查看: 649|回复: 1
[LISP程序]:怎样编一个程序来判断点是否在选定的边界内
发表于 2004-5-21 10:30:06 | 显示全部楼层 |阅读模式
我需要在选定的边界内间隔一定的点插入行,该怎样判断点在内部啊??请大家给点建议!!谢谢!
发表于 2004-5-21 11:03:30 | 显示全部楼层
试试这个:
(defun c:test ()
  (setq e (car (entsel)))
  (setq p (getpoint "\nPick Point: "))
  (command "area" "O" e)
  (setq a0 (getvar "AREA"))
  (command "offset" 0.01 e p "" "area" "O" (setq le (entlast)))
  (entdel le)
  (> a0 (getvar "AREA"))
GMT+8, 2026-11-3 16:17 , Processed in 0.548671 second(s), 34 queries , Gzip On.
