查看: 1218|回复: 0
[建议]:标记图戳加用户名
发表于 2002-11-19 18:30:55 | 显示全部楼层 |阅读模式
这样就知道谁修改了!
下面是VBA代码,块是用的
XD的
Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" (ByVal lpBuffer As String, nSize As Long) As Long
Public Sub TRZ()
Dim BLK As AcadBlockReference
Dim PT As Variant
Dim retval As Variant
Dim i As Integer
Dim r As Double
Dim s$, cnt&, dl&
cnt& = 199
s$ = String$(200, 0)
dl& = GetUserName(s$, cnt)
On Error Resume Next
r = ThisDrawing.Utility.GetReal("图章半径:(20)")
If r = nil Then r = 20
PT = ThisDrawing.Utility.GetPoint(, "插入位置")
d = 7
Set BLK = ThisDrawing.ModelSpace.InsertBlock(PT, "modify_tag1.dwg", 1, 1, 1, 0)
retval = BLK.GetAttributes()
retval(0).TextString = Mid(Date$, 9, 2)
retval(1).TextString = Mid(Date$, 6, 2)
retval(2).TextString = Left(Date$, 4)
retval(3).TextString = Left(Time$, 2)
retval(4).TextString = Mid(Time$, 4, 2)
retval(5).TextString = Left$(s$, cnt)
BLK.ScaleEntity PT, r / 20
End Sub
GMT+8, 2026-11-7 10:27 , Processed in 0.326828 second(s), 32 queries , Gzip On.
