上倒流板的展开图和盘管的俯视图\\n\\n2.本程序画出的螺旋线是通过四点法近似模拟的\\n\\n3.椭圆封头外圆展开尺寸近似为:1.21*(di+2*t)\\n\\n4.碟形封头上外圆展开尺寸近似为:  1.12*(di+2*t)\")")
  (start_dialog)
  (unload_dialog dcl_id)
  (if (= flag 1)
    (progn
      (startdlb)
(defun startdlb()
  (setq p0 (getpoint"\n请选择一个中心点:"))
  (setq sc (nth listnum (list 1 2 3 4 5 6 8 10 12 15 16 20 25 30 40 50 60 80)))
  (setq kswz (nth listkswz (list 0 90 180 270)))
  (setq nj (/ nj sc) bh (/ bh sc) jj (/ jj sc) zxbj (/ zxbj sc))
  (cond
    ((= tyft 1)
       (setq wj(* 1.21 (+ nj bh)))
    ((= dxft 1)
       (setq wj(* 1.12 (+ nj bh)))
    ((= pg 1)
       (setq wj nj)
  (setq n 1)
  (setq r (+(/ wj 2) (/ jj 8)))
  (swcenter)
  (newos)
  (command "pline" (polar p0 no (/ wj 2)) (polar p0 so (/ wj 2)) ""
    "pline" (polar p0 0 (/ wj 2)) (polar p0 pi (/ wj 2)) ""
  (if (= txt 1)
    (progn
      (COMMAND "Text" "j" "mc" (polar p0 no (+ 6(/ wj 2))) 5 0 "0%%d" ""  )
      (COMMAND "Text" "j" "mc" (polar p0 0 (+ 6(/ wj 2))) 5 0 "90%%d" ""  )
      (COMMAND "Text" "j" "mc" (polar p0 so (+ 6(/ wj 2))) 5 0 "180%%d" ""  )
      (COMMAND "Text" "j" "mc" (polar p0 pi (+ 7(/ wj 2))) 5 0 "270%%d" ""  )
  (swdraw)
  (cond
    ((= ssz 1)
     (progn
       (setq ang (* kswz (/ pi 180)))
       (drawssz)
    ((= nsz 1)
     (progn
       (drawnsz)
  (oldos)
  (reset)
  (princ "\n命令-->DLB \nBY SWAYWOOD")
(defun drawnsz()
    (while (> r zxbj)
    (progn
      (setq p1(polar p0 (- (* (/ pi 4) (- (* 2 n) 1)) ang) (* jj (sqrt 2) 0.125))
     r(- r (* 1 0.25 jj))
     pt1(polar p1 (- (* n pi 0.5) ang) r)
     pt2(polar p1 (- (+ (/ pi 2) (* n pi 0.5)) ang) r)
      (command "arc" "c" p1 pt1 pt2)
      (setq n(+ n 1))
(defun drawssz()
    (while (> r zxbj)
    (progn
      (setq p1(polar p0 (- (* (/ pi 4) (- 5 (* 2 n))) ang) (* jj (sqrt 2) 0.125))
     pt1(polar p1 (- (* (/ pi 2) (- 2 n)) ang) r)
     pt2(polar p1 (- (* (/ pi 2) (- 1 n)) ang) r)
      (command "arc" "c" p1 pt2 pt1)
      (setq n(+ n 1))
(defun reset()
(setvar "clayer" lay)
(setvar "cmdecho" 0)
(setq r nil pt1 nil pt2 nil p0 nil nj nil wj nil bh nil zxbj nil
   jj nil sc nil tyft nil dxft nil pg nil ssz nil nsz nil listkswz nil
    listnum nil ang nil n nil  flag nil txt nil)
(if lay (setq lay nil))
(if os (setvar "osmode" os) (setvar "osmode" 4607))
dlb: dialog {
          label = "螺旋线模拟" ;
:column{
  :boxed_row {
     label = "型式";
   : radio_button {
     key = "tyft";
     label = "椭圆封头放样";
     value = "1";
   : radio_button {
     key = "dxft";
     label = "碟型封头放样";
     value = "0";
   : radio_button {
     key = "pg";
     label = "盘管俯视图";
     value = "0";
    :row{
   :boxed_row {
      label = "方向";
    : radio_button {
      key = "ssz";
      label = "顺时针";
      value = "0";
    : radio_button {
      key = "nsz";
      label = "逆时针";
      value = "1";
   :boxed_row {
      label = "绘图比例";
              : popup_list
              { key = "sc";
                list ="1:1\n1:2\n1:3\n1:4\n1:5\n1:6\n1:8\n1:10\n1:12\n1:15\n1:16\n1:20\n1:25\n1:30\n1:40\n1:50\n1:60\n1:80";
                width = 15;
                fixed_height = false;
  :row{
   :boxed_column {
      alignment=left;
      label = "开始位置";
             : popup_list
               { key = "kswz";
                 list ="0°\n90°\n180°\n270°";
                 width = 15;
    : toggle {
      key = "txt";
      label = " 标出角度文字";
      value = "0";
            : image
            { key = "helpme";
              width = 14;
              aspect_ratio = 1;
              color=dialog_background;
   :boxed_column {
      label = "参数";
    : edit_box {
      edit_width=6;
      key = "nj";
      label = "封头内径或盘管外圈直径";
      value=1000;
    : edit_box {
      edit_width=6;
      key = "bh";
      label = "壁厚(仅对封头有效)";
      value=8;
    : edit_box {
      edit_width=6;
      key = "jj";
      label = "节距";
      value=100;
    : edit_box {
      edit_width=6;
      key = "zxbj";
      label = "螺旋线半径不小于";
      value=150;
             ok_cancel_help ;
GMT+8, 2026-11-4 17:44 , Processed in 0.591429 second(s), 35 queries , Gzip On.
