查看: 950|回复: 0
[VBA函数]:匿名块的两个函数
已领礼包: 181个
发表于 2002-11-18 17:05:22 | 显示全部楼层 |阅读模式
根据上次探讨的话题,给出两个常用的函数。
  1.   [FONT=courier new]
  2. '获取块集合中匿名块的数量
  3. Function GetUNBlockCount() As Integer
  4.     Dim BlockObj As AcadBlock
  5.     Dim n As Integer
  6.     For Each BlockObj In ThisDrawing.Blocks
  7.         If Left(BlockObj.Name, 1) = "*" Then
  8.             If BlockObj.Name <> "*Model_Space" And Left(BlockObj.Name, 12) <> "*Paper_Space" Then
  9.                 n = n + 1
  10.             End If
  11.         End If
  12.     Next
  13.     GetUNBlockCount = n
  14.     Set BlockObj = Nothing
  15. End Function
  16.   [/FONT]
  2. '返回最后创建的匿名块
  3. Public Function GetUNBlock() As AcadBlock
  5.     Dim n As Integer
  9.                 If Mid(BlockObj.Name, 3) >= n Then
  10.                     n = Mid(BlockObj.Name, 3)
  11.                     Set GetUNBlock = BlockObj
  12.                 End If
  13.             End If
  14.         End If
  15.     Next
  16.     Set BlockObj = Nothing
  17. End Function
  18.   [/FONT]
GMT+8, 2026-11-2 02:00 , Processed in 0.422958 second(s), 32 queries , Gzip On.
